Question about Sharp Aquos LC-32GD4U 32 in. LCD HDTV
After 4 hours of use, developed a green vertical line down center of picture.
My Sharp 32" after about 4 hour of use developed a green vertical line right down the center of screen when there is a picture. No line when is nopicture (black screen). All inputs have it Video 1 Video 2, (Sat, DVD ect. Have tried go back to factory resets, turning of OFC ect. Un plugged, and played with every menu I know. Is it off to the shop time?
  • rjsimms3570 Jul 21, 2008
    I guess it the right answer. The set should be under warranty so I will contact MFR.
  • Anonymous Mar 24, 2014
    this tv fell off the back of the car while unpacking to a new house. upon turning it on, there was a while vertical line almost at the center of the screen while the pictures on the other part of the screen looks like negative colored pics
  • 1,894 Answers
Your vertical ICs need to be replaced.
Posted on Jul 21, 2008
  • dewan nafees ahmed Jul 21, 2008
    if you have good experience with Tv repair you can get it done by yourself.
    just order the Ic by mentioning your model number and then replace it.
    if you dont have good experience then i would advice you to take it to some repair shop.
    doing experiments in this units with out any prior experience is very very dangerous.
White line in center..sound iis fine
Most common are soldering problems on the vertical deflection IC's.
If this line is quite bright: shut down the set, it might damage the picture tube permanently. Resolder all pcb connections under the vertical defl. part. With a magnifier you can see "craters" around the footprints. Where is the vert. deflection. ? Mostly an integrated circuit
on a vetically mounted heatsink . Typnumber: mostly something TDA53xx like. Gently knocking with a screwdriver and observing the screen might lead you to it's location if you're not familiar with TV's.
Watch out: lethal voltages !
Jan 27, 2014 | Panasonic CT-32SL14 32" TV
Sharp 32" lcd tv vertical lines on screen
sounds like you have receiver connection problem..
To test it try to play dvd on your TV..if the picture is fine your TV is good..your problem is on the cable box or receiver..
Nov 06, 2012 | Sharp LC-32AV22U 32 in. LCD TV
Sharp standard tv turns off by itself. have to
if you know how to solder,resolder the vertical section of your tv especialy the IC.i think it is TDA 3657 it is an IC with 7 to 9 legs
Jul 29, 2009 | Televison & Video
vertical line ic no pda 3653
Aug 16, 2008 | RCA F36650 36" TV
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Mar 27, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sony gv-27v42 27" tv picture cuts out after a few minutes
Vertical lines down the center only means that you have a loose connection on the Yoke. Re solder all the connection on the yoke and where the yoke connection meets the main board.75481bd.jpge307a54.jpg
best regards
Dec 21, 2007 | Sony KV-27V42 27" TV
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Sharp Aquos LC-32GD4U 32 in. LCD HDTV Logo
803 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
