Question about Maytag MER6772 Gemini Electric Kitchen Range
Upper broiler the upper broiler won't heat but the bake does. replaced the broiler element and that didn't solve the problem.
  • tjjones1132 Nov 17, 2008
    My problem is similar - but it is the bottom element )bake) of the top oven that does not work. We replaced the element, but it still does not heat. Cam't toast, can't "keep warm".
Mine did the same thing. Turned out to be digital panel.
Posted on Oct 17, 2008
  • 37 Answers
The next step would be to check your wiring and control switch/knob to ensure correct function. You can use a multimeter to check the wiring (with the power off) and a voltage meter to check the control (with power on), be careful high voltage can hurt you badly. Good luck.
NSSMS
Posted on Jul 21, 2008
Bake and broiler element come on when bake is selected. Why?
Understand that I am not a professional, so this answer is subject to revision by someone who is more knowledgeable.
Where I live now I'm on Natural Gas, but in the past I've had electric stove/ovens. Based on my best recall the situation you describe is NOT abnormal.
When in the Broil mode, the Bake element is NOT on, but the Broil element is on FULL-bore to provide that strong radiant heat required for the Broiling process, AND for the good browning /crusting of the product being Broiled!!!!!
On the other hand, when Baking, not broiling, IF the Broiling element were on high it would provide too much radiant heat to the top of the product being Baked, and would burn the top.
While Baking, by energizing the Broil element in a lower power setting, the Baking process is enhanced with more heat by the assistance of the Broiler element, BUT without the hazard of burning on the top!!!!!
Hope this is right and helps your understanding.
Jan 16, 2015 | Ovens
Whirlpool built in electric oven
The upper element is for broiling and should not come on until you tell it broil. If it is coming on as soon as you turn on the breaker then it sounds like the printed circuit control board is bad. There is a relay on the board that engages when you program in the broiler. The relay can be hard to find and may not be removable. My broiler would come on when I programmed in the bake mode, go into runaway heat, put up a F10 code, and shut off. I could not clear it until I programmed in the clean mode for 2 hours. Now it works great.
Sep 07, 2014 | Whirlpool RBS275PD Electric Single Oven
Why doesn't GE JBP24 preheat?
Not familiar with this exact range, but it could be a couple of things.
If the broiler (upper) element heats properly and the baking (lower) element works properly, then the issue is probably in the controller/preheat switch.
If the broiler doesn't heat up, then the upper heating element.may need to be replaced.
Jun 15, 2014 | GE JBP24 QuickClean Electric Kitchen Range
Neither oven or broiler work. Upper elements work well. Why is the bake light flashing / blinking?
if it is not coming on then you may have the same problem again with the ignitor.
May 04, 2014 | Ovens
No heat when set to broil but the bake turns on the broil element. nothing turns on the bake element. are the wires hooked back correctly?
see the next steps and proceed according with commong sense: God bless you
Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. To determine if the heating element is burned out, watch the part testing video at the bottom of thi
Jul 27, 2012 | GE Kitchen Ranges
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
Is the upper element supposed to heat up when roasting or baking?
Normally, the upper element is the broiler and isn't active during baking. If it was, it could easily burn the tops of baked goods.
It may well turn on during the self-cleaning cycle if so equipped since the temperatures required for the special coating to become active is ~ 900 degrees F and can't be reached by a single element.
Nov 29, 2009 | Whirlpool RF368LXKS Electric Kitchen Range
Kenmore range bake element doesn't work
check that the wiring is not bad and every thing is conected
Jun 04, 2009 | Kenmore 95922 / 95924 / 95929 Electric...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Bottom Baking element not working
dmiller58
If all your connections are solid then your controller is defective. Did you get any faults before changing the element? Does the broil (one at the top of the oven) work?
Post a response
Regards
Sep 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
109 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
