Question about M-Audio Audiophile 192 Sound Card
Low volume does the card require a amp.. coz the sound levels coming in are so low..
  • 476 Answers
Assuming you are running XP.
uninstall and reboot then restart
device should autofind and self install
Let me know how it goes thanks
Please rate me ,,,Cheers
Posted on Jul 24, 2008
Why will Amp not produce sound unless the input and output are patched together
A typical stereo receiver / amp consists of switching low level input signals (CD, DVD, Phono, DAT, etc.), processing them and then output to the amplifier (low level) input for amplification to levels needed to drive speakers. The low level signals would barely be audible via an earphone, so they need to be boosted significantly in order to drive speakers.
Some amps provide jumpers to insert into the phono jacks on the rear of the amp to bridge the processed low level output signals into the low level amplifier input. You could install a Y cable here to feed two amplifiers - or - connect a tape recorder's "REC L+R" to the low level output and the "PLAY L+R" to the low level amp input so that you'd hear the actual audio as it had been recorded on the tape.
If you remove the jumpers (or tape recorder if used instead), there is no way for the low level audio to get into the amp's low level inputs for amplification.
Feb 24, 2015 | Audio Players & Recorders
When playing low notes on my guitar, I'm getting sub harmonics while playing clean on my Delta Blues 210. (sounds like a detuned bass playing along with me.)
That unit has a digital reverb and tremolo that can not be turned OFF with your foot control, meaning this small sound card is always on. Even though that level is on "0", it is still always on. If it has a problem within it, it will put noises into your sound. I would recommend opening the amp, look for the power to the effects card and unplug it to see if it goes away. It should be a small card resembling a sound card from a computer mounted off to the side. It should have a red and a black wire plugged into it. Wiggle it and listen for a change, dirty connections on that plug could do that. Unplug it completely and listen. This would only remove the possible interference of the card, you would still have sound without effects. Regardless of the brand, those cheap effects cards are usually more trouble than they are worth. They only have a few samples of effects, not the actual effect. I hope this helps, I know it is a great sounding amp but, those effects cards are the weakness of amps today.
Mar 28, 2014 | Peavey Music
Music volume low when digitizing vinyls
The software itself should come with an sound imput level control. But if you can't find it or it's on full then there are ways round it. However it depends on how the turntable is connected to your computer. Most turntables require in an amp to have a magnetic cartridge pre-amp to boost the level to that say of a tape. Rather than mess around sometimes it's better to get one of these pre-amps and have that between the turntable and the computer. Then the sound should be the same level as a tape signal. You will have to bypass that pre-amp if you are recording anything else such as tapes to your computer. Or you will get a noisy loud signal!
Just search for a "magnetic cartridge pre-amp" on the web.
Jan 31, 2014 | Music Hall USB-1 - turntable
Woofer sound distorted
What audio source you put into your Amp? you can lower the source volume also the amp volume to confirm, where the problem come.
Source input is also important whether you using low level or hi level input.
Nov 18, 2012 | Acoustic Research P315 HO Speaker
Inspiron E1505 Sound levels are very low and distorted. Can the sound card be replaced? How do I determine wether it is a hardware,software, or cpu issue?
if the sound is very low & distorted, then that is a hardware sound issue. Sound card can be replaced by calling your pc provider. CPU issues can occur if you experience slow pc performance. If there are error messages coming from windows, that is a software issue.
Oct 30, 2011 | Dell Inspiron E1505 Notebook
Volume at 10 produces very low speaker output.!?
It sounds to me that all you are getting is the pre-amp stage of the amp and nothing from the power amp stage. As it is on both channels then it is something that is common to both. This could be something to do with the power supply of the power stage. Or whatever is on the heatsink. It could be that the amp uses a single audio amp IC for both channels. If it does my bet is that it's gone. If it uses two sets of semiconductors for the right & left channel it would be highly unlikely that both channels have gone, but not impossible.
Dec 27, 2009 | Audio Players & Recorders
In my system the sound is low i am fixed 5.1 sub woofer intex.
so like you mention your problem that you have problem with speaker sound problem so i tell you sir that you better search for a good sound card that could match your cheapset there are now day's different sort's of sound card available in the market depend on your use & need requirement most of them do complain this issue b'cause the sound card which come on the chip set does not support 5.1 channel surround system so better consult to a well known hardware engineer for this computer issue untill then have happy computing & see you soon sir...!
May 24, 2009 | Audio Players & Recorders
No sound ...
Go into global settings, choose the MIDI settings and make sure the very first box is checked. I lost my sound and had a similar problem and just did some troubleshooting and once I clicked that box, my sound returned. Hope this helps.
Sep 14, 2008 | Alesis Fusion 8HD Sound Card
Shooting Speed Dropped
You can perform a Low Level Format of a memory card with this camera. Select Low Level Format under the following circumstances: - The continuous shooting speed has dropped. - The read/write speed of a memory card has dropped. If you perform a Low Level Format, the read/write speed of the memory card may recover, or the continuous shooting speed may improve. A Low Level Format may require 2 to 3 minutes with some memory cards.
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
M-Audio Audiophile 192 Sound Card Logo
114 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
