Question about Karcher 2500 PSI Pressure Washer
Karcher K2.89 how do you get the soap to work
  • pajodi Jul 22, 2008
    This is how I feel about your premium assistance plan-- if I have to pay for you to answer my question -you either do not know the answer or your power washer is not worth the money we paid for it and if you can't stand behind your equipment then I don't need it and won't buy anything else made by you.
  • 92 Answers
Dear Pajodi,
I just came across your problem. I have just joined FIXYA, and solved various Karcher problems. First of all with all respect, the shop from where you bought the machine, must have told you all necessary instructions to operate your machine.
Now the soap always works on low pressure. So if you have a variable lance, turn it to low pressure. You can also remove the lance, and the soap will surely starts to work. With turbo lances, the soap system does not work. This concludes that the soap does not work when high pressure is used. Bigger machines do spray soap at high and low pressures. But these have regulating knobs, to swith off and on, the soap supply.
Regards,
MG.
Posted on Nov 19, 2008
Why doesn't soap come out of my Karcher 1750g gas pressure washer the soap will not come out thriugh the tube
The wand has a high and low pressure setting. When it is set to high pressure, no soap will come out. This is the way it is designed to work.
Feb 13, 2016 | Garden
Why is the machine not sispensing soap
Karcher pressure washers can only dispense soap when used at minimum pressure. Try low pressure wand.
Sep 01, 2014 | Karcher Garden
Why won't my Karcher k4.600 soap not work
is it plugged with dried soap? need to disolve in hot water..
Jun 30, 2014 | Garden
2600 PSI Pressure washer will not draw detergent up
I posted an answer to no soap on the Karcher Factory-Reconditioned 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR. Same machine I suppose, but use the black 65 l degree low pressure nozzle.
It's in the manual , I missed it and had a hell of a time trying to figure it out. If that doesn't work check the check valve on the pump(Where the soap hose is) , see if it's gummed up.
Be careful taking it off there's a spring and ball bearing in there.
Apr 09, 2013 | Karcher Garden
I have a karcher 3000psi 2.5GPM.Is not vaccum to bring the soap in the water line. Thank. Ed
Some soap injectors have an adjustment that must be turned to allow or increase the amount of soap that enters the line. To make it work, install the blace tip on the wand (black tip has a very large hole/nozzle). With the black tip installed there will be very little pressure in the discharge hose and soap will enter. If your machine does not have an adjustable injector you dont need to do anything for it to work. If soap does not enter, stop enging and turn off water. Remove the injector fitting and check for debris. There is uaually a spring and checkball (very simple design).
Oct 10, 2011 | Karcher G3025OH Pressure Washer
Cant get my soap dispenser hose working on my karcher winner 10, any suggestion?, lost my instructions manual so dont know weather i need to be doing anything for it!
If you have not yet found a solution, then here are some steps to take.
1. The soap dispenser only works on low pressure!!!!!!! So you have to REMOVE the high pressure Sprayer so that all you use is the Trigger Gun without the Extender.
2. Pull out the thin Plastic Hose with the filter attached in the end, and insert into your container of detergent.
It will only splatter the detergent over the area you want to clean, so you will then need to REATTACH the SPRAYER into the hand gun to work with the soap to lather, clean and spray of till clean.
This seems to be the way the system works on this model......also known as K2.36M (AU) in Australia or (EU) in Europe on the Karcher.com.au site then Service then Manuals. or on the link below.
Hope this helps any of you who has misplaced their Owners Manual just like I did and had a great problem trying to find a link as Karcher doesn't recognize the Model No: as Winner 10 or 11.
Cheers, Luke
Nov 19, 2010 | Karcher Vacuums
How to use soap dispenser on Karcher K2.87 power washer
Also, be sure the cap is turned to the direction that lets the soap in. It has a gradation on it and if it is turned all the way to the smallest (cap fully closed) very little soap will be injected into the stream.
Apr 18, 2010 | Karcher Garden
Karcher k3.91 how do i change from just water to soap
Twist the end of the nozzle or jet pipe until you get low pressure. This will **** the soap through
Aug 16, 2009 | Karcher PSI Electric Pressure Washer
On my karcher pressure washer, how do i get the soap to come out of the spray nozzle?
Two nozzels came with your washer one has a cone shaped head, the other one is blunt, attach the blunt one to the trigger. You will notice on the barrel of the nozzel it says "mix" turn the indicator line to "mix" and it should work. This is a very low pressure setting and is used to "apply" the soap only. You cannot despense soap in the hight pressure mode.
Apr 13, 2009 | Karcher K2.26 Electric Power Washer
Karcher G 2600 ph
Dear johnny_river,
In general there are many causes why soap is not sucked. In a domestic and various other machines the soap is only sucked in low pressure. So one thing you can try is remove the nozzle or the complete lance from your gun. This will give a low pressure. If you attach a pipe directly to the machine soap inlet, and soap is not sucked, than the soap valve is "stuck closed" with soap. It is important that one must work with fresh water after using soap. This to flash the system from any soap left. So in a few words attach a pipe directly to the nipple at the machine and use low pressure. Important , you do not have to use soap to test....use fresh water. If this works( which it should)...than service the flow control tap or change it altogether.
Regards,
fulltech.
Apr 09, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
905 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
