Question about Maytag Washing Machines
Occasionally clothes are catching on the agitator where the corkscrew is attached to the base. When I washed sheer curtains last week some of them caught and snagged. They are ruined. I can't feel anything protruding that would cause this.
    Scholar:
  • 154 Answers
Without a make and model it is hard to say but I would say there must be a small protrution or maybe a cut in the aggitator that is catching them feel around again slow and carefully if you still can't feel anything give the edges of the agitator a slight sand with some very fine sandpaper hopefully this will fix the problem. Make sure your agitator isn't loose on it's mount maybe they are catching under the agitator.
Posted on Jul 21, 2008
A407 maytag washer getting grease on clothes occassionaly what would the replacement part
Maytag washing machine gets grease on clothes ... - Fixya
www.fixya.com/.../t14582529-maytag_washing_machine_gets_grease
Oct 8, 2012 - Maytag washing machine gets grease on clothes occasionally. ... some of their clothes ruined by grease stains from their front loader Kenmore. .... remove the agitator from a Maytag washing machine Model A407 series 02?
Aug 24, 2015 | Maytag Washing Machines
Simpson esprit 550 agitator & spin not working properly.
Open the lid during the wash cycle and observe the agitation, you need to see exactly whats happening, If its corkscrewing instead of agitating it will wind the clothes as you described. Agitation is usually back and forth, or up and down etc, not just turning constantly in the same direction.
Aug 25, 2014 | Washing Machines
I have an older model (bought it about 15 years ago) top loading Kenmore washer. I noticed that the spindle that is part of the agitator doesn't move as much as it is supposed to. In fact, if you...
That sounds as if the parts called the agitator dogs are worn out and thats a pretty easy thing to replace the dogs and fairly inexpensive (the parts are less that $8.00) this tip i wrote explains how to replace the agaitator dogs. http://www1.fixya.com/support/r10294924-top_part_agatator_isnt_turning_top_load
GENE
Sep 18, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
The agitator tries to rotate, but instead jerks, but doesn't rotate in normal motion. It also makes a ratcheting snapping sound.
Does the lower half of the agitator still operate normally? (Back and forth) Can you spin the top half (spiraled part) of the agitator in both directions with out the lower half moving? If so then you have a worn set of agitator "dogs" they are little plastic ears located in the upper half of the agitator and catch the notched inner section of the agitator to make the top action work like a corkscrew, slipping one way and driving the other as the lower half goes back and forth.
To get at these parts you will need to remove the agitator, Remove fabric softener dispenser or cap on top, and look down inside tho opening.
You will need to remove the plastic cover inside that has two ears sticking up, pull on one side or the other and it should pop out, there will be a rubber seal around it so it will be a little difficult to remove.
Now you will have access to the bolt that holds the entire agitator in the machine. The agitator dogs are located right on the outer edge of the center cup that the bolt goes through. To access them you will want to seperate the two halves of the agitator and flip the top half upside down while holding your hand inside it to catch the cup with the dogs in it. Part number 80040, for the dogs.
Good luck to You!!
Jun 26, 2010 | Roper RAS8445KQ Top Load Washer
Several pieces of clothing stuck under agitator.
you can remove the agitator. there are 3 steps to this. 1.take off the top plastic part of the agitator. 2 remove secondary plastic piece from inside of agitator 3. there will be a 7/16 bolt inside and will be deep so you will need a long extension to reach it. hold the fins of the agitator and remove the bolt with a ratchet. once the bolt is out you will be able to lift the agitator up.
Jan 03, 2009 | Kenmore 22422 Top Load Washer
Agitator not spining properly to pull clothes down into water
remove agitator cap remove boplastic cover underneath remove bolt remove upper portion of agitator replace agitator dogs part # 80040
Jun 06, 2008 | Roper RAB2121KW Top Load Washer
I have a Maytag performer series machine,the main agitator is screwed down properly but the corkscrew agitatorthat is attachedto the main agitator completely cuts loose and floats to the top , i don"t...
With the Maytag Performa series, the auger is held by a pressure fit only - no screws. Mine failed after about 6 years. There is no (easy) way to repair this problem. The top auger does not stay attached to the post, and it floats off the post while washing... I ended up ordering a new one from the Sears 1-800 number. Easy to replace, and it comes with both the post and auger. Costs about $110, but certainly a lot cheaper than buying a new machine. The part does not come with the top cap for fabric softener, so be sure to save the old one. You do need a fairly long extension for your ratchet wrench to unscrew the attached bolt, but it is fairly easy to do.
May 30, 2008 | Maytag Washing Machines
Maytag SAV365ZAWW Agitator Comes Apart
The should be a bolt that goes thu the center that holds that down with the bottom part of the agiatator.. it might have pulled loose or rounded out the whole for the top part here is a link and a pic http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=3048&modelDesc=WASHER&modelNumber=SAV365ZAWW&documentID=M0512408&documentTypeID=PLDM&documentClassCode=PV&titleType=TUB%2C%20INNER%20%26%20OUTER%20%28SERIES%2012%29&titleID=00010&
Sep 19, 2007 | Maytag SAV365Z Top Load Washer
Agitator - is it working right?
there is slipping in the transmission. older machines used a pair of electrical solenoids to shift between spin and agitate. newer machines use the motor direction to engage the transmission for agitate and reverses for empty and spin. GE service phone: 1-800-848-7620
Sep 10, 2007 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
121 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
