Question about Akai LCT3201AD 32 in. LCD Television
Panel buttons and remote controls are both erratic
When malfunctioning, pressing any function such as volume, channel change etc. causes to go to basic blue screen showing the basic mode. Suspected heated related. Put out with hot sun on back of TV and controls begin to function after a while. LCT3201AD TV is 6 months old.
I read about power supply problems but this sounds limited to something else that decodes control commands. If this problem is in a module board, I can probably change it out but I have only a VOM for testing and no service manual. I have not disassembled the TV.
  • 10,594 Answers
Problem seems in panel board having bad switches. You probably need to replace the (control) panle board. Check out this Weblink having info for Akai TV parts.
Posted on Aug 10, 2008
I have a Humax LU23 TD2 television and have now got Sky tv. I would like to know how to use the Sky remote to control all the functions such as power on, volume etc. for the tv. Can you help...
Hello
These are the setup processes for Sky TV.
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 28, 2011 | Televison & Video
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
I have a sharp 52". the remote will adjust the volume but, i can't change the channel. Help? Out of nowhere I could no longer change the channel. The Mrs is getting tired of standing next to the tv so I...
Sometimes, if certain remote control keys are used over and over again the rubber on the bottom of the buttons wears off onto the inside contacts, breaking the electrical connection. This is common on power and channel keys, especially. If you can get the remote opened up, you can clean the contacts with a cloth and it might help. Otherwise, it may be worth buying a universal remote. Good luck! Der Strom
Apr 05, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Remote control code for Sanyo DP26648
remote is worn out cannot change volume, channel , check info etc most buttons have stopped functioning I need code to set up universal remote need it now.
Apr 12, 2009 | Sanyo DP26648-R 26 in. LCD TV
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
Channels keep changing
Make sure there is no other remote control working simultaneously or with a key pressed constantly by mistake. In my case i found the air conditioning remote control with one key being pressed by my furniture next to my bed, it was causing that erratic behavior. As soon i realized, i stopped that remote control and problem solved. I hope this works.
Nov 11, 2007 | Vizio L32 32 in. LCD HDTV
TV Won't Power Down; Change Channels; Change Volume; etc
sounds like maybe the remote contol is at fault.Do the front panel buttons work?
May 29, 2007 | Panasonic CT-32G9 32" TV
Erratic behavior...
Change all the little switches (on-off, channel up etc). If just one of the switches is intermettent, or a combination of one or more, it can cause you moe misery than you can imagine. The switches are not expensive but can cause you to lose an awfully lot of time and agravation.
Nov 24, 2006 | GE 31GT740 31" TV
Akai LCT3201AD 32 in. LCD Television Logo
117 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
