Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool washing machine
I have just inherited a whirlpool washing machine and the second time i used it it let alot of brown flakes behind ran both hot and cold water cycles and nothing came through the water. The flakes reappeared when the machine started to spin. Any suggestions.
  • Whirlpool Master
  • 5,568 Answers
It sounds like the porcelein on the inner or outer tub is damaged allowing rust to form.
Another possibility is that there are iron deposits in the internal hoses that are loosening.
I would (assuming you can afford the water wastage) run the machine on 'full load' and 'hot' several times with no clothes in it to see if it will flush out.
Posted on Aug 03, 2008
Whirlpool model WTW5310VQO
i've found problems with the temp. switch on this washer part number W10184148 and it's around 40 dollars,also on the rinse cycle the washer only uses cold water.what happens when you use just the hot?i had a lady that her water would start to fill and then the water would stop and the pipes in the house would start making a banging sound.if you order the part from http://www.repairclinic.com/PartDetail/Switch/W10184148/1468990 repair clinic and if this isn't your problem which i think it is from how you discribe it you can send the part back and get your money back for up to a year.good luck with your washer and next time you buy something and it doesn't work right get right on it
Mar 14, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Turned on whirlpool duet washer, came back to FH as realized forgot to turn water on. Have tried all the suggestions, but each time I plug the machine it tries to drain water and the motor hums. I cannot...
Make sure both hot and cold water supplies are turned on. Select a cold wash cycle and start the wash cycle, do you get cold water? Now select a hot wash cycle and start the wash cycle, do you get hot water? If you only get cold water replace the hot water fill valve. If you only get hot water replace the cold water fill valve. If you get neither replace both fill valves.
Jun 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The machine won't sart. the code seems to be an L , followed by an F duet GHW9150POW the timer sounds to be running & cycle sset to cold/cold w/ only cold water hooked up. cycles briefly through...
If that is a new unit the hot water has to be hooked up as it will take in a small amount of hot water even on the cold cycle. whirlpool strarted this a while back due to energy use..try hot water let me know.....good luck.........
Jan 31, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Random brown stains in random loads of laundry
Hi from Australia
Ok the problem with your washing machine is that there is grease and oil stuck in the machine and the oil will dribble out when you run the machine on a different cycle if you rince with cold water then the oil stays in there and the hot water lets a little bit out as it is stuck in the pipes of your machine ok the first thing is run an empty load on full hot water even the rince cycle with 1 cup of bleach nothing else let that go through the long cycle then do the same again with 1 cup of white vinger and 1/2 cup citric acid which you should be able to get over there or baking soda try that it will clean your machine and your pipes it is great way to keep it all clean by the time you have done this you should not have any brown stains
Have a great weekend
Jan 22, 2010 | Kenmore HE2 Plus Front Load Washer
Whirlpool washer problem
it sounds like you cold inlet need replaced its a easy job
Jan 10, 2008 | Whirlpool AWM6100 Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
339 people viewed this question
Dan Webster
Dan Webster
Sal De
