Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
CHAMBERLAIN LIFTMASTER PROFESSIONAL 1/2HP
I HAVE TO HOLD THE BUTTON FOR IT TO CLOSE ALL THE WAY, OR ELSE IT WILL OPEN BACK UP. LIKE THERES SOMETHING WRONG WITH THE SENSORS. BUT IT WILL OPEN WITH JUST A PUSH OF THE BUTTON. IVE CHECKED THE SENSORS AND DIDNT NOTICE ANYTHING OUT OF THE ORDINARY. I DONT KNOW WHATS GOING ON WITH IT, PLEASE REPLY
  • 4 more comments
  • Anonymous Jul 27, 2008
    Have the same problem...door will not open or close unless I hold the button down inside the garage. It's 7 days old.
    Dennis
  • jnryan2000 Jul 29, 2008
    I have to hold down the 'wired' open/ close button for the door to close, but when it gets to the 'closed' position, doors opens again. I checked sensors (no problem) and adjusted close/ open height & force settings. No change.
  • Anonymous Mar 27, 2009
    I have the same problem too. The door opens fine but only closes if I hold the button doen until its completely closed . There is a clock ticking sound that I seems very strange too.
    I'll check the sensors but I don't know if that solution makes sense....
  • ca78colonypa Apr 26, 2009
    Sensors don't light up anymore. changed them to resolve the problem. problem came back after 6 months. Now what do i do, change them again? or is there something else wrong that i don't know about.
  • dorismullins Apr 29, 2009
    I changed the gear in my unit. Now, I can't get the chain to move all the way closed or open. I adjust the level and the force but it just moves a little and the goes back the other direction. If I keep pushing the botton until it closes or opens that is the only way to get it up or down. What is the solution.
  • lobomiller May 09, 2009
    my liftmaster pro wont open more than half way without assistance...? It closes fine (guess gravity has a bit to do with that...)
Align the sensors and make sure the green light in on both sensors
Posted on Jul 29, 2008
    Genius:
  • 1,027 Answers
The sensors are the most probable cause.
Posted on Jul 26, 2008
My garage door all the sudden stopped going down when I push the button once...I have to hold it down
SEnsor issue. If not hooked up properly or something is in the way, the door will not close unless you push and hold button till it closes.
Aug 28, 2017 | Building Materials
I'm having to hold the main remote button down continuously to get the door to close. It acts like something is obstructing the path, but it's clear. The sensors have a green light on one and a...
You need to hook those wires back up and then check the door sensors very closely. If the light in one of the door sensors is dim or flashing it will cause your problem.
Sep 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
Door goes down and when it stops at botton, it turns and goes back up ??? Need adjusting ..How can I adjust???
Adjust the position of the door by using the black and purple buttons. Black moves the door UP (open) and purple moves the door DOWN (close)
Setting the up position: 1. Press and hold the black button until the LED starts flashing slowly, then release. 2. Push and hold the black button until the door reaches the desired UP (open) position 3. Push the door control or programmed remote control. This sets the Up (open) position and begins closing the door. 4. Immediately when the door begins to close press and release the black or purple button. This will stop the door Setting the Down position: 5. Push and hold the purple button until the door reaches the desired DOWN (Closed) position. 6. Once the door is closed, If there appears to be too much pressure on the door, you may toggle the door back and forth using the black and purple buttons to reach the desired closed position. 7. Push the door control or programmed remote control. This sets the Down (closed) limit and the door should open.
Aug 11, 2011 | Chamberlain 3/4-HP Whisper Drive Plus...
I have a 2006 TL. When you turn Rt the door light goes on and beeps. Is it a sensor or is something wrong with the door?
check door at first chance after light comes on..If securely closed then it is a faulty sensor or door switch in door frame contact dealer and find out if there is a defect in sensor or door switch perhaps they may repair it if defect or under warranty
Dec 21, 2009 | 2006 Acura TL
Okay, I'm having an issue with my Sears Craftsman garage door opener. Not exactly sure of the model number, but can dig it up if that's necessary. Symptoms: 1) Door opens fine from either wall button or...
It sounds like you have a problem with your wall button. I would remove the button from the wall and then disconnect the 2 wires on the back. Remember where they go as they are color coded. You can then momentarily touch the two wires together to check the operation. There isn't enough voltage there to bother you.
One thing to remember. If when the door reverses the main light flashes 10 times it is a door sensor problem and nothing else.
Sep 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
My craftsman 1/2 hp garage door starts to close and then opens up
I had a simular issue, except mine was that the previous owner decided to mess with all the settings and mounts and screwed everything up.
The problem isn't your force sensors its your downwards stopping sensor on the opposite side of the opener. For me I had to take the entire panel off and replace the sensor back in its holder, but try adjusting that sensor setting (clockwise goes down, counterclockwise goes up).
If that doesn't work then i dunno:)
Also set both force settings in between 0-1, for some reason with mine if i set it higher it would set them off....
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Wont Close Craftsman 1/2 HP (1998)
What it is is the electric beams at the door are getting blinded buy the sun or out of line. They are the two black boxes on both sides of the door about a foot from the ground. Put a piece of card board in front of them not blocking the beam dut to block the sun. All that they are is safety beams for kids so they do not get hurt. If you have to move them to the top where the sun will not hit them. Sorry to say though you can not remove them all the way. Also make sure the lite on them is not blinking if so they are out of line.
Good Luck and Please Rate FixYa!
Mar 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Automatic garage door
There should be 2 sensors on the bottom of your door on the inside, 1 on the right side and 1 on the left side.
These sensors serve 1 purpose to send a beam or reflection to each other.
If something is blocking this reflection or is in front of the sensor the door will always come back up.
It is a safety feature so nothing or no one gets hurt when the door is closing!
Sep 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
SEARS/CRAFTSMAN 53628SRT Not Closing properly
sounds like the safety door sensors are at fault,also did you reprogram the remotes by pressing the smart button on the logic board,when the safety sensors are bad the door will reverse to open state.you can pully the rip cord to manualy close the door untill you solve the problem.
Sep 04, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
3,395 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
