Question about Lexmark X5150 All-In-One InkJet Printer
Lexmark 5150 printer
Printer pulls paper ******* right and jams.I have checked for any obstruction and there isn't any. this printer is appx. 1.5 yrs. old.
  • gasdog Jul 22, 2008
    o.k.,I was able to locate and remove the Sharpie marker! Runs as good as new.
  • EddyT Aug 15, 2008
    Fed several pages at one time through the machine. Since then message says, 'paper jam'. Problem is that there is no paper or bits anywhere. Info from Lexmark didn't cure. On switch on, motors churning around for quite a long time, and then we get 'Paper jam' all over again. Any idea?
    Problem Solver:
  • 11 Answers
Pick up the printer with both hands, hold it shut, turn it up side down, and shake violently in every direction until something falls out (which it will!!!).
qwester1
ps if this fails go to fixyourownprinter.com where there are hundreds of posts about this problem.
Posted on Aug 21, 2008
Lexmark x1240 printer jam pulls to the right
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
  6. If cartridge area is clear, close the cover.
  7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark X1240 All-In-One InkJet Printer
Paper jammed inside printer unable 2 see it and pull it out? its a all in one x2500 lexmark printer?
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
Aug 08, 2011 | Lexmark X2500 All-In-One Printer
LEXMARK X7550 JAMS &MISFEEDS TROUBLESHOOTING
How to clear and avoid paper jams: To clear the paper path: 1 Pull firmly on the paper to remove it. If you cannot reach the paper because it is too far into the printer, lift the scanner unit to open the printer. 2 Pull the paper out. 3 Close the scanner unit. 4 Press check. 5 Reprint any missing pages. To avoid paper jams, do not force paper into the printer.
The Lexmark X7500 Series User's Guide will be able to give you more detailed instructions on how to troubleshoot paper jams and misfeeds on your printer. You can download the user's guide from the Lexmark website at http://bit.ly/mdAcJO and go to page 177.
May 10, 2011 | Lexmark X7550 InkJet Printer
Lexmark E342n. The paper jams after it prints and before ejecting. Paper is not wringled when pulled out. I open the back door and the end is there. It is like it is using shorter paper then letter.
Power off the printer, check the entire paper path of the printer for any jammed sheets of paper or other obstructions. Remove any obstructions you find and try printing again. Check if the page setting may be incorrect or paper size and the paper size settings do not match and make sure that the paper size in the printer driver settings matches the paper in the tray.
For further assistance, please contact Lexmark Technical Support.
Jan 07, 2011 | Lexmark E342n Laser Printer
The Lexmark X3350 printer paper jam
Try this:
turn off you printer
unplug the power cable
lift you printer up
while lifting, put it in an upside down position
then shake your printer from left to right for about a min. or 2
then put the printer back to its normal position
turn it on
then check if the issue persist.
Feb 26, 2010 | Lexmark OfficeCenter X3350 All-in-One...
Error 0502 on lexmark 5150
does it happen when you want to print? when you want to print u must choose the long way, then select ure printer on the screen (windows office) and print with that, it can be that someone else used your printer,, and changed the options
Mar 21, 2009 | Lexmark X5150 All-In-One InkJet Printer
Printer 2480- my printer is pulling paper only on right side
Try this :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 16, 2009 | Lexmark X2470 All-In-One InkJet Printer
Lexmark z2300 printer won't pull in paper
Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
Lexmark X2250 uneven paper feed
Oct 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
LEXMARK X83 PRINTER 1) A few times papers jammed too far back to pull out from the front so i pulled them out the back. Now when the paper feeds there is a clicking noise and the papers feed only...
Oct 10, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
70 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
