Phillips 55pw9363 about 4 years old. picture not as bright ao as clear.
Remove the upper back and clean the three projector lenses with Windex and soft paper towel. You have dust build up. If there are smokers in the house then also windex the back side of the screen to get the nicotine film off. This cured my picture. I had lost fine detail and the picture looked like there was a white haze over it.
Posted on Jan 30, 2009
Picture shrinks on white areas
Is this a power supply problem? You bet. Also old age.
Jun 30, 2017 | Philips 27RF50S 27" TV
My tv is 8 years old and the picture is not as bright or clear as it used to be. Can the mirror be dusty?
No,the three CRTS tubes guns coolant chemicals are not as good as before,will causes this problems. Like old dull and hallow colors pictures?Tries websites like Tvrepairwold.com,Tvrepairkits.com to buy a kit to replacemt of it coolant chemicals of one or all three CRTS tube guns.The coolant chemical kit should came with a DVD tutoring how to do it too.
Jan 03, 2011 | Hitachi 57SWX20B 57" Rear Projection...
We just purchased a 55'' Phillips projection tv that is 7yrs old and the picture is horrible. It worked fine at their house. However it's like there is a bright light and the colors are horrible. We tried...
Sounds like the TV either failed or was thrown out of alignment during the trip to your place.
See if there is a reset button on the remote, or if there is a reset procedure for the television.
I hope you didn't pay too much for a 7 year old TV. Good luck.
Mar 02, 2009 | Televison & Video
36'' Admiral fuzzy picture model GOJ 12390
you'll have to take the back off the tv and on your right you'll see two black button on the flyback transformer one over the other the other the top button is for the focus you can bright or darken the image on your screen don't be afraid it will not bite as long as you don't touch nothing but the button with a phillips screwdriver and don't have the kids around when you are doing it
Jan 15, 2009 | Televison & Video
Clearer HDTV picture?
quite possible that the coolant is getting contaminated as thats a normal occurance with phillips after a few years. If the color seems dim and not focusing properly its almost certain that the CRT coolant will need changing
Dec 28, 2008 | Philips 55PW9363 55" Rear Projection...
I currently have a phillips 28pw9308, its just 3 years old, but i have a green screen with green lines across it, i hear the programmes clearly but no picture can u help please?
sounds like you have a shorted green gun in the CRT. It may also be the green drive transistor. Check the trans first, and if the trans is good you will need a new CRT
Mar 10, 2008 | Televison & Video
Picture is dim and blurry
The screen probably needs to be degaussed, which will require either a degausser or a technician. Try turning the television off, and then unplugging it from the wall outlet. Then replug after 30 seconds and turn it back on. Also, try plugging any cables from a cable or satellite box into another set of in-ports on the back. If the problem persists, the screen needs to be degaussed.
Feb 22, 2008 | Philips 51PW9303 51" Rear Projection...
JVC AV27320 Screen too dark
hi solution #2 was correct. the adjustment knobs r on what's called the "flyback" i adjusted the bottom knob and the difference was from "night to day" !!!
Oct 12, 2006 | JVC AV-27230 27" TV
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
