Question about Kitchen Ranges
GE Oven does not light - no gas smell and no electronic ignition clicking sound
It worked fine one day and then it just didn't work at all. The stovetop burners work fine.
There is no sound of anything happening at all when started.
Gas oven does not work. Burners and broiler work. When oven knob is turned on, there is no glow at ignitor, nor any gas smell. Because there is no gas smell when it is turned on for 5 minutes, does that mean the control valve needs to be replaced vs the ignitor?
Thanks.
  • 1 more comment
  • 21catbird Dec 13, 2008
    I have precisely the same problem--the oven won't light but the burners and broiler are fine (Model JGBP28WEKWW). It worked last night, but not this morning. Was your oven successfully repaired?
  • azalea75 Mar 03, 2009
    The answer to my July 21 question was to install a new oven ignitor. It has been working fine ever since!
  • azalea75 May 11, 2010
    Am still working on determining which component is bad. Another website provided a free methodic route to take (using a multi-meter to measure ohms/voltage) in order to find out if it is an ignitor, valve, thermostat. Thanks for checking.
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Posted on Mar 02, 2009
I have a GE Hotpoint stove/range model num 317B6641P001 that the oven will not ignite nor will the igniter turn on.
It sounds like the ignitor is bad...you will not or should not smell gas if ignitor is bad...gas valve is not supposed to open until the sensor by the ignitor has reached a certain temp. It's a safety feature. If you replace the ignitor, it should work like normal.
Jan 31, 2013 | GE Profile JGSP44 Dual Fuel (Electric and...
I had problem with the GE Profile Spectra JGBP90 Gas Kitchen Range try to turn the stoe on , clicking noice but no flame. smell lots of gas. how can I light the pilot light back, where is it?
This range doesn't have a pilot,it has an electronic igniter. If you are smelling gas while trying to light, your igniter is bad and needs to be replaced. Remove the racks from the oven. Remove bottom panel in the oven. Remove the metal plate that covers the flame spreader. The igniter will now be visible. Try turning on the oven again. Take note of how bright the igniter gets. If it stays a orangish color it needs to be replaced. It needs to get to an almost bright white,
Feb 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE TrueTemp XL44 oven. All four of the burners are not working. The electronic ignition clicks and the gas is on (because I can smell it) but no flame is created. Any ideas? The oven itself on the...
Hi, To complete the circuit for the electronic ignition the 3 screwheads under the aluminum burner need to be really clean. The same goes for the 3 posts on the bottom of the aluminum burner. They touch to apply grounding for the ignition spark. GL!
Dec 19, 2010 | Kitchen Ranges
My ge xl44 oven will not turn on. There is no gas smell or sounds coming from oven. Burners are working fine. Any suggestions?
I have the same problem. Worked fine last night - now nothing from the stove but the top works fine.
Nov 15, 2010 | GE Kitchen Appliances - Others
My gas oven is not working-just used this afternoon for bread and chicken-it was fine-broiler and burners work ok
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 29, 2010 | GE Ovens
GE XL44 gas oven
hi thanks for the question just because the igniter lights up doesn't mean its good, the gas will not light, if igniter isn,t hot enough. and a very common problem is that the igniter does come on, but not hot enough to ignite the gas . replace the igniter thanks the appliance doc
Jun 25, 2008 | GE JGRP17 Gas Single Oven
Ge jgbs22 the oven will not work
yep id say your on the money take the racks out then the two screws in the oven pan then remove the pan remove the flame spreader and at the back of the burner bar is the ignighter replace it
Mar 31, 2008 | GE JGBS22 Gas Kitchen Range
It probably needs an oven igniter. Remove oven racks. Remove oven floor. Usually 2 screws towards back. Remove flame spreader if it has one. You can see long tube with holes in sides and igniter with 2 wires from rear. Now try oven. See if igniter glows. If it does but doesn't light within 1 minute, replace igniter.
If it doesn't glow, you need to check for power to igniter. Should be about 100 volts. If not may need ERC, "Electronic Range Control".
Nov 19, 2007 | GE JGRP17 Gas Single Oven
Kitchen Ranges Logo
1,365 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
