Question about Pioneer CDX-P670 6-Disc CD Changer
Wirng colour code
What does the AsenB connect to is it the Acc 12v
  • wooly4228 Jul 21, 2008
    How do I send E-Mail address to you
  • 199 Answers
Www.blueice-electronics.co.uk goto the contact page and email me from there. :)
Mark
Posted on Jul 21, 2008
What is a 12v acc.
1.Wire name: ACC wire
Color: Red
Describtion of ACC wire:
When you insert key into ignition switch and turn it to the left you are turning on the ACC circuit. It will allow you to operate radio, windows and other accesories, but it does not turn on fuel pump and other engine controls. It saves battery power for when you need to operate vehicle components without engine being on.
The ACC wire offers power/electricity only when you insert car key into ignition switch and turn it to the left
The ACC wire needs to be connected to car igniton
2.Wire name: 12V battery(+)
Color: Yellow
Describtion of 12V battery(+) wire:
The 12V permanent battery wire will always offer power/electricity when the vehicle is turned on or off
The 12v permanent battery wire needs to be connected to car battery.
26291025-azrw0qmg4txhvnd4c3h3ocng-5-0.jpg https://electronicshelponline.blogspot.com/
Sep 25, 2016 | Car Audio & Video
Audi A3 8p what wires are what I'm wanting to fit a turbo timer there are 6 colours I just need the 3 12v constant ignition on 12v and the acc
use s volt meter. with the ignition off see what pins have 12 volts. turn the ignition on, see what additional pin has 12 volts. turn the ignition switch to accessory, see what additional pin had 12 volts.
should be pretty simple to figure out...
Aug 15, 2015 | Audi Cars & Trucks
Need a nissan sunny 1999 wiring diaram
A 1999 is old enough to have a Haynes manual. BUY it.
Feb 01, 2015 | Nissan Cars & Trucks
Skoda fabia 04 plate ive replaced after market stereo with the original skoda symphony one i put the code in and it works however everytime i restart the var it goes into safe mode
You may have the 'backup' supply line switched with the ACC/IGN supply line.Backup has permanent 12V supply. ACC line only have 12v after you turn the key to position 1 or ACC.
Jul 20, 2014 | Cars & Trucks
Centurion DVD player (WMM-5 CENDVD1) plays and then it shuts off it self after 30 seconds
This happens with mine if I only connect to the +12V and Ground pins. You must connect the ACC pin to +12V as well. The +12V is the permanent connection and the ACC is for the +12V that becomes energised when you turn the ignition on and have the engine running.
Jan 10, 2014 | Televison & Video
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
Wiring colours
Not sure of your setup re hedunit.
the plug from the old sterio should have the following:
Black- Earth
Red - ignition (only supplies 12v when key is in the ACC position.
Yellow green (12v all the time) even if key is in the off position)
you can check the speakers by using a 9v battery and QUICKLEY toutching the wires on the terminals to distinguish what two wires run to what speaker.
Then use the same sequance for wiring the headunit making sure thar all the solid colour wires are used as the positave connection for the individual speaker wires.
Dec 05, 2009 | Car Audio & Video
I wanna connect my amp, and i dont know which is the remote wire? where do i connect the blue wire to? i have a sony cdx-f7700. can anyone help or have a diagram
The blue wire, if you've not got a corresponding blue wire to connect to can be connected to the ignition wire. That being one of three needed to power your head unit - RED (12v permanent), BLACK (negative / earth) and another colour, sometimes blue for 12v ignition (only comes on with the ignition on / acc).
Aug 20, 2009 | Car Audio & Video
Wirng colours ea ford radio
try the locu libbary they should have book on it
Jun 03, 2009 | Ford Futura Cars & Trucks
Radio wiring harness color codes for 2004 Jeep GC
This is for a 2002 cherokee:
RADIO 12V - red/white
RADIO GROUND - black
RADIO SWITCH - white/red
May 16, 2009 | Cherokee Car Audio & Video
Pioneer CDX-P670 6-Disc CD Changer Logo
212 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
