Question about Sub-Zero Refrigerators
Sub-zero 550 series
Refrigerator lights went out - four bulbs. Replaced bulbs but still no lights. (freezer bulbs work ok) Is there a fuse somewhere? Any other explanation.
Thanks
  • Anonymous Aug 09, 2008
    How are the lightbulbs replaced and where do you get them ?
I had this problem in the fridge portion last year and replaced the switch at the top of the door. Problem solved. There should be two switches: one for the lights and one to turn off the compressor when the door is open. I don't remember which one was which. Try the link below for the part, but double check to make sure it's the right one. They have an 800 number to call as well. Good luck
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=753971&PPStack=1
Posted on Jul 22, 2008
Lights all went out in refrigerator side of Sub Zero 632
I WILL BET THEY ARE DISCONNECTED !!!! CHECK FOR CONTINUITY AND SEE WHERE THE CONNECTION IS OUT.
Oct 13, 2012 | Sub-Zero 632 / S
I have a Sub-Zero Model 550 whose freezer does not get very cold even though the set to 10
set freezer for 0 deg and clean the coils on top . and make sure the fan up top is working . very important .. mm 550 are r12 and may be low or refergent . this is somthing you may need a service tec to ck but do the cleaning first and see how it works. mm
Sep 03, 2010 | Sub-Zero Bottom Freezer Refrigerator
We replaced all of the light bulbs in our 550 and the lights still do not work, any ideas?
Most likely light switch is bad. Could be light limit t-stat (prevents from overheating) and wiring problem too.
Sub-zero refrigerator repair in orange county, ca
Feb 06, 2010 | Sub-Zero Refrigerators
Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
appliance repair orange county, ca
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub zero 550 refrigerator light not working
first try to tightin the bulb, it has a seal and it's hard to drive it home. otherwise it could be the door switch.
Dec 22, 2008 | Sub-Zero 650 / O Bottom Freezer...
Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
______________________________
http://www.SubZeroLosAngeles.com
Nov 11, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Refrigerators Logo
318 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
