Lexmark Optra S 1855 Laser Printer Logo
Posted on Feb 04, 2011
How to change the printhead of a Optra S 1855 laser printer?
3 Related Answers
don_farr
Don Farrell
  • 1018 Answers
  • Posted on Jun 03, 2009
SOURCE: can't print from bottom drawer, will only print from tray,
There are at least three possible solutions. The first two are simple the third is fairly complicated unlr=ess you can read a hex dump of a print file. 1) Use the front panel "Paper Menu" to select the tray. 2) Check the driver settings to make sure the driver is set to "Auto" or the correct tray. 3) Set the driver to "Print to File". When prompted to name the print file, name it "tray_fail". If you do not know how to read this file, send it to me at [email protected] and I'll be happy to take a look at it and see I I can correct the problem. Don
Anonymous
  • 11 Answers
  • Posted on Jun 17, 2009
SOURCE: Swap parts between Optra S 1255 and 1855
I can say for sure that these parts do not translate. The service manual says.
Anonymous
  • 1382 Answers
  • Posted on Jul 21, 2010
SOURCE: My Lexmark Optra S 1855 has a
First thing to do is get the top off which can be easier said than done. The printer has four screws holding the top. After that remove the control panel by undoing the four screws holding it in place. This isn't strictly necessary but it makes life easier. Now move the print head to the left. To do this you have to lower a locking bar that is located at the base of the head. The head can be quite hard to move but it does slide left. Under the print heads you will find two pads of hard foam. These collect the ink when you perform a normal head clean and keep the print head moist. Soak these with water . Pool water on them and let it run through (it goes through to a large pad at the bottom of the machine by the way). Fold some tissue and lay it on the base when the heads pass over. Push the head back and forth over the tissue to clean the actual head. The tissue will come out covered in ink.Now for the tricky part get an old printer cartridge and remove the label on top that says "do not remove". Under the label you will find a couple of holes. Widen them / open them with a drill bit about 3 mm is good. Fill the cartridge with water and put it in the printer. Push the heads back over to the right as far as they will go. This will cause the sponges to come right up against the heads. Leave the set up over night. In the morning test the printer. Run a couple of head cleans with the cleaning cartridge in. Your problem is solved now
Thank you!
Optra S 1855: Error "202 paper jam open rear door" appears constantly as soon as I turn on the printer, and I can't do anything. However, there is no paper in the printer!
Get the user manual/support/information for your Optra S1855 here:
http://support.lexmark.com/index?page=manualsguides&linkSelected=node2%5Esubnode1&channel=manualsguideschannels&locale=EN&userlocale=EN_US
Also, sometimes if you blow out a printer with a spray can of air or small air compressor it could remove a little piece of paper/debris that is stuck to the jam sensor. Good luck.
Paper tray on optra n is not coming up and message says load paper
Check the paper guides on the paper tray, check if they are set to the correct paper size.
1helpful
SERVICE PRINTER ERROR: 934 ON LEXMARK OPTRA S 1620
These error codes indicate a problem with the mirror motor circuit
in the printhead assembly or the mirror motor cable to the engine
board cable or engine board assembly.
The mirror motor cable or engine board would possibly needs to be replaced. Please contact our technical support team for assistance.
I keep getting a paper jam error with my Optra S 1855 printer, but there is no paper jam. This error interchanges with a message asking me to Change the paer in tray 1 to letter size, but it is already...
Open the tray and make sure the green paper lever is set to letter mark, both at the bottom of the paper and the one on the side. And yes, if you haven't used it for 3 years, you should clean the dust that settled inside your printer over time.
Lexmark optra s1855 makes knocking noise when printing envelopes from the mp tray
this noise is usuallt cause by a flat spot on the backup roller of the fuser remove the fuser turn it by hand if you feel a flt spot when turning replace the fuser
I have a printer error 935. Can you help me?
this is a printhead error and can be caused by the scanner or the engine board. scanner 60% engine board 40% to be sure you have all of the parts you need and be able to return the one you didnt use go to L-tech4u.com a simple email on the site and you get better prices support and instruction to do your repair
1helpful
My Lexmark Optra S 1855 is showing a fuser error. What needs to be done?
the fuser needs to be replaced its about 200 dollars just search for Fuser for the model of your printer
Thank You John C
Optra t610 error 935/933/934
replace printhead - scanner assembly. The scanner motor is not working correctly. Need to remove side covers, back of printer assembly, the top cover. Printhead is below the top cover
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
