Question about Acer Aspire SA20 PC Desktop
LITE-ON DVDRW SHW-160P65
My Acer Aspire computer and dvd drive no longer accepts disks of any kind, and the computer doesnt even recognise that a dvd drive is there. i think it might be a driver problem but i dont really know what to do. hope you can help
  • 1 more comment
  • truthseeker3 Nov 15, 2008
    it will not read dv-r it has 2 times alowed me to burn a music cd but now will not detect anything again
  • mlpbull Dec 11, 2008
    Over the past few years i have recorded numerous dvds and have tryed to access my back-ups, with very simular problems, sometimes reading other times not.... I managed to find a driver for this drive at the main Lite-on site just released in 2008 , hope it works to fix this and possibly someone else out with this same problem..heres the link for anyone who may need it...
    http://us.liteonit.com/us/index.php?opti...
    Signed The Bull....!
  • Anonymous Mar 21, 2014
    I cant seem to install a DVD disk into the disk drive please help!
Lite-on dvdrw shw-160p65
Posted on Nov 13, 2008
  • 4 Answers
If windows sees the drive in device manager you can attempt to update the firmware. To access device manager, right click on My Computer and then go to properties. Then click the Hardware tab and then the Device Manager button. Look under DVD/CD-Rom Drives and see if it's listed. If it is, then get the model information off the the drive. Sometimes it is listed in Device Manger, sometimes not, you may have to take the drive out of the PC. After you get the info, post it here and I can point you in the right direction of a firmware update.
Posted on Jul 21, 2008
My lite-on dvdrw shw-1635s can't read or write any kind of cd's or dvd's. When i look at the drive letter of the burner it looks like it has a cd or dvd but there isn't one. I can open the...
if you physically unplug your cd/dvd restart your computer then reconnect it this should activate the found new hardware wizard or it might have a dirty lens you could use a liquid type lens cleaner read the instructions before applying put 2 or 3 drops on a cd/dvd then run the cd/dvd player
hope this helps
Aug 01, 2011 | Lite On (SHW-1635S) DVD RW Dual Layer...
What is the comparable drive for lite-on dvdrw drive SHW-160P6S?
IMHO this Lite-On model,
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4893211&csid=_21
Except it is faster, will read, and burn dual layer disks, and also has LightScribe Technology.
(LightScribe Technology is from HP. You have to use HP disks, (CD or DVD) that are made for LightScribe Technology)
This is the specifications of the Lite-On SHW-160P6S for you to compare against,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1740403&CatId=482
This is information about HP's LightScribe Technology,
http://en.wikipedia.org/wiki/LightScribe
Regards,
joecoolvette
Nov 09, 2010 | Computers & Internet
Light_On dvdrw SHW-160p6s working properly but doesn't read anyth
Thanks for coming to FixYa, The problem you have is either a well documented software problem or a failing drive.
Click the below link, then scroll down and click the "Fix It" button. Follow the onscreen instructions, restart when it's done and see if your drive re-appears. If it does, you're done, if it doesn't work then your drive is most likely failed and you should replace it.
www.microsoft.com/kb/341060/
Hope this helps FixYa,
Chris
Jul 15, 2009 | Lite On Beige&Black16X Double Layer DVD RW...
Error Message 'F:\ setup.exe is not a valid win32 application'
I uninstalled nitro. nitro for some reason blocks dvd roms from loading, and give a win 32 mesg.
Mar 18, 2009 | Lite On LITEON 8X DVDRW +/- Burner
Loosing cd/dvd completely from device manager
check your dvd in bios. is it recognised in bios ?
also try to push your dvd, dvd connection to motherboard might be loose.
Jul 31, 2008 | Acer Aspire 9300 Notebook
My Lite On DVDRW will not recognize any audio cd's...
Hi PhxROcker,
In these drives there are two lasers and two pick-up sensors. Normally in a combined head. One set is used for the DVD and the other is used for the CD. From you description it sounds like the optical sensor for the CD laser has expired! When you place a CD into the drive a small amount of information is read by the drive that identifies the disc type, manufacturer, it's status, capacity etc. If the drive cannot read this then it thinks nothing is present.
If you insert a disc does the LED on the front the the unit flash a few times while it spins the disc. Does it do this repeatedly? If it fails to read the disc does the LED stop blinking and the drive no longer spins the disc? If this is the case then your drive may indeed be faulty.
Sorry I could not be of any further assistance.
Regards,
Spare head 2.
Jan 05, 2008 | Lite On (SHW-1635S) DVD RW Dual Layer...
Lite-on DVDRW SHW-160p65 DVD-RW drive
Where are you looking to recognize the disks? if it is in my computer in Windows it would most likely be because the Roxio software was what was recognizing the disks. generally Windows does not do a very good job of recognizing blank disks. I would look at the disk information in your current CD burning software and see what that says.
Nov 13, 2007 | Computers & Internet
Acer Aspire SA20 PC Desktop Logo
706 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
