I have a P5WD2 Asus MoBo, manual says it has USB 2.0 but when I check my hardware I dont see any enhanced USB controller
OK, I downloaded the latest Intel Chip configuration utility, then rebooted and enabled USB 2.0 support in the Bios. This seemed to fix the problem as the Enhanced USB controller now shows up in my hardware.
Posted on Jul 22, 2008
I run the P5WD2 Premium WiFi/TV motherboard with windows 7 (SP1 build 7601) and the sound does not work. It has BIOS 0422. The only thing that seems to work is digital output, which I don't use. Disabeling...
Hey guys I have all motherboard drivers solutions and computer/laptop hardware and software solution so if you have any problem so plzz contact our help line no.09371409266 you get the best solution
Mar 07, 2011 | ASUS P5WD2 Premium Motherboard
I cannot install windows 7 on my p5vdc-mx motherboard, it keeps freezing on installation
Uodate the P5VDC-MX BIOS to version 0806. Download it from ASUS official site.
Aug 03, 2010 | ASUS P5VDC-MX Motherboard
Driver audio
You can download the drivers from ASUS WEB site. Select your model motherboard, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system.
Click on this link: -
http://usa.asus.com/index.aspx
Mar 25, 2010 | ASUS P5WD2 Motherboard
None of the USB hubs work (MB: P5NSLI)
The reboot did not locate new hardware?
Do they still make a usb card that will plug intio the PCI slot? If so way to go is just put one in. or new MoBo
Jul 27, 2009 | ASUS Motherboard, nForce 570 SLI, Core 2,...
First time building power hookups on mobo
the general guidline is that if your power supply has the extra cables and your mobo can support them, then plug them in... those extra 4 wires in your long power strip will normally be used for grounding, so that's a must. check your mobo manual to see the exact specs. ... as for raid, wiki it man.
Jul 17, 2009 | ASUS P5WD2 Premium Motherboard
ASUS P4SDX USB Ports not recognized as USB2 HS Ports
The message comes up when a USB 2 device is connected to a slower USB 1 or 1.1 port. It is only to advise you that the devise will operate faster on a USB 2 port. If your computer has only USB 1 or 1.1 ports, you will always see the message. You can buy and install a card with USB 2 ports and install it. It will come with the USB 2 drivers. Install the card and the drivers and then connect your USB 2 device to the new hardware and you should not see the message anymore.
Good luck, And let me know ho it works out for you.
~ Spoem
Mar 30, 2009 | ASUS P4SDX Motherboard
The system comments that this is not a usb 2 device
first thing is that message just means that your device will work at a reduced speed
second is that a high speed port or enhanced usb port is required to work it at enhanced speeds
to check if your usb port is enhanced goto : control panel / system properties / hardware tab / device mannager / then scroll down to usb controllers and see if it says enhanced next to your usb port if it does then you will need to get the updated usb driver for the enhanced speed
electech
Nov 23, 2008 | VIA Vectro VT6212 (A62124) Serial Adapter
PCIe card detection
I need to get mother board drivers of Asus p5wd2. Plz help out and tell me the site to download the same.
Oct 30, 2008 | ASUS P5WD2 Premium Motherboard
Asus p5pe-vm
"USB +5v" = VCC
"USB_P5-" = -D
"USB_P5+" = +D
"GND" = GND
May 15, 2008 | ASUS P5PE-VM Motherboard
Usb 2.0
Yes, your M2V board is USB 2.0 complaint.
How do know if your PC has USB 2.0?
You can identify whether your PC has Hi-Speed USB or relatively easy. Open control panel, open System. Click the Hardware tab & Click Device Manager.
Scroll down to Universal Serial Bus Controllers. Click the + sign to expand. There should be an "Enhanced" USB host controller present. Windows 98 systems may use a different name, because Hi-Speed USB drivers in this operating systems are not provided directly from Microsoft, (Windows ME, 2000 and XP)
get their drivers through (Windows Update). There should also be two "standard" version USB host controllers present as well. They are embedded in the USB chip which routes the differing
USB speeds accordingly without user intervention. nVidia (shows as "Standard" controller) & not enhanced but are still USB 2.0
You need to enter your bios. How to enter your bios?
When you turn on your Pc press the delete key every 2 or 3 seconds. Your system will load the bios. Use your manual & go to pg. 4-16 section 4.4.2. Make sure you have Enabled USB 1.1 & enable USB 2.0. Enable Legacy USB support & set USB 2.0 Controller Mode to HiSpeed. Bios EHCI Hand-off, set to Enable
Save & Exit your bios. When your system has finished loading run Windows Update. This will update your USB driver to 2.0
How fast is USB 2.0? USB 2.0 has a raw data rate at 480Mbps.
If you have more question just ask!
please vote...
Feb 12, 2008 | ASUS M2V Motherboard
Computers & Internet Logo
David Payne
David Payne
