I believe the Roadster uses the 2892 movement and as such should wind in either direction. Find a competent watchmaker and ask him/her to check the automatic winding mechanism for proper rotation. I am assuming this is a real Cartier.
I have looked at their site and they do not list instruction manuals but they do give a "contact us" link and they should be able to supply the manual you need.
Pull the crown of the analog/date Cartier watch and rotate it clockwise or counterclockwise until you see the date advance in the display window at about 1 a.m.
Use the quick date set method by rotating the crown counterclockwise after reaching 1 a.m. until the hands reach 7:30 p.m. Then again rotate the crown clockwise back to 1 a.m. Repeat the procedure until the correct date is displayed.
Adjust the date forward or backward 12 hours if your Cartier watch changes the date at the noon hour.
mcdevito75 here, That may be a screw down crown to help maintain water proofing, Best Bet, look for a small watch repair shop in your area for help with your Cartiers functions, you can also try to contact Cartier online, Cartier watch.com
