HP DeskJet 6540 InkJet Printer Logo
Posted on Feb 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i clean heads on hp 6540 under windows 7? The printing has faint colors
Anonymous
Level 2:
Sergeant:
  • Expert 422 Answers
  • Posted on Feb 04, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
422
Questions
0
Helped
104074
Points
985
Go for the printer cleaning section of win 7. or its hp driver software you install there are some instructions. but you can clean it manually also, pull out cartridges, use soft, wipe print head it with clean clothes a some alcohol. also do it to the printer trail, pulleys just be careful
Testimonial: "thank you it works"
Anonymous
Level 2:
Novelist:
  • Expert 169 Answers
Anonymous
Expert
Level 2:
Novelist:
Answers
169
Questions
0
Helped
47902
Points
377
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Go to Printing Preferences 3. Click the Features Tab 4. At the bottom of the window you will see Printer Services or Device Services. Click on it. 5. Choose Clean Printheads on the list.
Try Printing Again. I hope I was able to solve your problem. :)
While printing in black, why are there faint ink smudges?
It could be the "clean print head" sponges. The area under where the print head sits is where the ink go during the head cleaning cycle. They can become saturated with ink and smear onto the print head and then onto the paper.
Stops printing
Your Printer head need cleaning, try doing a self cleaning or change you ink, hope this helps.
I tried printing text including elaborate colorful artwork on the pages. Some of it printed but the text became increasingly smeared. Finally it would not print any more. Hours later I tried copying a...
2 possible causes: 1 - the ink has started to dry in the cartridges, it has become too thick for the heads to project on the paper correctly and in the end it has clogged the printing heads - replace the cartridges and run several deep cleaning cycles. 2 - hardware fault: either the data cable (the ribbon that connects the print head carrier to the mainboard) has been damaged and it will have to be replaced at a repair shop or the processor of the printer has just failed - this is terminal since it will be cheaper to buy a new one than to replace the mainboard. To make a pretty exact diagnose of the situation take out the cartridges and see if the printer recognizes the situation when you try to print something. If you get an error message then it's the data cable, if the printer is unresponsive then it's the processor - time for a new one.
Won't print except really faint color
Finally - continued to do further print head cleaning (about 6 times, included 2nd level) and finally started printing black again.
HP 7110 still won't print in color
Your post "...it prints very faint horizontal lines in color..." is indicative that indeed your color printheads are clogged and would need repetitive deep head cleaning. This is of course would require that you keep on cleaning until such time as the faint color lines have turned to legible print.
HP Deskjet 6540
The color cartridge sping was loose. I am in the process of super gluing it into place. Hopefully it will work.
Stripes
You could try doing an alignment which i think is a maintenance option on this machine. You should find it in the driver options. You could also look at my previous posts about under head cleaning. Look here -> http://www.fixya.com/support/t137335-problem_print_outs_from_printer
k24674
Grand Canyon Tech
Grand Canyon Tech
