Question about Euro-Pro Shark EP366 Handheld Vacuum
It just quit
I have a Shark hand hekd vacuum which I use for small jobs and removing hair from our retriever via a collecting tank which collects the hair before going into the vac. However, it was working fine this morning and suddenly quit. There was no signs of overheating. I emptied the dirt chamber which was far from fullo and tried to turn it on and it is dead. Is there an overload swith on this vac? Is there a reset button and where is it? Please let me know before I go and buy another hand held vac.
Charles Baum
e-mail, akelacmb@hughes.net
or akelacmb@earthlink.net
I took it apart and cleaned it a little and put it back together and it works.
Posted on Jul 22, 2008
What causes my Shark Vacuum to work only intermittently?
If the brush roller operation is intermittent, there may be hair jammed inside the end caps. The brush roller can be removed and the end caps also for inspection. Intermittent operation also can be caused by a stretched drive belt.
The periodic failure to pick up may be caused by something such as a ball of hair migrating through your vacuum cleaner and stopping from time to time to test your patience
Jun 26, 2013 | Shark Navigator Bagless Upright Vacuum
Where to fix float in collection tank
Hey Val, inserting the float is quite easy. Turn the tank so the flat side of the tank is facing you. Where it says, "Fill with Clean Water to here", there is a groove on the inside of the tank just behind the writing. Slide the rattle sounding weighted end of the float vertically into the groove. The float will only fit in one way.
Jan 31, 2013 | Bissell 7700 Big Green Complete Vacuum,...
Why does my filter collect so much dog hair and decreases the suction of the machine. I clean and change (alternate) filters everytime I vacumn, that isn't normal, is it? It seems like I have a seal or...
You obviously have a pet and it's good to see your machine is doing it's job. The only reason you could lose suction while collecting pet hair is due to the pet hair being a solid mass and air not been able to flow through the filters.( must be a lot of hair). Suction loss is only when the particles passing through your machine are dense therefore it will reduce suction and airflow . Very common on vacuum cleaners. Do not worry too much . Also check to see if you have Amy cracks in the seal between the drum and the vacuum cleaner itself
Jul 15, 2011 | Dyson Vacuums
Little Green pro heat is leaking from bottom with very little suction. I just purchased it.
Try the following suggestions for the leaking issue:
- Check to see if the black or white "duck bill" gasket is misassembled or missing from the collection tank; ensure the gasket will open where the flat flaps meet and then reinstall it. The duck bill should be inserted into the curved side of the collection tank.
- Check to see if the solution tank/cap insert is leaking.
Note: When the solution tank is filled and turned right side up, the straw on the insert may fill with water/solution causing the tank to leak for a couple of seconds. This leaking should subside after the straw empties out.
- Check for proper placement of the o-ring on the cap insert. The o-ring should be between the bottle and the insert piece (part with the "straw").
Try the following for the suction issue.
- Remove the Collection tank and locate the circular motor duct on the base of the machine. Turn the machine on and feel for suction at this location. If you feel suction proceed as follows:
- Remove the gasket from the bottom of the Collection Tank. Ensure that this gasket is open (not sealed shut) at the top of the gasket where the flaps meet. If the end is not open, simply squeeze the end to open it. The “duck bill” shaped portion of this gasket should align with the rounded side of the Collection Tank.
- Check to make sure there are no cracks in the flexible vacuum hose or in the tool you are using.
- Make sure the collection tank latch is locked down securely.
- Check for suction at the end of the hose with the attachment off by suctioning water out of the sink or a cup. If there is low/poor suction, check the hose for clogs by raising the hose handle above the unit to allow the water to go into the collection tank.
The issues may be related as you can see some of the suggestions are similar.
Aug 04, 2010 | Bissell 1425 Little Green ProHeat Handheld...
My vacuum has no suction and when power is on and I stand it upright it shuts off
soonds to me like you need to check all of the removeable port inlets. Check for debris. what we find quite often, especially with pet owners, is that the collection tank, even after dumping is plugged with fine particulates and or pet hair lodged up high inthe cones. try tapping your dirt cup on the floor not too hard, and then dump the dirt. if you have access to a air compressor, or a canister vac w/ a blower port, blowing the tank out quite often will give good results.
Sep 12, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Tank not collecting dirty water
You most likely have a break in your suction hose. check at the base where it attaches. When you bring back the handle release, you can see lt. If you have the type that has the external plug in for the water, then you probably don't have the hose part plugged in to the collection tank. in the front of the collection tank. Your motor shut off? Well, If you have the first variety cleaner w/built in hose, you may have sucked water into/onto your motor. If this is the case you need to bring it for service. otherwise, you could have a blockage in your collection hose, this would also explain the machine shut down, from the thermosat. A clogged machine will ultimately overheat, wont run again till cooled.
Jul 18, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Roomba Discovery
did you replace the filter? when you remove the dust bin there is a small filter that needs to be cleaned, or replaced. You can buy a maintenance kit that replaces the brushes and filters as well, its good to replace them all regularly
Oct 02, 2008 | Roomba Robotic Floor Bagless Vacuum
Dirt/Collection Tank Bissell Little Green
I had the same problem, so I took out the black stopper, and soaked the whole thing in bleach water for about an hour, then I took a hand full of " aquarium " rocks and put them inside the tank, and shook them inside using a bit of the same water and then got rid of the rocks,( the rocks worked as an scrubber ) .... it worked pretty good
Sep 22, 2008 | Bissell 1400 Little Green Pro Canister...
Emptying the powerbrush
Gently
press the Quick Release tabs on the Clean/Solution Tank
and slide the tank off of the unit.
Grab the Dirty/Collection Tank and pull to remove.
While at the sink, remove the Tank Cap by turning
approximately 1/4 turn counterclockwise and lift
out the cap.
Empty the tank. Rinse the Dirty/Collection tank with
warm water.
Replace cap and turn approximately 1/4 turn clockwise,
until snug.
Slide the Dirty/Collection Tank into the unit. Replace the
Clean/Solution Tank.
The tabs on the side is what locks the tank on, if they won't release the tank, then you may have to take apart to get it off and replace the tank.
Jan 30, 2008 | Bissell SpotLifter 1716 Bagless Handheld...
Euro-Pro Shark EP366 Handheld Vacuum Logo
205 people viewed this question
Top Euro-Pro Vacuums Experts
Roger Potts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
