Question about Nikon COOLSCAN 5000 ED Film Scanner
Wrong alignment in batch scan
Hi, I tryed to make a batch scan fomr 35mm posetiv film, the strip's are from 4-6 pictures, the 1 picter is align correct, but the rest i somhow off but 1/3, the film is a posetiv but the edge is transparent.
can you please help me
    Problem Solver:
  • 13 Answers
Try scanning these strips with the FH-3 accessory. It may be the negatives aren't being sensed correctly at the frame boundary. This unit overcomes this problem and can often be found at a reasonable price on eBay.
Jeff Underwood 1Scan.co.uk
Posted on Mar 02, 2009
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
Dec 20, 2014 | Canon EOS-AE-1 35mm SLR Camera
I just bought a Minolta maxxum QTsi from a lady and it had no manual with it, I can't figure out how to load the film. Can you take me step by step on how to load the film and how the camera works when...
Hi, I've found the instruction manual online for you, http://www.mediacollege.com/equipment/manual/konica-minolta/camera/maxxum-qtsi.pdf that way you have it for future reference. For loading film you open up the back of the camera and make sure that the end of the roll of film is aligned with a red mark and then you close the back. For taking pictures you press the shutter button half way in order for it to focus, when the image you want is framed you press the shutter button the entire way and it'll take the photo.
May 13, 2011 | Minolta Maxxum QTsi 35mm SLR Camera
Lost film guids for canoscan 9900f. looking for
lost film guids for canoscan 9900f. looking for 35mm strips and slides 120 and 4"x5" format film holders in the accessory kit for canoscan 9900f
Apr 07, 2010 | Canon CanoScan 9900F Flatbed Scanner
I used all of the elevation adjustment on 3-9-50mm scope and my 22 rifle still shoots low at 25 yards
its a bad mount thats doing this,,,you can get over it easly by letting off the rear top mount of the scope (the mount near your eye) and pushing under your scope a strip of 35mm film this will lift the eye end of the scope giving you more range,,(elevation) only put 2 or 3 strips of film under the scope any more that this could bend the scope tube when you tighten it up
but a strip of film is about 25th of an inch and 1th will give you 1/4 of an inch at 100 yds ie:1 click! so you should easly get 10 inches at 100 yds or more with 3 strips of 35mm film under the scope even with bullet drop, the only other way to sort this out is to buy an adjusterbal mount witch is very pricy and 35mm film is cheaper, i do this all the time with my scopes
Nov 21, 2009 | Tasco Scope Guide Quickly Zeroing Rifle...
Elevation is turned all the way up and at 50ytards
this is a common fault with fitting cheep mounts on your rifle,,
a nikon scope is realy for "air rifles" but having sead that there very strong scopes, i have 4 of them all fitted on full bore rifles,,308,(7.62) .303 british enfield, .22-250 and a 357 mag rifle? and none of them have shook apart yet! and i found that on a full bore they do shoot low,,,to get over this problem you could change the mounts to the ajustable type witch is pricy,,or a cheep way out is to pack the bottom of the rear scope mount out with a strip of 35mm film,,(the rear being the end you look throw),you only need to life the rear end of your scope 25th of an inch to rise its point of impact by 6" inchs at 100 yds as the nikon scope is one click (1 thou of an inch) = 1/4 of an inch at 100 yds so 25 thou will raze it by 6.25 inches (- bullet drop!) just undo the scews that hold down the rear of the scope and slip a bit of old 35mm film under the scope then nip the scews back up again and try it out,,,if its still low put in a bit more packing,,,but you can only get about 4 bits of film in before its likley to bend the scope tube!!! mind you with 4 bit under it you will be shooting at the moon??? its much cheeper that ajustable mounts,, all my scopes are packed out like this and they dont creep or slide or loos point of aim even after 300 rounds in a day?
Nov 18, 2009 | Nikon Optics
Film is not loading automatically
That's not a "12" but halfway between 1 and 2, so it would pay you to have your camera aligned by a pro.
Apr 18, 2009 | Nikon N70 35mm SLR Camera
Canon T90 Problems Loading Film
OK, the problem is that film door switch is faulty.
It needs alignment.
Jan 25, 2009 | Canon T90 35mm SLR Camera
Scanned 35mm slide comes out as rectangle with dark edges
I've not ever seen "square" 35mm slides. By definition they are a rectangular positive film in an outer square "mount".
If you have a truly square piece of film then it is not a 35mm slide. You may have to use settings other than those for a 35mm film but these would be I don't know.
When were they taken (approximately)? What brand of film? Are they in a cardboard "mount?
Aug 01, 2008 | Epson Perfection 4490 Office Flatbed...
Film advance slipping?
This has happened with my pentax super program. All that was wrong is the the spool/winder was dirty. It needed to be cleaned. You open up the back of the camera. Stick something such as a small screw driver, just something to stop the film winder from turning. Now turn the top of the winder off while keeping the bottom part in place. Be very careful not to close the back of the camera while you do this. Once you have it out give it a clean with a soft cloth and then put it back in. I found it tricky to align it and get it back through the whole. But, that's me. After that it worked perfectly. Until the next time in a year or so it needed to be cleaned again. Hope this helps.
Oct 06, 2007 | Pentax ME Super 35mm SLR Camera
Nikon COOLSCAN 5000 ED Film Scanner Logo
132 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
