Question about Whirlpool LBR4132JQ Top Load Washer
Washing machine not draining
I have a kenmoor washing machine and lately i noticed that all the water has not been draining all the way. i have changed the drain hose, checked for any clogs in the other hoses. the motor does not make any noises. i can hear it spin just not draining completely.??
  • museworthy Feb 01, 2009
    Washer does not drain completely drain and clothes remain very damp when spin cycle is finished
    Scholar:
  • 154 Answers
If you are confident you can do it pull your pump off washing machine and pull the pump houseing apart most will come apart and make sure there is nothing in the pump maybe a small piece of plastic or other item in it. you could also try taking the hoses off the pump and just flush water through it backwards this will also sometimes work I have come across this a lot and normally it is something in the pump interupting the water flow. There may also be sand or small pebbles in the drain holes under the adgitator if flushing the pump doesn't help check under the adgitator for something in the holes. Hope this helps
Posted on Jul 21, 2008
Kenmoore 600 washing machine. Clothes comes out with brown spots.
Are you on a well, or town water supply? If machine needs cleaning you could try running a load with just water and a bottle of CLR it is a cleaner for calcium, lime and rust I think, if it smells after that of the cleaner run a load with white vinegar in it with the water. hope it helps, good luck
Jul 03, 2017 | Washing Machines
Kenmoore 800 washer doesn't do anything
Possible that the timer controller is faulty as it fails to switch or move in the cycle of the program
Use WD 40 to clean the switch, the knob can be replaced if this turns loose.
Jan 25, 2013 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Washing machine won't drain
I had a new washing machine in my garage(lucky me)
Aug 22, 2009 | Whirlpool Washing Machines
Kenmoore washing machine no longer spins during normal wash cycles
sounds like your spin cycle belt has come off or broken. it,s a simple fix at a repair shop.
May 02, 2009 | Washing Machines
Kenmoore model#417.4105200 dirt stains/ dirty water residue
this is a drain problem.inspect the water pump, motor coupler and the drain hose for kinks.
Dec 14, 2008 | Kenmore 44921 Front Load Washer
Water will not drain during spinning
look at the pump and make sure you have the arm in the slot or it will not switch over to drain the water out
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Describe your Maytag Neptune MAH5500B Front.loader...Creaks when washing
Hello saber396
welcome
Here are some facts that may be the sounds!
You said. you noticed lately that I hear a creaking sound when it is in the wash cycle...Is that a motor problem?
Clicking/draining sounds
when washer is started will be
before the washer starts to fill, it will make a series of clicking noises to
check the door lock and do a quick drain.
Could it be a rapid snapping and/or
popping sound from the rear
of the washer during spin.
means that
Water is being extracted through the drain holes in the spinner and is
hitting the outer tub before draining out of the machine.
Let me know if these help any one understand the sounds!
Huuum
Please remember to leave a rating!
Jun 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool LBR4132JQ Top Load Washer Logo
167 people viewed this question
Dan Webster
Dan Webster
Sal De
