Question about Compaq CV 7500 17" CRT Monitor
Computer Monitor Problem or anything else
Compaq Monitor: earlier there was no problem, but now-a-days when I turn it on (I have UPS connection also) the screen brightness increases gradually and after some time it becomes completely white, I can't see anything. Initially when the problem started I found that after some time it was normal- but, suddenly it flashes light with full brightness and I have to stop working. Now it is completely white from the begining when I turn it on.
Is this problem can be solved at home? please tell.
I have a multimeter(digital), continuity tester and other tools for my different purposes.
  • 37 Answers
Contrast and brightness controls usually come from one chip. You can try looking up the specs of the chip online and then determine which pin of the chip conrols brightness. Usually faulty Electrolytic capacitors act like the simptoms you described. Find the Electrolytic capacitor connect in the brightness circuit and you will most likly fix your problem. The chip that contols the brightness might also be faulty. Good luck.
NSSMS
Posted on Jul 21, 2008
Problem in Samtron 45Bn Monitor
Try connecting the monitor to the mains instead of the UPS.
If it works OK then the problem maybe the UPS and that it is very close to the max output of the UPS.
If not then the monitor is faulty.
Mar 12, 2013 | Computers & Internet
Powering down
your not very clear but here is what I'm assuming your saying.
Pins 5 & 6 - Any-Mode Shutdown
1. Pin 6 of the 9-pin communication connector is used for "Any-Mode Shutdown"
of the UPS output. This control input may be used in special applications
to disable the UPS output power-both Inverter and Bypass.
2. The Options tab allows the behavior of the Any-Mode Shutdown feature to
be modified. When the program opens, or the REFRESH button is pressed,
the UPS setting is read by the configuration program and displayed.
Auto-Enable Output
Pin 6 Logic
If version 1.6 (or later) is used with an earlier Liebert GXT2U model (with an
earlier UPS firmware version), the Any-Mode Shutdown features cannot be
changed.
If the configuration program is used with an earlier UPS model (with an
earlier UPS firmware version) that does not support the modification of these
settings, the Options tab will display a reminder of the factory default
settings. These cannot be changed.
! WARNING
Note that when this option is selected and the UPS output is
disabled using Pin 6, the UPS output can turn on automatically
and without warning if the Pin 6 connection is changed.
! WARNING
DO NOT CHANGE THIS OPTION from the factory default
setting unless you are ready to install a normally-closed
connection between Pins 5 & 6. This connection must be
maintained to use the UPS or to use the configuration program
again, including the ability to change the UPS setting back to the
default setting using the configuration
Sep 05, 2011 | Liebert GXT2-10000R230 (GXT2-10000R230)...
Problem for LG 22" FLATRON Widescreen LCD Monitor LCD Monitor My monitor says analog power save and shuts off. Day before Yesterday I bought a new computer. I got the above mention problem on by...
The monitor is going itself to the Power Saver mode.It is not a problem of the monitor.This happens when there is no signal on the monitor.The monitor will display properly when there is an output signal on it.Please connect it to the computer and check that the output signals from the motherboard are proper.Also check both DVI (Digital Visual Interface) and VGA (Video Graphics Array)cables on the monitor.
Feb 23, 2010 | LG 22" FLATRON LCD Monitor
Samsung Syncmaster 760V TFT monitor & LED is blinking on and off!
put the monitor upside down till it comes on works for me anyway
Sep 07, 2009 | Samsung SyncMaster 760vTFT Monitor
When i turn the computer on it just beeps. its a long beep and there is nothing on the monitor
Chek the connection points of the monitor - ups. dirt must has accumulated. consult a authorized person.
Aug 11, 2009 | HP Compaq Presario SR1603WM (ED861AA) PC...
Display fails after a couple of seconds
Connecting a different computer that works to it doesn't fix the problem(what does that mean, its not CLEAR at all)
my guess is you meant the new PC fails on this bad monitor , too.
ok the monitor fails on PC #2, sure....
so the monitor is bad, why ask for help, buy a new monitor.
why spend $100 to fix it when new is %50
why>?
your not going to fix any monitor, here, on fixya,
but there is one thing to check the very old monitors from compaq
ive answered this 4 times here now.
has menu botton
see that? push that now on the monitor
see that menu..
? one menu selection , has silly horrible, power saver timer on it
and a RTC clock that keeps time of day, (pc can be OFF)
if the power saver is on , get it off now, and if paranoid set the clock.
id set it. so its double safe, see?
this happened back in 2002.
i read you users guide for you its a 2001. oops, its got the above BS.
read page 18 and all related pages to this. clock and saver.
page 18 there, page 16 real.
if it one , the INANE thing will go to saver at odd times.
later this was removed for VESA , update, remote sleep rules. and time.
https://www.manualslib.com/manual/30090/Compaq-Tft8030.html?page=18#manual
May 01, 2017 | Compaq TFT8020 (White) 18" LCD Monitor
Monitor goes to power save mode on startup
Sounds like a bad video card (if embeded "built in") then you need a new mother board
Dec 09, 2008 | Belkin (F6C800-UNV-PL) UPS System
Power supply for Compaq 1501 15" LCD Monitor
the connecter of monitor will not fit wrong way it can fit only right way so no possibility to damage the monitor
Oct 28, 2008 | HP Compaq 1501 15" LCD Monitor
Less then 5 minutes runtime at minimal load
You gave no reasons why you thought it was simply a software setting, so I gave you a link below for some management software. The HP R3000 UPS supports HP Power Management Software (CPM) version 1.8. http://h18004.www1.hp.com/products/servers/proliantstorage/power-protection/software/legacy-software.html In addition the HP R3000 UPS also supports the LanSafe III management software (discontinued). My first question is: When were the batteries last changed? If they haven't been changed in 3 or so years, then it's probably low batteries, meaning they are old and cannot take a charge anymore. ZT3000 Beta tester of "0"s and "1"s
Jul 26, 2007 | Compaq UPS R3000 (242705-001) UPS System
Compaq CV 7500 17" CRT Monitor Logo
93 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
