Question about Frigidaire FGB24S5A Gas Single Oven
High flames in oven
Just installed gas range/oven, range is fine. when i turn oven on, the flames are very high in the front and not flame in the back. also the flames in the front are yellow, with small amount of blue. thanks.
Flame saftey device control valve stuck in open position that why main gas is coming other wise flame should be max 2cm long after flame saftey device heat up and bellow expand and main valve should open
Posted on Nov 07, 2008
Gas valve wont open in my oven
call your local repairman .
Nov 15, 2016 | Ovens
Flame too high on gallery gas stove
Hello Carlos - Does you range have an LP conversion kit installed? If so, I would recommend verifying that unit is set to appropriate fuel and fuel conversion kit is finished. Also trying adjusting the pressure regulator and/or air shutter.
Sep 16, 2012 | Frigidaire FGB24S5A Gas Single Oven
Oven flame is to high. How do I fix it?
You have selected an electric range, what is your true gas range model number?
Aug 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven wont turn on
I have a delongi oven and hob hob is working fine but the oven isnot im turning the nob on the front of the oven and ignition on lighting is fine after I release the knob on the front the supply turns striaght off no flame no gas nothing
Apr 04, 2011 | DeLonghi Ovens
Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
Sep 19, 2009 | Ovens
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
Oven and broiler will not come on.
go to enter model number and look for the igniter it seems to me you need to change this part. Note it is very fragile.
May 02, 2009 | Ovens
Oven lights on low flame but will not come up on high flame .cannon chester cooker.suspect by pass is not working. Do I need control knob/thermostat with the phial. Thanking you.
all gas range ovens have a small metal box in the back upper area of the broiler burner; a gas line runs into this box as do two wires; this is a "flame control " gas valve; the way it works is: after the pilot has been lit as you turn the oven temp control a heating element in the box causes a small valve to open allowing a larger amount of gas into the oven burner to ignite the whole burner If you can only get pilot flame on high replace this valve
Apr 26, 2009 | Ovens
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Frigidaire FGB24S5A Gas Single Oven Logo
455 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
