Installing windows on HP dv 6000
In the BIOS setup, there is no diable SATA Native support option. Hence my dilemna
  • 37 Answers
Just kidding. Go into the BIOS by pressing F10 when it starts up, its under the system configuration tab, or something of that sort.
Its called SATA Native support or something like that, just arrow down to it, hit enter, and select Disabled.
Hit F10 to save changes and then reboot.
Regards
Raj
Posted on Jul 30, 2009
I want to install Windows XP on Sony Vaio VGN CS15GN B instead of Windows Vista but it is not happening kindly help
---------------> Perform a clean install of Windows XP 1)- Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
2)- When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
3)- At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
4)- Read the Microsoft Software License Terms, and then press F8.
5)- Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
6)- Follow the instructions on the screen to complete the Windows XP Setup.
Note:- Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
May 25, 2011 | Computers & Internet
Hi..i have HP pavilion dv5 laptop with preloaded Windows Vista. i want to istall windows xp instead of vista. i tried installing it using xp bootable disc. but after loading the required installation files...
its very simple....
enter the bios setting...The BIOS settings menu is accessible by pressing the f2 or f10 or the f6 key on some computers.
if the BIOS provides an option to disable the native-SATA configuration in the BIOS, do the following steps to Disable the native-SATA in the BIOS
1. Use the cursor to navigate the Configuration options to locate the Native-SATA setting. 2. If there is a SATA setting, select the Disable option, and then press F10 to save the change and restart the computer.
if your system bios does not contain such option.... then find "Native SATA mode" or "SATA IDE"
then change "AHCI" to "ATA"
Jan 16, 2011 | Computers & Internet
Im using hp 530 and when trying to re install xp
you need to change native SATA settings in bios. then you can install windows xp. The steps are below
  1. Turn off the computer.
  2. Press the power button and press f10 to open the BIOS Setup.
  3. Use the cursor to navigate the Configuration options to locate the Native-SATA setting.
    • If there is a SATA setting, select the Disable option, and then press F10 to save the change and restart the computer
May 05, 2010 | HP 530 Notebook PC
Unable to Downgrade vista OS to windows 2003 or XP(CQ-LAPTOP)
During the Windows XP install it cannot find a hard drive?
The reason why Windows install does not work is because Windows XP does not have a SATA driver support and therefore cannot find the hard disk.
THE FIX FOR THIS PROBLEM.
Go into your BIOS and turn off Native SATA support or set it to IDE controller (this setting depends on the type of BIOS). Save the setting and reboot and you will be able to install Windows XP.
IF YOU CANNOT DO THIS IN THE BIOS then :-
Go to the Compaq/HP WEB site to download the SATA driver for your model laptop. This driver is used to install the 3rd party driver
during the Windows installation (during the Windows installation you need to press F6 to allow you to install the SATA driver).
Mar 30, 2009 | Compaq Computers & Internet
How can i desable sata hard drive in laptop for installing win XP
in the BIOS you should change the following option
sata native mode should be disable.
Feb 02, 2009 | HP Pavilion dv2000t Notebook
When i try to install windows xp sp2 it says "no hard disk detected" i also doesn't know how to use nlite.could u pls help me with a complete step by step method starting from nlite to completion of driver...
First of all, as this Notebook is installed with SATA Hard Drive, any retail version of windows XP will not be able to detect the Hard Drive because of which you are getting this kind of errors when trying to install XP.
However, to proceed with installing XP in your Notebook, I recommend you to disable the SATA Native Support option which will be present with Notebooks installed with Intel Processor and not with AMD Processor.
You can disable the SATA Native Support feature from the BIOS by following the instructions below :
Start or restart the notebook and start tapping the F10 key which will take you to the BIOS setup window.
In this, go to the System Configuration tab where you will find the SATA Native Support.
Press Enter to select it when the option is hilighted and set the option to Disabled.
Now, press F10 key to Save the settings and exit the BIOS setup window.
By doing this, the Hard Drive in the Notebook will be detected as IDE Hard Drive and you should be able to install XP without any issues.
Please not down that the SATA Native Support option should be set to Disabled even after installing the Operating System in the Notebook.
However, I need to have the Product Number of the Notebook wich can be found printed on a white sticker pasted at the bottom of the Notebook indicated wit P/N using which I can find the Hadware specifications of the Notebook and provide the appropriate drivers.
Oct 28, 2008 | HP Pavilion dv6000z Notebook
Compaq presario v3000 laptop..doesnt recongize the hard drive
I beleive that you are trying to install retail versions of XP which will not be able to detect the Hard Drive in the Notebook as it is a SATA drive and Windows XP will not be having the drivers for SATA Hard Drives by default.
In this situation, I recommend you to check and disable the SATA Native support  option available in the BIOS.
Start the Notebook and start tapping the F10 key which will take you to to the BIOS Setup window.
In this, go to the System Configuration tab using the Arrow keys and select the option as Disabled next to SATA Native Support.
Press the F10 key again to save the settings done and exit BIOS.
Now, you should be able to use the Windows XP disk and install Windows XP Operating System in your Notebook without any issues.
By disabling the SATA Native Feature, the Hard Drive of the Notebook will be detected as a IDE Drive because of which we will be able to install XP without any issues.
Donot Re-Enable this feature in the BIOS again as the Operating System may not boot. Let the option next to SATA Native Support be Disabled.
Hope this helps...
Aug 12, 2008 | HP Compaq Presario v3000z Notebook
Xp professional installation on hp pavilion dv6700 cto notebook
The original Windows XP Installation CD, a freeware application named NLite and a blank CD.
we need the drivers for the SATA controller provided by the manufacturer.
When you start the Nlite application, you will be asked to provide the location for the Windows installation package. Insert the genuine Windows Installation CD into the CD drive and, inside the application, select the CD drive letter.
To insert the SATA drivers within the installation package, you need to have it saved on the HDD. Hence, when the warning window appears click OK and select the destination folder for the files to be saved. Make sure that the destination partition / HDD has enough space to store the contents of the installation CD.
Immediately after you have chosen the destination folder, the application will start copying the Windows installation files. When finished, it will display some version information regarding the newly copied Windows Installation Package.
Now, click next twice until you get to a screen where you get options sorted in 4 categories: Integrate, Remove, Setup, Create. We are interested in the integration procedure, therefore select the Drivers button and click next. From the next menu window, click Import and select multiple drive folder option from the drop down menu. This option permits you to browse to the location where the downloaded drivers are found.
Select the containing directory and click next. You will get a list with the available drivers (in case there are more than one) or simply one driver. Select it (them) and click next. Now the application will ask for the permission to start the integration procedure. Choose Yes and wait for the drivers to be inserted into the installation package.
With problematic driver being included in the installation package you can install Windows XP on your SATA HDD...but...the installation package is on the HDD. You need a bootable CD in order to start an installation. Don't worry, once the installation package has been adorned with additional user selected drivers it can be transformed into a bootable disk image and later burned on a CD. To encapsulate the installation into a ISO image use the same Nlite application.
Open it, make sure the HDD installation folder is selected and click next. Select "Last session" preset and click next again. Now from the options menu choose Bootable ISO and click next. In the following window, make sure that the mode is set to "Create Image" and click Make ISO. A destination folder is required where the resulting ISO image will be saved. Once the image saving process finished you have the freedom to burn it on a blank CD with whatever you favorite CD burner software may be.
The new CD will be the twin copy of the Windows Installation CD but with one difference, it includes the SATA driver
Mar 17, 2008 | Microsoft Windows XP Professional With...
How to install xp on hp 530
Press F10 to enter BIOS setup...
find and disable the SATA native support
Now save and exit then when you reboot and attempt to install XP you will have no problem.
Download the drivers you need from here
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3375995&prodTypeId=321957&prodSeriesId=3375953&swEnvOID=1093&taskId=135&swLang=8
Mar 11, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
