Question about Dryers
Top panel How do I remove the top panel. Are there any on line exploded diagrams of this dryer, the GE DBL333GB4WW?
  • 5,911 Answers
There are some exploded view diagrams available at searspartsdirect.com. Just type in your model number and look under the "Controls and Top Panel" heading on the next page. If you are talking about removing the washer top, you simply push in on the release tabs (item number 7) with a putty knife, while lifting at the same time. The entire panel should lift up. I hope this answers your question. If not, please post back and let me know if you need further assistance.
Posted on Jul 21, 2008
Tip
How it works: Late model Ge top loading washer
The late model top loading GE washer is much different than it's original models that were so much more dependable than these newer ones are. To access the innards you must forst remove the front panel. Older models had the top pop up first but these newer models have the top bolted down. To get the top up you must first remove the front panel by using downward force on the top between the tiop and the front panel. It is not easy even for eperienced techs but cuss it a minute and it will come off. Once it is off you will notice the washer has an elecetric pump. Strings and junk get into this pump. It is easy to take apart and cleanup. The tub is suspended on 4 rods and the lateral movement is kept in check by 4 rubber cord mounted to the top called bungies. The motor and tranny can easily be accessed by removing the tub from the washer. After disconecting the power cable and pump the tub lifts out. Not all GE washers use the same motor or the same transmission method. Some do not even have a tranny. I have some GE washer service manuals.
GE front access late model washer
on Dec 13, 2010 | Washing Machines
HOW TO GET INTO THE CABINET OF MODEL LER3622HQ0 WHIRLPOOL DRYER
You will need to remove the top panel, then the front panel in order to access the dryer interior on this model. With the dryer UNPLUGGED, follow these steps:
1. Locate the screws for the top panel in the REAR of the dryer. With the screws removed, the top panel should slide back, then lift off so you can access the screws holding the front panel in place.
2. Disconnect the door switch connector and any ground wires that may be attached to the front panel. Then, remove the panel screw on each side that holds the front in place. With the screws removed, the panel will lift up, then come off.
You should now have full access to your dryer interior. If you have any questions about this procedure, or if you need additional advice, please post back and let me know. I hope this helps you.
NOTE: There are helpful exploded view parts diagrams that can assist with disassembling and reassembling your dryer at the following websites:
searspartsdirect.com pcappliancerepair.com appliancepartspros.com
Aug 15, 2010 | Whirlpool Dryers
Clothes dryer is squealing when turned on. suspect drum bearing. looking for a diagram for dismantling can i take the top off without removing the back panel( GE 5 cycle dryer)
You dont need a bearing you need the DRYER DRUM SLIDE Part number AP2041815 which is under $6.50 a piece. Take the top of the dryer off and look on the front of the drum. Some GE dryers have 2 and some have 4.Go to Appliancepartspros.com it item 316 they also have a diaphram.
Oct 10, 2009 | GE Dryers
HOW DO I REPLACE THE BELT
2 screws at bottom front, pull out slowly from bottom first. Remove the door switch wiring. Then you will see the rest. Note how the belt rides thru the pulley and onto the motor. Belt # 341241, available for $11.99 at timerking.com. Hope this helps!
Jan 07, 2009 | Estate TEDS840JQ Electric Dryer
REMOVE FRONT PANEL - ZIPPER PARTS STUCK IN DRUM GUIDE.
I found the parts manual on line at GE Appliances.
The replacement parts for the top indicated pictured two clips holding the front of the dryer in place.
I tried a narrow screw driver on the clips and that released the top.
With the top off, removing the front panel required removing two screws, lifting the drum and pulling slightly on the front panel.
After removing the wires from the door switch, I was able to find the broken zipper, clean out the fan, remove excess lint and reassemble.
Dec 06, 2008 | GE DBL333EBCC 5.7 cu. ft. Electric Dryer
No heat on my GE prodigy dryer dpxr483
Here you get exploded view, so that you can locate the thermostat. There are two thermostats at the back of the drum, they are numbered 505 and 507 in diagram.
Here is the diagram
To access the thermostats, remove the back panel (see diagram), and undo the belt routing.
Sep 29, 2008 | GE DCSR483EA Electric Dryer
Ge dryer
you need to remove the front panel and kickplate (if you have one) This will allow you to detach the front of the top of the dryer and you can prop the top up while you replace the belt around the drum, down to the drive belt. Here's a link for your make and model. It shows an exploded view of the parts of your dryer. http://www.partselect.com/MultiModels.aspx?ModelNum=dde7100&searchTerm=&RefineSearch=0. This can help you figure out what parts you might need and how things go back together. Good luck!
Jul 14, 2008 | GE DBSR453EBWW Electric Dryer
Ge dsxh43
This link goes directly to the exploded view/tear down page for G.E. dryers at Repairclinic.com. From there you can navigate back to the parts breakdown/order page. Just enter your model no. in the search box and click search Most G.E. dryers have 3 or 4 screws holding the top panel to the front panel. Open the door andd they should be accessible at the top of the door opening. After removing those, then should be 2 screws at the bottom to loosen, then the front lifts off the 2 screws. The diagram should help guide you through the rest.
http://www.repairclinic.com/0100_20.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 07, 2008 | Dryers
Dryers Logo
157 people viewed this question
Top Dryers Experts
