Hi My zenith allegro from 1961 am fm stereo just quit running. Model number E939 chasis 35WDR507. Can you tell me who can fix my console wood cabinet zenith? clare439@sbcglobal.net phone nr: 847 515 1949
  • clare439 Jul 21, 2008
    I payed $10 to "get" the name of a service repairman to fix my Zenith sterio console from 1961.
    Clarence
    Master:
  • 382 Answers
I will say the Experts in Fixya can Fix any of your problems and assist you with many solutions..But concerning your question here we were suppose to find and help you with a service man in you place buddy..btw the Solution is you an find a repairman in fixya on the right side where you have a block..Please enter you state code and you can easily find the Repairman!!..
THANK YOU!!..REGARDS!!..
Posted on Jul 21, 2008
  • Natesan Sabesan
    Natesan Sabesan Jul 21, 2008
    Also Im sorry to say you have paid 10 $ for finding a Repairman only my Friend!..Even if you have any other queries please post back for how things turned on or for further assistance!.. :)
  • 3,037 Answers
It looks like you are in the Chicago area
Try Peckens TV & Video Established Over 50 Years.
364 Irving Park Rd Roselle, IL 60172 (847) 230-4988 Let me know if they can't help you and I will see where else you may go. good luck
    President:
  • 2,712 Answers
Try the link on the right that says "Repair Service". Just enter you zip code in the box, and you will find a list of service centers in your area. Mention that you were referred by Fixya, and you should be able to get a discount :)
Does old Zenith Allegro Console Stereo - 8 track/AM/FM/turntable, have a belt drive phono? I can see metal gears to drive the stuck turntable .
The manufacturers of such items would usually buy in such hardware as record turntables from fairly standard catalogues.
One popular brand of turntable was the BSR but the design of other brands were similar. The metal gears aren't for driving the turntable but to drive the multichange mechanism so when one record has finished playing another will drop from the stack loaded onto the extended centre spindle.
This type of turntable is driven by a synchronous motor with a multidiameter spindle via a moveable idler wheel equipped with a soft rubber tyre. Lack of maintenance causes many problems and as the rubber tyre ages it tends to harden and lose traction on the inside of the steel turntable so when the record reaches the end and the metal gears engage there is insufficient torque and everything stops.
It is for that reason many older examples have had the multichange removed or disabled.
Removing the turntable centre motif should reveal a circlip which when removed will allow the turntable to be removed for maintenance.
Jun 07, 2017 | Zenith Televison & Video
Old Zenith Allegro Console Stereo (made in England). - Turntable will not turn; tone arm does not move, even on "manual."
remove the flat rubber platen cover to expose the lock ring at center (horseshoe clip) remove this lock ring and pull the platen straight up and off , under there you should find a rubber tire and the drive motor shaft , turn unit on , you should see motor turn and then it should move rubber tire , if not , your going to need to replace it or clean it up and lube it
Jun 06, 2017 | Zenith Audio Players & Recorders
Can you replace the turntable in a vintage Zenith Console sterio with a newer turntable?
Generally speaking all you need to do is find the left and right channels leads from the old deck to the amp, cut them off or if thy plug in somewhere unplug them, then you can connected the playback leads of the new deck to the amp and it will then play back.
Jun 22, 2014 | Audio Players & Recorders
Need manual for DVD & VDR progressive scan, Allegro by Zenith
Did you try a Google search for the product name and model number? ( Example: Zenith Allegro DVD VDR progressive scan model number xxxxxxx manual.) You should be able to find the manual on-line if you have the model number (not the serial number).
Feb 11, 2012 | Zenith Televison & Video
I have a Zenith Solid State Console Stereo model E939, which no longer plays in stereo. Any suggestions or solutions???
your botton could be jaming up open radio up blow it out with air in can then see what happens.
Feb 05, 2011 | Zenith Audio Players & Recorders
Trying to find a way to get the turntable of a Zenith Allegro Console to work. We have turned to whole unit on and off. AM and FM radio plays. Turntable doesn't turn. At the bottom right of the turn...
Lift the turn table off the case and check the belt if it has one or the idler wheel that mechanically turns the table. Also check the motor to see that it rotates when you simulate a record play moving the needle carrier towards the center, The power must be on to test it. Becareful not to touch the 115 VAC line.
Oct 29, 2010 | Audio Players & Recorders
My old zenith (probably early 90s) only gets up to channel 48 when there are more channels provided by my cable service. I have used the autosearch, and thats what number it goes to.
[1] use LG exteanel setup box chenal convater 90 to 200 ch avalabel in market .
[2] use inside of tv extra chenal convater pcb. PHLIPS.
[3] change complet new tv chasis with new latest function and all new facilety
EXP.
UOC Technologey chasis
NTSC /PAL /SCAME / AUTO Multi Colour System
Auto Search tunig
A/v 1 -2 -3 Stereo.
A.v Out facility
DVD Comonent input
surround sound mode
1300w pmpo woofer System
on timer /off timer /clock /sleep timer facilety
calender
5 pictur mode
Curtain Effect.
all facilety Avalabel in TOSIBA /SANYO chesis
pls Cont. your Nr.tv techicien
Oct 30, 2009 | Zenith C27A24T 27" TV
Zenith Allegro console stylus
I have the same model with the 8 track player, original manual, and original receipt dated 1975.
Jul 15, 2009 | Audio Players & Recorders
126 people viewed this question
 Grubhead
Grubhead
