Question about Jenn-Air JCD2389G Side by Side Refrigerator
Change filter light
The change filter light will not go off despite othe fact that I have replaced the filter. I followed the directions in the manual to no avail. What must I do to correct this?
Press and hold the lock and light button for about 3 seconds. the filter light should blink, then release the buttons and the filter light should go off.
Posted on Aug 24, 2008
    Scholar:
  • 165 Answers
The light goes off only upon reset. the instruction calls for pushing and holding two of the buttons in, together, until the light goes off. it should work
Posted on Jul 21, 2008
We have a 4 person heritage spa with ozone and we have 3 lights flashing ..what could this be? Cannot find my manual
ozone not flowing could be related check recirculation pump and pressure switch and heating element
Oct 09, 2017 | Heritage Pool & Spa
Can,t seem to find the fuel filter
the filter is under the car . there should be a plastic clip on one side and a screw in connection on the othe. 5/8 and 3/4 wrenches needed. First off pull the fuel pump fuse and start the car when it dies, keep trying to start it till it wont attempt to run this relieves fuel pressure in the system then change the filter your tank does not need to be empty or full it doesn't matter. Dont forget when u r done to reinstall the fuse. Jack the vehicle up with stand support on the front of the engine. u will see the fuel filter under the vehicle, near the door on the right side. plastic clips are sqeezed and pulled out. remove clamp if exist. put filter on in the right direction. follow arrrow on filter.
Jun 27, 2011 | 2000 Buick Park Avenue
Am unable to start the mower despite new spark plug, new filter & fresh oil. Unfortunately I don't think I used all of last year's gas, although the mower acted like it was out of gas when I let run...
Do you have an in line fuel shut off that you turned off last year and forgot to turn on???
Try and remove the fuel line from the carb. If gas flows out you are getting fuel to the carb.If the above 2 items are ok the problem is in the carb..
I would try next to check for spark. Remove the spark plug and set it on the engine block or any metal. attempt to start , crank the engine . Is there spark?? If not and it is a lawn mower follow the spark plug wire back under the coverThe othe r end is connected to the coil/magneto Replace it . When replacing it ,you will have to gap the space between the coil and the flywheel. I use a business card.
If you have a tractor and no spark make sure the safety sw.s are working properly. Seat sw., brake/glutch sw?,deck sw. engage sw. be fore you change the coil/magneto.
On lawn mowers sometimes mice get in under the cover and nest. they will chew the spark plug/coil; wire.
Apr 15, 2011 | Garden
GE refrigirator problem
You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Refrigerators
Lamp replaced, sequence from Manual (p.49) for 2010+ hrs fails
Apparently, the above posted steps do work, but they are finicky. The manual suggests that you do the aforementioned steps with the remote - I had tried with the remote and when that did not work I tried directly on the controls on the unit itself. Neither had worked - after multiple attempts, hence the posting above. The solution was that the various steps need to be done speedily - when I previously did it I apparently did not press the sequence rapidly enough. Nothing in the manual suggests that this is the case (and in fact I thought I had previously followed the steps in rapid succession on at least one of the many times I had tried, but apparently not quickly enough). I never could get this rapid succession of steps to work with the remote (as the manual said I needed to), but I did ultimately get the rapid succession of steps to work when done directly to the unit itself. The first three steps need to be completed within approximately 1-1.5 seconds, the final push of the volume+ button did require 2 or more seconds before the process was recognized (and complete). Never did have a single FixYa party try to address my issue - perhaps you only really get responses from them when you pay for their monthly service.
Sep 23, 2009 | JVC DLA-HX1 Multimedia Projector
Jenn-Air "replace filter" light
each dispensor is a little different, but youll need to hold down a button(perhaps even a combonation of 2) for3 seconds to "reset " the filter indicator.
Mar 19, 2008 | Jenn-Air JSD2789GEW Side by Side...
Red light
Here is the link to the user manual; http://www.filterqueen.com/pdf/defender.pdf The red light indicates a filter needs replacing, see page 6 of the manual (page 9 of the pdf file) If filters have been replaced and the light still flashes, then the reset procedure (described on the same page) should work. If still flashing then there is a more serious, but probably fixable fault. Hope this helps - ask again if you need more info :)
Apr 13, 2007 | Filter Queen Defender Air Purifier
Jenn-Air JCD2389G Side by Side Refrigerator Logo
97 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
