Ribbon problem thanks i know that. my problem is... theres one space for aribbon so i can uyse either the cd roms in it or the hdd, my old motherboard had room for both.
    Genius:
  • 2,785 Answers
You can try with another cable having two three connectors( one will go to motherboard
Posted on Jul 21, 2008
Dell Gx60 doesnt recorgnize hdd and cd rom
If both the HDD and CDRom are on the same cable, try replacing the cable. Check the jumpers to make sure they are set correctly as well. If neither of these work, it's likely your IDE controller (that is where you plug the ribbon cable into your motherboard) is defective. You can try to move it to the other IDE controller to see if that works. If not, you may have to replace the motherboard.... assuming you know the HDD and CDRom drives are good. I hope this helps!
Sep 23, 2011 | Dell Optiplex GX60 PC Desktop
What is the best motherboard and system configuration for adobe premiere 6.5 and pinnacle pro on rtdv ? I need the configuration in details please..... Please, thanks, Mack
TECH SPECS for ADOBE PREMIERE 6.5
Minimum System Requirements
Windows
  • Windows 98SE, Me, 2000 (SP2), or XP
  • Intel PIII 500MHz
  • 128MB RAM (256MB or more recommended)
  • 600MB HDD space for installation
  • CD-ROM drive
  • QuickTime 5.0 recommended
  • Microsoft DirectX certified FireWire
  • dedicated large-capacity 7200RPM HDD
  • For Real-Time Preview:
    Pentium III 800MHz processor (Pentium 4 dual processors recommended)
    Macintosh
  • Mac OS 9.2.2 or Mac OS X v.10.1.3
  • PowerPC G3 (G4 or G4 dual recommended)
  • 64MB RAM (128MB or more recommended)
  • CD-ROM drive
  • QuickTime 5.0.2
  • QuickTime compatible FireWire
  • large-capacity HDD capable of sustaining 5MB/sec
  • For third-party capture cards:
    Adobe Premiere certified capture card
  • For Real-Time Preview: G4 processor (G4 dual recommended)
  • Jun 27, 2011 | Pinnacle Pro-ONE RTDV Video Capture
    Wen i switch on my computer it freezes at a screen showing biostar motherboard and the url
    Remove al.l the power jack from HDD and cd/dvd.and start again,
    If the problem is same think RAM problem .
    I know when remove the power socket from HDD it will solve,Only reasen hdd is defected due to bad cluster.
    You will zero fil with ontrack bootable dm.
    Hope this helps.
    2.Restart >press F2/F10/Del( for entry in the BIOS)>Set the cd/dvd as 1st priority.
    3. Ensure that your Bootable dm cd, in cd rom.
    4. Boot from cd will be appear then hit Enter as quick as possible.
    5. All it will be possible, if you know dos other wise it will be difficult.
    6. DON'T PANIC,I hope, you will can do it
    Download link for ontrack dm=
    http://www.downtr.net/297918-ontrack-easyrecovery-professional-621.html
    Download and make bootable cd from iso file.
    7. Type that letter where the dm software in the cd.
    8. Type in dos mode. e.g. if your two partition c: d : so your dm will be in e:.
    9.type e: and enter , for observation type= dir and enter >now you can see is there ontrack or dm (directy or folder) have or not try it once after one
    10 If have ontrack in that folder type=cd (space) ontrack>cd (space) dm hit enter .
    11 If all ok type dm and enter
    12.Enter
    13.Advance installation
    14.Maintence
    15.Uttility
    16.Zerrofil
    Hope this helps
    Jan 12, 2011 | Biostar P4M800-M7A Motherboard
    No detection of hdd or cd/dvd rom
    try to delete upper and lower filters on the registry to make your cd/dvd properly working
    Jun 24, 2010 | MSI K9MM-V Motherboard
    Hoew to install CD Drive
    You want to install a CD Drive. Ok you are Following these steps....
    1. Unplug the power cable from your power supply and open your Computer case.
    2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
    3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
    4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
    5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
    6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
    7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
    Thank U
    Aug 28, 2009 | LG Computers & Internet
    ASUS P5S800-VM Motherboard configuration
    Serial ATA drives are pretty much plug and play. You just need to install them and set them up as a primary drive in your bios settings. The IDE devices can be connected on the same ribbon cable but need to have jumpers set on the back to determine which device is primary or slave. If the IDE devices are on different ribbon cables then most likely the hard drive jumper setting should be set to master or master (single drive). The CD-ROM drive jumper on master. BIOS should detect all drives You also need to assign the boot order in BIOS. CD-ROM should be the first boot device to load and install the new OS onto the primary hard drive.
    Mar 20, 2009 | ASUS P5S800-VM Motherboard
    MY DVDRAM DRIVE WAS CANT WORK, THERE IS NO (E) DRIVE SHOW IN MY COMPUTER.SOME TIME CAME DRIVE (R) BUT SOME TIME CANT WORK. I CANT ABLE TO RUN MY DVDRAM. PLEASE HELP ME OUT.
    sounds like the ribbon (cable) could be a controller issue, unplug the h.d.d. from controller head on mb and plug in the cd rom ribbon there boot into bios and look for the cd roms if the same problem is there replace the ribbon or you can check each one seperaely by running them off the primary ide as a slave to the hdd
    also swap ribbons with the hdd and see if there is still a prob. if these do not correct the prob you have a controller issue buy a controller pci card and use it or replace the board, the card is much cheaper or the last poss. is both cd roms are bad
    Dec 12, 2008 | Computers & Internet
    BIOS PROBLEM
    plz mention your motherboard and BIOS version.
    neways try this:
    1.go to ur Motherboard manufacture website and search if updated drivers for ur MBD are available, these include GFX, HDD, BIOS
    2.Is ur HDD old, rpm-5200? try upgrading
    3.If these dosnt help thn contact me
    Nov 20, 2008 | Intel 845GE Motherboard
    Mobo only one ide connection socket for HDD & CD-Rom
    yes you can add both your HDD and CD-ROM Drive with the same IDE, get a IDE data interface cable (BUS) atleast three connection point. Add 1 to mobo, second to HDD and top 1 one to CD-ROM drive. Just connect and dun wrry m sure it will work....so............:))
    If any problem just Ask me
    Thanks
    Iqbal
    Apr 07, 2008 | Computers & Internet
    Not posting
    Maybe a silly question to ask; but did you connect the processor power lead, as unlike some processors this needs a seperate supply.
    Dec 18, 2006 | Mach Speed MK8-939A (VIPERMK8939A)...
    Computers & Internet Logo
    19 people viewed this question
    David Payne
    David Payne
