Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Will not power up
Self test blinks 19, why is it so difficult to get RCA to tell me what my tv is trying to tell me, from what I'm readin it's maybe the flyback, any suggestions will be appreciated
  • RCA Master
  • 8,617 Answers
The flyback error is usally the power led will blink three times when power is pressed then go out. does your set do that when the power is pressed one time?
Posted on Jul 22, 2008
Started blinking and the red light blinking now and no tv screen when i turn on just blinking red power light
The blinking light is a self-test diagnostic. If you can tell me how many times it blinks in between each pause and what is the make/model of the tv, I can tell you whats the source of the problem.
Mar 27, 2011 | Televison & Video
The power light cuts right off and the television does not come on the power light just blinks then cut off
Count the number of "blink" and then google your make and model. At the end add "blink codes". The number and sequence of the blinks is a self diagnosis for your tv and will tell you what the problem is.
Jan 25, 2011 | RCA HD52W59 HDTV Projection Television
Tv turns itself off
do the self test the set has.
when green light (power) comes on and then goes off, press and hold BOTH the Menu and Input buttons for at least 5 seconds and release both buttons on the front of the set.
The power light will display a error code: for example 2 blinks, a pause and 2 blinks (this is the most common one) and it will repeat the code about 5 times.
To get it to repeat it you have to unplug set, plug it back in and turn it one and when it fails repeat the check.
Let me know what error code you find and I will tell you what may be wrong. I hope it is 2,2 as it is the least difficult to resolve.
SD TECH
Jun 16, 2010 | Mitsubishi WS-55809 55" Rear Projection...
My d52w20b rca tv will not turn on and if you hold down the power buton down the led flashes a code 19
All the ITC222 series will blink 19 if they have a no start situation regardless of the problem, Since the set wont power up the Main eprm cant communicate so it blinks 19 which means it cant identify the chassis. When you press the power to turn it on does the power light come on briefly then go out 3 times? Let me know and I will assist you with the problem. Also do you hear any sounds when the power is pressed?
Nov 27, 2009 | RCA D52W19 52" Rear Projection Television
Rca D52W19
I would try replacing CP150 , CP114 and also CP120 as those three capacitors have been known too fail which will prevent the set from powering up.
Jan 28, 2009 | RCA D52W19 52" Rear Projection Television
Remot not working for Sens TV/DVD 19''
Hi sifrid,
Program the RCA remote with the instructions below, this will tell us if the problem is with the remote or the tv.
  1. Turn tv on.
  2. Press and hold tv button on remote
  3. While holding tv button press and hold power(on/off) button, led light shold go off then back on after a coupke of seconds.
  4. Release both buttons.
  5. Aim remote at tv and press the power(on/off) button every 5 seconds until tv turns off.
  6. When tv turns off press the stop button at bottom of remote, that will lock in the code.
  7. Turn tv back on with remote and test all buttons.
Let me know if this helps and please rate this solution.
Lone99star
Jan 27, 2009 | Samsung Televison & Video
RCA F27650 32" TV Problem
Hello ddw7321,
This sounds like it could be a malfunction in the High Voltage section of the TV. The shutdown circuit is switching on and preventing the TV from turning on. This might be due to an excessive amount of current flow possibly caused by a shorted turn in the Integrated High Voltage Transformer (IHVT), or a shorted Horizontal Output Transistor (HOT). To test this you will have to unplug the TV set, and with a multimeter set to resistance, measure the resistance from the collector of the HOT to ground, If it reads 0 ohms then that is the problem (a shorted HOT). The next test which is of the IHVT is a little difficult because it requires removing the IHVT and doing a ring test. At this point I would like to suggest that you take the TV to a repair shop, because these next test might be difficult for someone who does not know electronics, and if you have no knowledge of electronics you may do more damage then good.
With that being said:
Remove the HV anode of the IHVT connected to the CRT by first using a large flathead screwdriver connected with a clip lead to the ground of the TV, by sliding the screwdriver under the rubber cap and releasing the clips. Then unsolder the pins on the bottom of the IHVT using a soldering iron and a suction type desoldering pump. when the solder is removed , pull the IHVT from the circuit board. locating the main primary winding connect it to the device that you are using to perform your ring test (I use a Sencore LC-102), when it is connected do the ring test and it should have at least 10 rings to be considered good, any less then 10 and the IHVT is to be considered as bad.
I hope this helps.
Thank you,
Shuttle83
Oct 04, 2008 | RCA F27650 27" TV
Power button blinks 3 times
You need to replace the flyback, and that will fix your set. You can get a replacment flyback at the following link and they will provide free online instant messaging when you do the repair so they can take you through the replacement step by step. You need flyback number 259296 heres the link.
http://servicemanuals.vstore.ca/
Aug 08, 2008 | RCA D52W19 52" Rear Projection Television
19, signal 19, 19, what is it trying to tell me?????
The only error code 19 for the ITC222 chassis listed from RCA/Thomson for 19 is invalid chassis detected. Which doesnt make sense unless you have replaced a PCB with a wrong part number.
Jul 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV won't turn on
your dog sitting on the remote is unlikely to cause the problem, it is a coincidence. You need a television engineer to diagnose and fix the set.
Thread RCA TV power light flashes on off on off
RCA television blink codes Google Search
Nov 06, 2017 | RCA T19060GY 19 in. Combo
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
