Monitor works with one workstation but not another
  • 94 Answers
OK; more basic troubleshooting is needed.
1] monitor doesn't work a] try on different cpu - check b] return with monitor from other cpu - ?
From the above I will try to spell out my steps.
1] notice monitor stops working
2] since I have another cpu close by - swap [it is important to also back swap {working monitor from other cpu]
analyze result.
I suspect that the video output somehow changed and the current display can't 'catch' what the video card is throwing.
does the display show the POST? is so, then you can start in safe mode and then set it to a low resolution.
Posted on Jul 21, 2008
Poweredge 6600 not showing display
If you have multiple video connections (onboard from motherboard, usually vertical or stand alone video card, usually horizontal) that you plug into the stand alone card, as the onboard is normally disabled when the expansion is installed. Verify the cable and monitor both work and that the monitor is on the correct input. Finally try another video card, if you have one available. Even if the drivers are not correct, etc, you should still see a boot screen.
Nov 13, 2013 | Dell PowerEdge 6600...
HP workstation going to sleep mode when windows logo appears.and it is working in safe mode and vga mode.
Did you change your monitor / resolution / card drivers / refresh rate?
Sounds like your computer resolution is out of range for the monitor. (or refresh rate)
Solution: Boot in safe mode and change the resolution, then boot to normal.
Optional: Update graphic card drivers.
Aug 09, 2011 | HP xw9300 Workstation PC Desktop
Fiery unit s400 will not work
If you press the Fiery button on the copier does the copier display the Fiery logo and the menu. If yes you are just missing the Fiery software for the workstation (called Command Workstation I believe). If no you will need a service call to possibly reload system software.
Feb 10, 2010 | Office Equipment & Supplies
Roland vs-1880 workstation graphic display gone blank
there is a bulb in the display to backlight probably burned out.
Jul 03, 2009 | Electronics - Others
Planar PE191M monitor display will not stay on
iv come across this before sometimes people can see that the monitor is actually working but the light has gone out id say bad capacitors that are breaking down. if you want to DIY it take it apart and find the light pcb usually built on the power supply pcb and look for bulging or swolen capacitors this happens alot in my opinion. if you can DIY it get the same caps or same value but better ones. I might be wrong but worth a look
Apr 01, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
Korg Triton Studio Workstation Keyboard
it has something to do with power input of your monitor. Or the HOT shorted.
Mar 31, 2008 | Gateway FPD2275W LCD Monitor
No Video
remove RAM and safely clean it after that reinstall the RAM.
Nov 24, 2007 | ASUS Pundit-R Barebone
Open Questions:
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
