Hello, the problem is with an acer aspire l100 desktop computer. When it starts up it freezes continuously and won't shut down. How do I solve this problem?
    Genius:
  • 1,011 Answers
Dear,
what are the starting and freezing conditions. i mean it freeze at what end. in the start, when windows starts, or on the other stage.
if ur computer freezes at very start, where the ram, hdd show. then its some hardware fault. it can be b'coz of ram. so check ur ram or rams.
if ur computer freezes at the starting of widows then it can be hardware but mostly software/ windows problem. so repair ur windows or try to run it on safe mod. b'coz if it run on safe mode then it dead sure that ur windows files have been corrupted or missing.
regards,
salman
Posted on Jul 21, 2008
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    Hi When I start up my Acer Aspire L100 mini desktop, it makea clicking noise, which emits from with the computer and then the computer freezes with the screen below. Also, sometime I have to power off on,...
    You can solve this problem by:
    -- cleaning system junk
    -- optimizing computer services
    -- repairing registry
    -- defraging registry
    -- clearing browsers junk
    do these things with some secure tool such as Intel Software Partner Reginout.
    Also remember to uninstall and reinstall updated drivers for your devices. Thanks
    Nov 10, 2010 | Acer Aspire L100 PC Desktop
    My acer aspire l100 keeps shutting off. it sometimes will stay on for like two minutes but most of the time it shuts down after like 30 seconds. it works fine in safe mode. most of the time it shuts off...
    this seems like a software issue . if you can not run your system but ift works fine in safe mode try to run a system restore from factory disks and see where that gets you,
    May 14, 2010 | Acer Aspire L100 PC Desktop
    Thanks for the response to my Acer L100. have checked the cables and they are fine. have noticed the fan doesn't start up when the computer is switched on....could this be the problem???
    The CPU fan should turn on when the PC is powered on, and then it usually slows down until the workload on the processor causes it to heat up, then the fan spins faster, it might also be a power supply issue, but if your able to boot and its giving you messages and not shutting down then you should re-install the operating system.
    Nov 18, 2009 | Acer Aspire L100 PC Desktop
    PC automatic shutdown
    logon.ddl has been missing u hv to reinstall ur operating system
    formate ur pc it will solve ur problem
    Jan 29, 2009 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 overheating
    You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
    Dec 22, 2008 | Acer Aspire L100 PC Desktop
    Acer l100 shut down
    You can buy a Laptop cooling pad for less than $40 from most any computer store.
    Oct 26, 2008 | Acer Aspire L100 PC Desktop
    Possible overheating problem for Acer Aspire mini L100
    I am not totally sure if this is the problem, but I would suggest that you may have a power supply issue or possibly it going out. If the computer runs fine, and then shuts down, than this can be more symptomatic to a overheating issue.
    In my limited experience with overheat issues, the computer actually smelled like it was getting hot, and then it would slow down and then sometimes stop. Most computers have fail safe settings where they either alarm, or shut down or both when they overheat.
    Sep 26, 2008 | Acer Aspire L100 PC Desktop
    Computer will not shut down
    I have not switched to Vista, but I would try starting the Task Manager (right click on the task bar and select task manager). Then I would select the Processes tab and start killing processes to see if you can track down which one is causing your problem. Assuming you can narrow this problem down to a single process you'll at least have a fighting chance at solving fixing this.
    Good luck.
    Nov 19, 2007 | Acer Aspire L100 PC Desktop
    Computers & Internet Logo
    127 people viewed this question
    David Payne
    David Payne
