Question about Dishwashers
General Electric Pot scrubber Dishwasher
Spinning arms don't move or spray water. We have taken it apart and cleaned it, still doesn't work, even though there's a small amount of water that oozes in, kinda like suds........................please help!!
  • 2 more comments
  • blc1 Jul 21, 2008
    My problem above was posted, and it's still not working.
    what can I do next?
  • blc1 Jul 24, 2008
    We have replaced the inlet valve, the water that's standing looks dirty, what should I do now?
  • a_greg Aug 27, 2008
    same issue, completes cycle but spray arms don't turn,
    getting water in and out of DW and the machine acts as if
    has complete the wash. One other thing is that the soap dispenser
    door does not open GE GSD6200
  • fishon77 Jan 27, 2009
    It appears to be a valve in the back, bottom of the unit that is not opening.
    The rubber hose coming from the pump fills with pressure to this valve, but nothing comes out through the white plastic drain hose.
  • 413 Answers
From what you are describing, the fill valve may have failed or become clogged. Start the dishwasher, when the water stops filling, open the door and check the water level. There should be at least an inch to an inch of water in the center of the tub. If not, replace the water inlet valve.
If you need further assistance, let me know with a model number
Regards,
reg501
Posted on Jul 21, 2008
My potscrubber 650 does not drain each time after use, what can I do to fix this?
Posted on Sep 16, 2008
Dishwasher
sounds to me like the pump is not working as good as it should . water pressure runs the arms .look for something plugging it
Dec 13, 2015 | Dishwashers
Spray arms not working
Hi frustrated in Raleigh,
I understand that the spray arms are not moving or spraying water, even after you have cleaned the screens and arms. What might be happening is you are not getting enough water pressure to the dishwasher.
The hot water line to your dishwasher must provide water pressure between 20 and 120 psi.
Low water pressure may occur when laundry or showers are in operation.
Wait until water use is reduced before starting dishwasher.
If you are still noticing that the spray arms are not moving or spraying water, I would have a local Authorized Technician come out to see what exactly is going on with the spray arms of your dishwasher.
-Best Regards-
Jan 06, 2014 | Frigidaire FPHD2491KF Dishwasher
Dishes not clean seems to have no water pressure
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 12, 2011 | General Electric GLD5950N Built-in...
Maytag dw Not cleaning the dishes-a haze has appeared on the surfaces and the silverware looks tarnished. All the parts have been taken apart and cleaned, new detergent, checked water temperature-all...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
m,nb.
Sep 02, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
My dishwasher sprays water up into the dishes but the little spray arms don't move when the water sprays up. The arms move by hand when I touch them. What could this mean for my dishwasher?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
heatman101
Aug 31, 2010 | Whirlpool Dishwashers
The top cleaning bar will not spin---water is moving through it but it wont spin--the bottom cleaner spins fine---took it apart and there is not blockage in either of the cleaning bars
heatman101
vvbn
Mar 24, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
Dish washer gets to hot in pot scrubber mode
did it distort the spray arm? A lot of times if it's the spray arm that melted it's possible that it was jammed while trying to heat the water and the heat from the element would warp it.
Mar 24, 2010 | Frigidaire PLD4375RFC Dishwasher
I have a Maytag MDB9100A leaving food particles
heatman101
m,.bn
Feb 23, 2010 | Maytag MDB9100A Dishwasher
Maytag MBDF550Aww upper spray arm doesn't spin.
Cleaning the filter was the right thing to try.
Since you don't see cracks/breaks on the spray arm and it appears that it is spinning freely, I doubt that replacing the spray arm will fix your problem.
If your dishwasher is several years old, your problem is likely a failing pump motor, but before you swap that out, check that the impeller is not damaged. Good Luck!
Apr 01, 2009 | Dishwashers
LG dishwasher bottom arm not spinning
heatman101
syte
Aug 24, 2008 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
1,556 people viewed this question
Top Dishwashers Experts
