Question about Vacuums
Dust Buster has no suction
Black & Decker Dust Buster CVH1400 14.4 V
I have had this Dust Buster for a year or so. It was quite powerful and charged well at first. Now it does not pick up anything. I really prefer to fix it than buy another. Thanks in advance for your help!
  • kwingen1 Nov 13, 2008
    Black n Decker has little suction. I really like to fix mine as well.
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: How do I empty this dust buster?
Most of this type have a bag filter that you take out, it is just insie the front part that you take off , then you can empty and clean it.
Posted on Feb 14, 2008
Agent Don
  • 310 Answers
SOURCE: I have a 7.2V Dust
I have a 7.2V Dust Buster Black and Decker cordless vacuum and we have lost the little filter inside it.
Where can I buy it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Please include the brand name and model #
A lot of your local vacuum cleaner dealers carry the Black and Decker filters depending on the model #’s and I will post a few phone #’s listed below so you can order a filter. But 1st always check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://blackanddecker.com/
Contact Us -- Customer Service and Produce Support
1-800-544-6986 (M-F from 8am until 5pm, Eastern Time)
Black & Decker
101 Schilling Road
Hunt Valley, MD 21031 USA
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 30, 2008
SOURCE: black & decker steam buster
Step 1 - fill the rear tank with water. Clip the tank onto the back of the unit.
Step 2 - plug the unit into the wall.
Step 3 - move the switch to "steam". You should hear the unit 'ticking' at the rate of about 120 clicks a minute (2 clicks a second). The clicking should be "kind of" loud until the water makes its way into the pump.
The clicking will get quieter as the water moves through the pump and into the heater. The book says that you should start getting steam in a couple of seconds. My experience is that you don't get a good head of steam up until the unit has been going for about 20 seconds.
Another recommendation: don't use "Spray" until the steam is really rolling out of the unit. It just overpowers the heater and slows your steam production.
Step 4 - Steam the spot you want steamed. If you want to soak the spot, use "Spray". Most of the really good cleaning power of the unit is through the steam, so use that more than spray.
Step 5 - Switch to Vacuum and **** up the moisture from the steaming.
Repeat Steps 4 and 5 until you're happy with the cleaning.
Step 6 - Empty the front tank, rinse it out. Empty the rear tank; you probably won't get all of the water out, but that's not a problem. If you use tap water, put in a couple of teaspoons of vinegar and let the unit run until you've sucked the last of the water/vinegar solution out of the tank. If you use distilled water in the rear tank, you might be able to skip this step.
Step 6 is intended to reduce the amount of lime scale that will build up in the pump over time. You should probably avoid stronger chemicals, since they are going to sit in the pump until you use the unit next, and the first few seconds of steam on the next use will have whatever chemicals you are using.
Posted on Aug 22, 2008
SOURCE: Black & Decker 9.6 V
Response by small6363 was right on target. All the reviews and comments I had read up to this point for my Dustbuster CHV9600 indicated the battery could not be replaced. I am so glad this link was here.I have ordered the part and will follow the other posters' cautions about reassembling the product. I could not be happier as I could not find the model anymore and it is my favorite purple color. Thanks again small6363. You are a life saver.
Posted on Jan 21, 2012
How do I get more batteries for a dust buster?
You have 3 options:
1. You could do a search under the part number of the machine for a parts break out diagram.
2. Open the vacuum, and do a search for the battery when you see the part number on the old battery.
3. Call the manufacturer for assistance.
Oct 04, 2014 | Dewalt Black And Decker Vpx Cordless Hand...
Dust Buster 16.8v won't hold charge, but for a minute. Can rechargeable battery be replaced or is is shot?
What model number is this. Black and Decker does not make a 16.8 to my knowledge, so a model number would be helpful.
Sep 19, 2011 | Vacuums
I HAVE A BLACK & DECKER DUST BUSTER CORDLESS VACUUM. I'VE HAD THE CHARGER PLUGGED IN FOR ALMOST 24 HOURS AND IT IS STILL DEAD. SHOULD THE SWITCH BE IN THE OFF POSITION OR THE MIDDLE POSITION. IT'S...
I am not certain about this specific battery, however, if many batteries are unused for a long period of time, they can not be rejuvenated.
Try the switch in each position for 24 hours and if there is no action, it is probably not worth repairing.
Gary
Feb 20, 2011 | Black & Decker AV1200 DustBuster Handheld...
I lost the manual for the Black and Decker Scum Buster
how long do you charge the batteries for the S300 Scum Buster
Feb 10, 2010 | Black & Decker S500 ScumBuster Handheld...
Black and decker handheld vacuum phv1800 type 1 low battery power
Hi I know what you mean! My B&D dust buster used to do this too. The hi power boost means that it can only be used for a limited amount of time. Due to the age of the dust buster though its a sign that the battery is on its way out and regardless of whether or how long its been used or not used, batteries can lose power regardless.
Try to let the dust buster completely lose power and then charge it up for its initial burn in period of 14 hours. Also clean the connection metal strips or hole with a dry cotton bud incase there's any static or dust. Then see if it lasts longer. If the turbo mode or speed 2 is still short, then the battery is dying out.
I don't know where you are but in the UK its hard to get battery replacements for B&D products. You could check your local seller where you are if they have battery replacements but at the cost of current dustbusters it may make more economic sense to consider buying a new dustbuster.
Jun 19, 2009 | Vacuums
I have a 7.2V Dust Buster Black and Decker cordless vaccuum and we have lost the little filter inside it. Where can I buy it?
Where can I buy it?
Black & Decker
101 Schilling Road
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Dec 23, 2007 | Black & Decker CK1300 Dustbuster Wet/Dry...
Vacuums Logo
88 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
