Question about HSM 125.2hs Shredder
Hsm125.2 Both lights are illuminated. Shredder doesn't need emptying and the door is closed but lights staying, doesn't do anything except for leds on
  • 57 Answers
Because your shredder shred almost to dust level. you may have paper back up inside the machine. you will not be able to see it unless you remove the head and open the cover. Or your main board could be bad. You have one main board that controls your shredder.
At this time, the machine maybe reading as full because the paper backup inside the machine.
you have few screws that holds the base and the top cover.
Good luck.
email me if you have problem
This is known problem with Hsm125...
Posted on Jul 23, 2008
I emptied the shredder and now the red overheat/door open light comes on when I turn it on. will not allow me to shred anything. please help!
There is an interlock that prevents your shredder from operating without the bin in place. Something may be stuck inside, preventing the bin from closing the interlock. There also could be a shred of paper preventing operation.
Feb 17, 2015 | Compucessory CCS60076 - High Security...
Full bin-door open light on with empty closed bin
Pull the bin out and look inside for a push switch that the bin pushes against. See if it moves freely. Likewise it may have an LED switch, see if it's blocked.
Oct 09, 2014 | Office Equipment & Supplies
How do I fix my door ajar light stays illuminated
its a bad door ajar switch. which one? you would need a scan tool. but the drivers door does get used more.....
Sep 26, 2014 | 2004 Ford F150
SAFESENSE ISN'T WORKING ON C-480C FELLOWES
Use a cotton bud dipped in alcohol and clean sensors
Run shredder once a day in reverse for 15 seconds to clear cutters
Empty wastebasket when bin full indicator light is illuminated using b0
If this does not solve the problem goto
www.fellowes.com for an extensive on-line support section
Feb 27, 2014 | Fellowes Manufacturing Powershred C-480C...
Automatic door lock 1999 toyota prerunner
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
AUTOMATIC LOCK SETTING
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Jan 28, 2014 | Toyota Camry Cars & Trucks
SONY DCR-PC100 The video control panel should illuminate orange so you can see the buttons. Now this only illuminates when you open the cassette door to remove a tape. As soon as the door is closed, the...
The camera has in fact 2 leds built-in, so it rather looks like one led is out, I had same problem, and sad to say stripping it down to put a new led in is,,, shall we say an eye opener, o yes a wallet opener too.
Jun 12, 2010 | Sony Handycam DCR-PC100 Mini DV Digital...
Shredder keeps turning off and full light comes on but its empty. Have to keep opening and closing door to shred something
Door switch possibly bad I am a shredder tech out of colorado. Call fellows at 800-955-0959
May 05, 2010 | Fellowes DM15C Shredder
Gbc shredmaster 4220S just stopped working
Check swich door , if door is open the machie stopped for securyti of the operator . the swich is closed whith the door is closed , good luck
Oct 31, 2008 | Quartet gbc 4220S Shredder
KENMORE SELF CLEANING FEATURE WILL NOT ACTUATE
Firstly, empty the oven of stuff, including the little thermostat that dangles from the grate, if you value it's life.
Next, close oven door.
Press CLEAN; it beeps and green LED illuminates. LED readout says " -- -- --".
Press the UP arrow; it beeps and LED readout says: ''3:00'', for a three hour burn.
DOOR LOCKED LED blinks while door locking mechanism actuates, then stays on steady. Burner ignites, and it's off to the races.
The exterior of the Range becomes quite HOT, providing an excellent opportunity to educate young children of the concept. ;)
The Cleaning Cycle can be stopped at any time by pressing the OFF/CANCEL button for ~3 seconds. The door will remain locked until the internal temperature of the oven falls below 400F. Nice toy.
Apr 10, 2008 | Kitchen Ranges
HSM 125.2hs Shredder Logo
464 people viewed this question
Top HSM Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
ray gallant
Tom Chichester
Are you a HSM Office Equipment and Supply Expert? Answer questions, earn points and help others
