Question about ASUS Computers & Internet
Hi there, im having trouble with this motheboard, it seems to only have one slot for a ribbon cable, so how the hell do i plug my dvd drives into it
    Genius:
  • 2,785 Answers
Use master and slave combination(only one hard disk and one rom can be used)
Posted on Jul 21, 2008
D945gtp how to connect cd-rom hardware
1) IDE {PATA} DVD burner drive:
For an IDE { PATA } DVD burner, connect to the 40-pin IDE header on the motherboard. This is located to the right side of the Ram Memory slots.
It is the longer header that has 40 contact pins. {39 actually}
( The shorter connector on the motherboard is for a Floppy Drive.
{34 pins} It is above the IDE 40-pin connector )
NOTE*
The IDE connector on the motherboard should be keyed. Should have a cutout on one side. This is so the Number 1 pin in the flat IDE ribbon cable, will line up with Number 1 pin in the motherboard connector.
Some flat IDE ribbon cables, do not have a Locating Lug on the connector. (Small rectangular 'bump')
Number 1 pin on the IDE ribbon cable will be on the side that has a faint RED stripe on it.
Number 1 pin in the motherboard connector is at the Bottom, with the motherboard installed.
The side of the flat ribbon IDE cable that has the faint red stripe on it, goes DOWN, when installed in the motherboard connector.
If the DVD drive does not have a cutout for it's circuit board, the faint red stripe of the flat ribbon IDE cable, goes towards the power cable connection.
2) SATA DVD burner drive:
You have 4 Serial ATA headers (Connectors) on the motherboard.
Your SATA harddrive should be plugged into the SATA1 header.
You can choose any open available SATA header, to plug your SATA DVD burner drive into.
BIOS will see it once you turn the computer on.
3) If you somehow have been using an IDE {PATA} harddrive, and have it connected to your IDE connector on the motherboard, you SHOULD not use a DVD drive on that flat IDE ribbon cable, also.
BIOS has to find which device has the Operating System on it, (Windows), and then hand the computer over to the Operating System.
To state again, BIOS will look at both devices connected to that flat ribbon cable. The Harddrive, and the DVD drive.
It will then determine that the Harddrive, is the device that has Windows on it, not the DVD drive.
This slows the computer down, and could result in a blue screen.
If you have an IDE harddrive plugged into the motherboard, it would be best to use a SATA DVD drive.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 28, 2012 | Intel D945GTP Motherboard
I would like to install a lightscribe drive , can it be put into the hot swop carrier space witch i don't use
Yes you can add the lightscribe drive to your system as long as you have an open pay (slot) to hold it. If you have a desktop tower, then most likely you have a slot available either right under or above the current dvd/cd drive.
Just make sure your lightscribe drive has the same interface (SATA or IDE) as your current drive or you might need some cable adapters to make it work.
If your system uses IDE (little metal prongs or pins where the cable plugs into the back of the dvd/cd drive) then you want to set the jumper pin on the back of the dvd drive to CS for cable select. If there is a cable ribbon going to the current drive it will have another connection open that you can use for the new drive. Normally the cable ribbon will allow you to piggy back the two drives.
SATA is the latest technology so if your current drive is SATA, and your lightscribe is SATA then look at the two cables that go into the dvd drive already installed. There might be another set that is not being used that you can hook to the lightscribe drive. If so, hook the set to the back of the drive and into the slots on the motherboard.
May 18, 2012 | Acer Aspire M3400 PC Desktop
Hi i bought WD 320 gb sata /8mb hard drive - the cable ribbon on my dell 4600 does not plug into it! do i need a different cable yes
Generally speaking, we have two types of hard disk interface. IDE (the old one with ribbon cable) and SATA (with a 1cm strip like cable).
As your new hard disk is SATA, you need a SATA cable to connect it to you PC.
Below are a few images which would help you.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 23, 2011 | Western Digital WD Caviar Blue WD3200AAJS...
Hi . I have trouble with Dell optiplex GX280 . In the PATA I have two devices . DVD and HD . Both set with jumper . DVD as Slave and HDD as Master ....But the install os cannot detect HDD . where is...
I don't know where the trouble is without more information.
Some tips/information I will list, however,
1) The master harddrive that came with the computer, and has the operating system on it, is a SATA unit.
Therefore any harddrive installed along with it has to be installed as a Slave drive.
BIOS will look for the harddrive with the operating system on it. This harddrive has to be set as a Master drive. (Primary Drive in BIOS)
Installing a harddrive that is a PATA (IDE) unit, AND a PATA optical drive on the same flat ribbon cable, has to be done accordingly;
A) It depends on what flat ribbon cable you have.
There is a 40 wire cable with a 40 pin connector. (39 actually. One socket hole is not used)
There is an 80 wire cable with a 40 pin connector. (39 actually)
http://en.wikipedia.org/wiki/File:ATA_cables.jpg
http://en.wikipedia.org/wiki/Parallel_ATA#IDE_and_ATA-1
Proper method of connecting,
http://www.mikeshardware.com/howtos/howto_connect_ide_hd.html
2) Proper method of using jumpers on an IDE (PATA) harddrive, and connecting the flat ribbon cable,
http://www.youtube.com/watch?v=4inX3nC6M1E
Regards,
joecoolvette
Jun 05, 2011 | Dell Optiplex GX280 (99301) Motherboard
New DVD
Say what drive model you are replacing. The  IDE interface ribbon cable is a broad PATA cable that plugs into the the slot at rear of the drive ,its the only place it can go .IF your cable is a narrow one you need a drive with a SATA cable.
Regards Bill
Mar 09, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Two CDROM be connected in this Motheboard
Yes, this appears to be a standard motherboard with two IDE channels. Two CD-Rom drives can be connected on the same ribbon cable, and with set their jumpers to cable select or one to master and the other to secondary.
Mar 01, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Issue Installing 4th Drive Device (2 DVD Drives and 2 Harddrives)
You cannot plug an IDE ribbon in the floppy slot (port). The total IDE drives you can install is four (4). But check your jumper configuration. The DVD & DVD/CD-ROM cannot have the same jumper configuration to share the same IDE slot. One has to be MASTER (MS) and the other SLAVE (SL). Or you may put both drives on CABLE SELECT (CS).
Apr 21, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
How do i install a second writable disk drive???
aloha...this can be done, IF your computer has the expansion capacity. what kind of computer are you using?
Mar 17, 2008 | AOpen : CDRW 52x32x52 Beige Color Retail...
Installing hard drive on this model
Sure why not.
You,ll need a ribbon cable also 40 or 80 strand IDE Cable. to connect from hard-drive to Motherboard. If you have an existing connector already in. this should be In IDE 1 Or Primary slot ( on motherboard ) there should also be a secondary IDE Slot.
connect ribbon to IDE 2 Or secondary slot, and to hard-drive.
ensure the jumper on the hard-drive is set to Slave Or Master, if your running another device from that same cable, set to Master/Slave alternate to hard Drive.
Good luck and go for It.
Power Off first.
Motherboards are,nt too happy about Static.
Mike @ compurepair.
Feb 21, 2008 | Telex 4-52NH SpinWise CD Duplicator, Four...
DVD writer, master drive
If you have both the DVD and CD drives connected to the same ribbon cable you want one set to Master and the other to Slave, or both set to CS (cable select). Good luck.
Nov 10, 2007 | Computers & Internet
Computers & Internet Logo
64 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
