Question about Ricoh Aficio 1515MF All-In-One Laser Printer
I HAVE CHANGED THE TONER CARTRIDGE AND THE SIGN TO ADD TONER IS STILL ON
I have changed the toner cartridge and the sign to add toner is still on.
Posted on Nov 24, 2008
3 Suggested Answers
SOURCE: Add toner message
CHANGE MOTOR TONER
Posted on Oct 30, 2007
yooperbud
  • 8637 Answers
SOURCE: Cl2000n Ricoh can't reset add toner cyan in display
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Sharp copier Mx 5000N is doing continuous toner replenishment I changed toner cartridge drum developer still replenishment what do I do
If the machine is still trying to add toner after the toner cartridge has been replaced & the developer is new then I would look at the toner supply motor for that particular colour. Also check for a blockage within the small tube between the toner cartridge & the developer unit. You could try swapping the toner supply motor with one of the other colour motors as they are all identical. If the fault switches to another colour then the motor is at fault.
You can also check the operation of the toner motor in simulation 10.
Hope this helps.
Dave.
Jan 09, 2017 | Sharp Office Equipment & Supplies
I changed the drum unit on my c5500 printer and didn't realize that I needed to replace the toner at the same time. I just replaced that toner about a month ago and now it's saying it's empty - which I...
Before you replace a drum unit, you should (with the top toner cartridge still in place) turn the unit upside down and gently shake the toner that is in the drum unit back into the toner cartridge. When you install toner on these printers, most of the toner falls into the drum unit. The only way you can "reset" the printer is to add more toner, because there is almost no toner in that new drum.
Oct 20, 2009 | OKI C5500n Printer
How do I add toner to machine? Also, is this copier do color copies?
1 Open the front cover and pull out the
drum unit and toner cartridge assembly.
2 Hold down the lock lever on the left and
pull the toner cartridge out of the drum
unit.
3 Unpack the new toner cartridge. Place
the used toner cartridge into the
aluminum bag and discard it according
to local regulations.
4 Gently rock the toner cartridge from side
to side five or six times to distribute the
toner evenly inside the cartridge.
5 Remove the protective cover.
6 Insert the new toner cartridge in the
drum unit until it clicks into place. If you
put it in properly, the lock lever will lift
automatically.
7 Clean the primary corona wire inside the
drum unit by gently sliding the blue tab
from right to left several times. Return
the blue tab to the Home position (▼)
before reinstalling the drum unit and
8 Install the drum unit and toner cartridge
assembly in the MFC.
9 Close the front cover.
If you need illustration for this, click on the link below and turn to page 112
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_7420_7820N_EN_1156.PDF
Jun 02, 2009 | Brother MFC-7820N All-In-One Laser Printer
Studio 230 added a new toner cartridge
When adding toner to the developer unit, it will load from the toner. So, if toner is empty, it will ask for replacement. Normally u can hear noise from the toner when loading.
Mar 19, 2009 | Office Equipment & Supplies
Printout getting fainter magicolor 2300dl
Probably low toner if fading is on black only or a single color. To check levels, MENU (right arrow to Consumable Usage) MENU (right arrow to see each toner cartridge level) Readout may not be accurate, especially if you have changed or removed a toner cartridge.
Dec 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Mar 19, 2008 | Ricoh Aficio CL2000 Laser Printer
Does not feed
please put the new toner cartridge,toner sign will go automatically
Sep 22, 2007 | Copystar CS-1510 Copier
Add toner message
have you tried another toner cartridge? eyo7 eyoifiok2005@yahoo.com
Mar 30, 2007 | Savin 9935DP Laser Printer
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
528 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
