Question about Breville JE900 Juicer
The machine wont work
I bought it off a guy 4 months back. It was working when I bought it but havent used it since. the other day i got it out but it just wouldnt work. Desperate need of help!
  • Eric Rountree
    Eric Rountree May 08, 2009
    I was juicing and the machine stop working
We had a Breville juicer which we just recently used but after a few hours it stopped working. May I know if whats the problem with it. We tried to open it but we can't figure what cause the machine to stop.
Posted on Sep 23, 2008
We have just had this problem with our juicer (a present last Christmas), checked the fuse etc but the fault appears to be a small piece of plastic on one of the side clips which fits into a hole under the clip, depressing a switch inside the machine and allowing power to go through to the mechanism - it's clearly a safety device to prevent the machine operating unless everything is properly assembled, but has been made of such fragile plastic that it has sheared off. Looks too flimsy to superglue, the alternative would be to operate the juicer with something else pushed manually into the hole - not entirely the safest idea... Does anyone know if Breville can supply a replacement clip?
Posted on Nov 23, 2008
  • 3,866 Answers
There is a small sensor that has two black wires connected to it that puts the ground wire togeather this is activated by this sensor and what happens is this little plastic peice get broken easly so what you do its cut the two black wires and splice them togeather for-going the sensor and you should be back in business.
Posted on Aug 08, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Aug 10, 2009
    I just bought one and fixed it by splicing the two ground wires togeather to complete the circuit.
I had this problem with this juicer and am still looking for a solution
Posted on Nov 17, 2008
Problems dismantling champion juicer
It's like a suction is created. I have had this happen. I managed to get mine off with a blunt knife to give a bit of leverage (not ideal I know to put a knife near an expensive piece of equipment but it worked for me) Once you have the blade cutter off I suggest oiling the metal prong that it sits on with something like vegetable oil or olive fairly regularly to avoid this happening again.
Feb 23, 2014 | Champion Juicers
Not working
This juicer has a 10 year warranty and you can contact Omega directly for warranty information and servicing the juicer. The link for their website is below:
Jun 02, 2013 | Omega Vert HD Machine VRT350 VRT 350...
Big boss juicer won't work
I had the same problem. Mine completely stopped working after I put a small carrot in there. Can't find a customer service number for them. I did find an email for Antoinette Ramos. She emailed me back and said they would send me a new Juicer. Almost 20 days later, I have not received it and I can't get a reply email from her at all. I just looked at the email and her phone number is on there, so I will be calling. Here it is incase you still need it.
Good luck.
Aug 02, 2012 | Juicers
It wont turn on. i have changed the fuse but still nothing help
Devices these days are safety-ed up the whazzoo (technical term)
The safety catches and hardware all must be correct for these devices to work.
It is possible that a keeper or stationary lock of somekind is still installed preventing the machine from working.
Check the outlet to insure you have power there.
Insure all of the covers are in place and then insure a catch is provided for the output.
Failing all that, return it.
Sep 27, 2010 | Magimix Le Duo 250 Watts Juicer
Juicier will not work at all
Try the juicer on another circuit to see if the breaker failed altogether on the circuit you were using. It's possible that the machine is drawing more power than it should and may need to be checked by an appliance service dealer. An electrician can also check the power draw at the breaker to see if it is being overloaded. If the machine itself is defective, it should receive professional service. Good luck!
May 07, 2010 | Champion G5NG853S Household Juice...
Cutter is stuck onto shaft, how can I remove it?
First, check to see if there is a set screw in the side of the cutter which screws against the shaft.
If no set screw, a gear puller would probably do the trick. There are many types -- you might luck out and find one which will fit on your first shopping trip.
Apr 29, 2009 | Champion 2000+ Household Juice Extractor
Wet pulp
There are two almost identical cone-shaped parts, one with metal screening and one solid dark plastic (I'm going by the parts color appearance of my 8003 model). Be sure you're using the one with the screen, otherwise the juice has nowhere to go but out with the pulp.
Jan 05, 2008 | Omega 8005 Juicer
Motor not working
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked. Hello Duane, Your machine is equipped with a magnetic start system which will only allow the machine to start when you have the screenholder all the way in place just as you would have it to start juicing. If you do not have any parts on the machine it will not start. Please assemble it again and give it a try. If it still wont start call me at 209-369-2154 for further assistance. Thank you Carl
Apr 16, 2007 | Champion G5NG853S Household Juice...
Breville JE900 Juicer Logo
764 people viewed this question
Top Breville Juicers Experts
Greg Cann
Greg Cann
Colin Stickland
Colin Stickland
Are you a Breville Juicer Expert? Answer questions, earn points and help others
