Question about Toshiba Satellite M65 Notebook
Vertical lines o my desktop
I have hp pavilion zd8000.Laptop is just 1 year old & still in excellent condition.I got the vertical lines problem.My screen is full of colour lining from top to bottom as I start the laptop & it remains permanent..Though the laptop works fine.I can see my desktop and i can work on it but the coloured lines remains permanently.so what can i do to remove the lines from my desktop. A thin blue line appeared yesterday about a fourth from the left top to bottom on my screen. Is there a way to delete it? Thank you. Jean
  • dvdmalagon Oct 05, 2008
    TOSHIBA LAPTOP plasma screen COLOUR RAYS from the bottom to the top cyan, magenta and yellow vertical rays from the bottom to the top of the plasma screen appears and increase number along the display.
    If you solved this, please help me.
  • 408 Answers
Sounds like your video inverter is bad or possibly the screen is going bad
Posted on Jul 31, 2009
Vertical lines in hp zd8000
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical line. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Sep 26, 2010 | HP Pavilion zd8000 Notebook
I have a sony VGN-AR41M laptop is just 2 years old & still in excellent condition. i got a vertical lines problem.My screen is full of colour lining from top to bottom as i start the laptop and...
Move the screen around while on, do the lines disappear when you hold it in certain positions? If so, your LCD needs to be replace. If the lines don't disappear when bending the screen, it could be a broken motherboard as well. Youcan try to open the laptop and check the dc connection. There is a Laptop Repair Guide that shows you how to take apart a laptop, the sony may be made in a similar way. Sony Repair NYC
Jan 10, 2010 | HP Pavilion zd8000 Notebook
Vertical lines have appeared on my hp pavilion zd8000 can u tell me how to fix it please?
Connect an external monitor to your laptop. If the problem appears only on the display of the laptop and not on the external monitor in the same time that means the video card is ok and the problem could be : the screen of the laptop or the invertor or the cable that attaches the screen to the mptherboard. If the problem appears on both screens, external and laptop, most probably the video card/motherboard is defective.
Have it checked/repaired by a professional.
Oct 08, 2009 | HP Pavilion zd8000 Notebook
White vertical line on monitor screen
The vertical line is because the screen is going, it needs to be replaced fix the problem. Try searching on Ebay if your laptop isn't under warranty.
Aug 30, 2009 | HP Pavilion zd8000 Notebook
Same problem with my zd8000 HP Pavilion laptop
what has happened with your notebook is a simple wear factor. on the LCD screen there are ribbon cables witch join the main PCB controller head to the LCD laminated portion (what you see) have begun to wear. i have just recently replaced a screen because of the same issue. try gently flexing the the screen and see if the lines dissappear. next open the screen up, and check the cable running to the back of the screen take care as to not damage anything.
Aug 12, 2009 | HP Pavilion zd8000 Notebook
HP Pavilion Laptop - vertical lines on screen from top to bottom
this will more than likely be a video card issue. The bad news, on laptops, everything is integrated into the motherboard and and you will have to replace. Getting to the motherboard can be a pain.
Aug 06, 2009 | HP Pavilion zd8000 Notebook
ZD8000 pAVILION where is video card, can it be replace
You can not replace the video card in a laptop, it may not even be a card, but a chip. You will have to replace the motherboard in the laptop or replace the laptop.
Dec 09, 2008 | HP Pavilion zd8000 Notebook
uninstall video driver reboot it should start on windows basic video drivers if it does and screen is good try reinstalling your original card drivers. or search on the net for updated ones
Jul 20, 2008 | Sis 6326, (4 MB) Graphic Card
HP Pavilion ZD8000 vertical lines issue
In answer to your question. It may be a screen problem. as the screen has a Matrix of vertical and horizontal line configuration.
I,d suggest trying the laptop/computer on an external monitor or screen. if it works fine on an external. then it could be assumed that the TFT Panel or invertor has a fault.
if the picture/display still has vertical lines on an external monitor, then the fault may lie, with the Mainboard.
Process of elimination, before spending any Money :)
Mike @ compurepair.
Jun 09, 2008 | HP Pavilion zd8000 Notebook
Toshiba Satellite M65 Notebook Logo
658 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
