Question about Magellan Crossover GPS
Magellan crossover Unit is less than a year old, and it won't turn on at all. It was working just fine last week, although it did have an episode out in the country where it tried to reroute every 15 seconds or so for at least 15 minutes, while the car was moving. Anyway, neither the car charger for several hours nor the AC indoor charger overnight have had any effect.
  • 1 more comment
  • jedunlap326 Jul 26, 2008
    My crossover won't turn on either. Just happened today. Was working great and fully charged. What gives?
  • Anonymous Oct 11, 2008
    same problem- won't turn on
  • Imhousin Oct 21, 2008
    I bought my crossover brand new in the box from a guy at a flee market type place. It was un opened I used it for a few weeks and now it will not turn on at all. Indoor charger wont have any effect nor the car charger. This sucks because I doubt I am covered by any type of warrenty since I did not get it from a dealer. I tried to reset it also.
    Help!
Had same problem found solution here: www.magellangps.com/support/askmaggie.asp which was to press the reset button on left side of unit - second up from bottom. (need to do it with a pen) Cheers Eagledawn
Posted on Feb 26, 2009
Why wont new alternator charge new battery on 68 dodge
Sounds like you may have a bad battery. How old is the battery?
Jun 08, 2014 | Mopar Performance 68-69-70 Mopar B-body...
I need to upgrade firmware on this unit
there are actually a few different updates for this gps..the link im going to give is for the north american model..if you have one other then the NA model, stop here and ost back to me.
first youll have to determine which update you need by going in the system setting and locate the firmware currently installed..if its lower then 1.68 install the 1.68 first and do not just jump to the 2.14 update as it will throw all kinds of fits and probably make it unusable ...choose the 2.14 update to install if you have the 1.68 version currently installed
updates and manuals the the NA crossover can be found and downloaded HERE
if you have any problem or i have confused you in anyway, please post back before you attempt this update.
you will have to register your crossover before Magellan will allow you to download the update.
follow the installation to the letter as described in the update..i recommend the unit be plugged in to the home charger although magellan says make sure the battery is full.
bill
May 13, 2010 | Magellan Crossover GPS
Unit will no longer turn on
MOST LKELY THE BATTERY HAS FAILED, THEY LAST ON AVERAGE 2 YEARS
Nov 11, 2009 | Magellan Crossover GPS
Unit will not turn on
Check for voltage at the end that plugs into the cradle. If no voltage there, check glass fuse inside end that plugs into car plug. If there is voltage at the cradle end and it still doesn't turn on then it's the cradle. The cradle fails over a short time inside the cradle plug. You can hard solder the cable end to the cradle circuit board, which is a delicate procedure which I have perfected but I am an electronics person. If you want to buy a new cradle it will fix your problem for turning on the gps but I recomend a cable tie on the cradle cable end to stop the strain on the connector so the new cradle connector will last a long time.
Jan 24, 2009 | Magellan RoadMate 700 GPS Receiver
Magellan maestro 3100 turns itself off
Try using the RESET button . Make sure the battery is holding its charge
Jan 20, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan repairs
I don't know what wire you are referring to, however, I just fixed one last week that was 1 year old, not taking a charge (not even to get the screen up at all). Went to batteries plus, ordered a battery for it (there are 4 screws in the back and then some plastic catches that are released with a thin screwdriver--I started on the top). The battery was $25 but the unit is no longer under warrenty and it cost $50 through Radio Shack for them to send it in to the company. Worked perfectly with new battery.
Aug 05, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Roadmate 800 has a white screen with no image
i opened the unit up, removed the covers and disconnected the ribbon that goes from the main board to the lcd screen, cleaned it and then reinstalled it. i then put the unit back together and it has been working fine for about 2 months. let me know if it works for you too!! good luck. dave
Jul 02, 2008 | Magellan RoadMate 800 GPS Receiver
Gps loading screen freezes
If Magellan touch screen, try turning unit on while holding bottom right corner of touch screen. This will reset the unit.
Jun 27, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan roadmate 300 wont stay on
It is the cigarette adapter, mine was doing the same thing until I bought a new adapter. When the old adapter plug to the GPS unit moved at all it would lose power.
Jan 13, 2008 | Magellan RoadMate 300 GPS Receiver
Magellan Crossover GPS Logo
165 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
