Question about Euro-Pro Ultra Steam SharkTM II Hard Surface Steam Cleaner Vacuum
Shark steam bottle sc618w
Mike, i purchased this product about 8 months ago never tried to use it until now. filled with distilled water, turned on light goes on when ready but cannot get any steam to come ou, tried several times even tried suggestion of pulling trigger 8 to 10 times quickly to get it started. please help. carole gunderson
  • 1 more comment
  • Hevyn Aug 29, 2008
    I have the same exact situation - mine is practically new but the water barely gets warm and no steam. I went on the Euro Pro website to send a customer complaint, but it says server is busy-try later. *sigh*
  • lissal221 Mar 14, 2009
    Same thing, did what they said, pulled the trigger repeatedly, I get nothing.
  • spannd Mar 28, 2009
    I took mine out of the box. Filled with water according to directions. Squeeed the trigger numerous times. no steam. It's brand new. Help
LizDahl
  • 75 Answers
SOURCE: Vinegar
Do not add anything to the tank.... Vinegar is corrosive and that would potentially be very bad.
Posted on Feb 27, 2008
evbob
  • 8 Answers
SOURCE: shark steam mop
Well got one brought it home worked for five minutes. Went back to walmart exchanged my Shark.Only one box left,looked opened but nothing seemed out of place till I got it home.Must have beeen a previous return somebody was short a funnel for their meth.lab(lol).Now warranty or not have tod to take it apart and see.There is a line that looks like it has a tendency to come off it has a spring inside it.Looks like it just blew apart because of pressure (poor design) Going to reattach it see what happens.
Posted on Jun 13, 2009
Merlyn66
SOURCE: I can't get my shark steam blaster model EP95 to create steam?
if you decide to junk it, I'll buy it just to get the resevoir lid that I lost
Merlyn
Posted on Sep 01, 2009
heatman101
  • 43501 Answers
SOURCE: my shark steam pocket mop
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
zx
Posted on Sep 24, 2010
heatman101
  • 43501 Answers
SOURCE: have a shark steam mop
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Posted on Jan 28, 2011
Why the euro pro shark mop model S3202 Get hot but does not steam
Unplug your mop, add vinegar, plug back in, let it sit inside a sink or tub. When all vinegar has been steamed out, then unplug, Now add "DISTILLED WATER" and repeat until all brown residue left over is gone. Then, from now on, only use "DISTILLED WATER".
Jul 08, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam wont come out although filled with water and heated as required
If you are using tap water the holes where the water comes out are plugged. You will have to take it apart to clean. After that you should use distilled water you can purchase at your local grocery store. That is what my wife uses after I insisted.
Dec 01, 2013 | Vacuums
Vax co uk support
There are a number of possibilities. I have this appliance and I'm not a fan of it!
  1. Check the water filter isn't void, which is behind the main water tank at the front. It should have a sandy colour to it and if it is low or discoloured, then it requires to be replaced.
  2. Fill the water tank with water and the back tank (if fitted) with clear "white" vinegar and switch on. If there is only one tank fill half with water and vinegar. Then press the trigger on the handle. If nothing comes out, You will need to buy a new water limescale filter which can be purchased from Vax UK.
Oct 31, 2013 | Vacuums
Shark Euro Pro Steamer
Hi, you could try the following steps, if you have not done so already. Some of these steps may seem like common sense, but it's for people to forget about checking the least expensive part to replace first, so if some of the steps are those that you have already tried, then feel free just to skip through to the ones you have not tried already.
  1. 1
    Make sure the power cord is plugged firmly into the outlet. The steam mop will not start if it the power cord is loose.
  2. 2
    Check the fuse box or circuit breaker connected to the outlet the steam mop is plugged in to. Replace any blown fuses. Reset any tripped breakers.
  3. 3
    Check the water tank if the Shark steam mop will not produce steam. Add water to the tank if it is empty. The mop will not make steam without water in the tank. To fill the tank, turn the tank cap counterclockwise and lift it up to remove it. Set the filling funnel into the tank opening. Pour water through the funnel into the tank until the water level reaches the "Max" fill line on the tank. Replace the cap.
  4. 4
    Inspect the microfiber cleaning pad if the steam mop is leaving water on the floor. If the microfiber pad is too wet, it will leave water on the floor. Unplug the mop from the wall outlet. Replace the microfiber cleaning pad. To replace the pad, move the latch strips out of the hooks on the mop head. Pull the pad off. Set the new cleaning pad on the mop head. Hook the latch strips onto the hooks on the mop head.
  5. 5
    Use distilled water if the steam mop is leaving white spots on the floor. Hard water may cause white spots to be left.
If none of the above work, then is it something that you purchased recently, and is new? If you did, then it could still be fixed under the manufacturer's warranty regardless of whether or not the original length of the warranty has expired. This could be due to the fact that you have received a product that has some sort of manufacturing fault, rather than it stop working through misuse by the user.
If it's a common problem, then you will more then likely be able to return it to the manufacturer and have it replaced for a new one, let alone repaired :-) - This only applies to whether or not the item is New though :-).
Hope this info helps
Apr 29, 2013 | Vacuums
I need operating manual for vapor white wing steamer
This is from an Amazon review. I have misplaced my manual and was searching for a pdf file without any luck. I think I have it under control if I only knew where to put my distilled water.Basic operation of the WhiteWing is:
1. Fill the tank with distilled water
2. Attach the hose to the steamer.
3. Attach the extension handles and attachment you want.(Be sure to watch the video and read the instruction booklet. Some of the attachments have specific uses and setup instructions)
4. Lock the finger trigger.
5. Plug it in.
6. Turn it on.
7. Wait 20 min. or until the pressure gauge reads between 3.5-4.5.
8. Get ready to rock - press the steam release button, unlock the finger trigger and start steaming.
For many jobs such as countertops, shower stalls, stovetops, you will need to follow behind the steam, wiping with a cloth to remove the released dirt from the surface. Some jobs may require you to start with a non-toxic cleaner or grease remover such as Orange Clean or Method brand cleaners. Remember, you'll be breathing in vaporized cleaner. So be sure it's something non-toxic and non-irritating. I prefer the Method brand cleaners.
Jun 20, 2012 | Vapor WhiteWing Steamer Canister Vacuum
Shark s3501 plugged
I had same problem with no steam... ready to throw in the dumpster!
I tried to it take apart. (kind of hard) still ready to throw it!
Then I thought about CLR!
I put about 1/2 cup in, turned on and let set for about 20 to 30 minutes.
I really did not think this would work but... Amazing! I actually got STEAM!!!!!!
Next I dumped out what was left, put in distilled water and ran for another 30 minutes on high.
Will use CLR again before final clean out and 2 full tanks of distilled water before I use again.
May 27, 2012 | Vacuums
Shark S3101 Steam Mop won't produce steam
You have to use distilled water in the steam mop. regular water clogs it up and causes it not to work.
Nov 27, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The mop just stopes making steam to the head. Could this be A heat coil problem? Also a lot of others have had This happen.
On these steam mops, you have to use distilled water, if you use tap water and do not have a house water softner or some kind of water filtration system, the water running thru the tubes of the steam mop
will develop calcium deposits, these deposits are caused by hard water and will clog up the tubes, and keep the mop from producing steam, then you will have to replace the lines. i own this brand of steam
mop and had the same problem you had, I replaced the lines and started using distilled water, and have not had any problems since and that was last year. good luck!
Aug 18, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Somewhat new_ leaking dark water on white shirt- washed then repeated
I stopped vacuuming my shirts ages ago, and mostly everyone else did, so I assume you're talking about an iron?
The dark water is just tap water that was sitting inside the iron and caused it to rust.
After you rinse the iron several times with distilled water, keep using distilled water from now on.
It's about $1.00 per gallon and you can buy it in any supermarket.
When you use distilled water in your iron, there is no need to empty it every time you're done with the weekly ironing.
Jun 01, 2011 | Vacuums
How do I clean my iron?
I am assuming that you have scale or lime build up on your iron. Make a solution of half white vinegar and half distilled water. Pour it in the water container on your iron. Turn your iron on its highest setting and set for steam. Wait about 15 minutes and turn off the iron. When water cools pour off the remaining water/vinegar solution. Fill the iron with distilled water and turn on. Let it heat and then cool then pour off that solution. Do this till the poured off water runs clear. If you have scale on the bottom of the iron you can clean that with an old toothbrush dipped into warm white vinegar. There may be easier ways to do this but this is eco friendly and it works the best of anything I have tried.
Apr 08, 2011 | Vacuums
Euro-Pro Ultra Steam SharkTM II Hard Surface Steam Cleaner Vacuum Logo
641 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
