Question about Lowrance GlobalMap 3500C GPS Receiver
Lowrance will give me a mob position but will not set automatically for running positions stay 0
    Novelist:
  • 113 Answers
I would like to help but I'm not sure I understand the question.
Are you saying that when you push the zoom in and zoom ou key at the same time you get a correct position, but you can't see a box that gives your real time position?
Is your map page set to show data on the right side of the screen? If not, press the page key and select the map/data page. This should give you some information on the screen which includes your current position, updated every second.
If I missed the mark with this answer, please give me some more details so I can help.
Posted on Jul 21, 2008
What causes a/c to blows cold on driver's side and hot on passenger side ?
There is a little motor on the heater box under the dash that needs to be replaced. It's called a blend door actuator...
Mar 16, 2015 | 2004 Cadillac DeVille DHS
How do I set position on my lowrance hdi 7
The GPS will automatically triangulate your position and display it on the map screen.
If you have your cursor turned on the the map screen will remain centered on the cursor.
while on the map screen push the Menu key and then the Enter key. If you notice the pop up window when you push menu you will see the first field highlighted will be to return to current position or something similar. By pushing enter you are selecting this option and the unit will display your current position on the map screen.
Oct 17, 2014 | Lowrance Elite-7 HDI...
HDS Gens Touch shows positive red to negative & black to positive?
Lowrance may have goofed on the manual printing. RED is Positive, Black is negative. All these systems have reverse polarity protection. If you wire backwards, the screen will flash on and then automatically turn off.
I install these systems and I have always put the fuse hlder on the positive line at the battery. The fuse holders are always red wires and that may also lead to some confusion if they suggest attaching that to the black lead.
Hope this answers your question.
Jan 05, 2013 | Lowrance 000-10767-001 Hds-9M Gen2 Touch...
My circuit breaker won't stay in the on position. when you try to flip it to the on position it automatically goes back to the off position
either the circuit breaker is faulty or there is a fault in the circuit, this is something that would need to be checked by a professional
Mar 12, 2012 | Electrical Supplies
Automatic lights wont switch on
From manual:
Automatic operation
With the engine running, vehicles fitted with a light sensor, the dipped beam headlights light up automatically as light begins to
fade; stalk 1 does not need to be turned (position 0).
To deactivate or reactivate this function, move the end of stalk 1 twice consecutively from 0 to side light position, with the engine stopped and the ignition on.
A bleep confirms the deactivation of this function, and two bleeps confirm its reactivation.
Jun 20, 2009 | 1986 Renault Sport
I am unable to return to the 0 crown Position - TAG-CAF2112
The aquaracer has a 'screw-down' crown.  This means that the crown needs to be screwed in the reset it back to the 0 position.
Jan 09, 2009 | Tag Heuer Aquaracer CAF2112.BA0809 Wrist...
Tag wk 1113-0
The crown is probably a screw down style. The screw down stem is designed to keep the water out and should be screwed shut when not adjusting the watch. Look at the watch stem from the side, look from the 3 oclock to the 9 oclock, you should see the end of the stem. Now turn the stem counterclockwise. After a number of turns, the stem should pop out a bit, it is now ready to set. Most waterproof automatic day/date watches have 4 positions for the stem:
1: screwed down (locked)
2: unscrewed position A
3: unscrewed position B (stem pulled out to first "click")
4: unscrewed position C (stem pulled out all the way.)
Position A:
This is usually used to wind the watch, although some automatic watches cannot be wound by the stem.
Position B:
Used to set day/date. Turning the stem one direction will advance the day and turning it the other direction will advance the date.
Position C:
Used to set the time. Some watches will "hack," a term used to describe the ability to stop the second hand for accuracy purposes.
Be sure the watch is at least a little bit wound before starting theis procedure or it will not run when you get it set!
Unscrew the stem and pull it all the way out to position C. Now turn the stem to advance the time clockwise. Continue turning until the day/date advances, now you know you are in the AM 12 hrs of the day. It is important not to advance the day/date with the stem during the 3 hours before and the 3 hours after midnight, so go ahead and move the time to 8 am.
Now push the stem in sligthly until you are in position B. Sometimes it is easier to go to position A, the out to position B. Once in position B, advance the day/date until it is set for the current day/date.
Pull the stem out to position C. Adjust the time to one minute past the current time. Watch your reference timepiece until it matches your watch and push the stem in when they match.
Your watch is now set! Screw the crown down and wear it in good health.
Hacking. If you stop the second hand at 0 seconds, and wait for your reference timepiece to reach 0 seconds also, you can set the watch to within a second accuracy.
Movement slop. If you advance the time past the time you wish to set your watch and then "backup" to your chosen time, you will remove the slop from the geartrain and make your watch set more accuretly
Jul 14, 2008 | Tag Heuer 2000 Classic WK1113.BA0311 Wrist...
Lowrance GlobalMap 3500C GPS Receiver Logo
87 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
