Question about Sun GDM-90W10 24" CRT Monitor
Help, 24" sun monitor not displaying any red color?
Everything else works fine, i've used different cables to connect, must be something inside the monitor, any ideas?
Color card is finished. Change the color card
Posted on Aug 17, 2008
ELMO Visual Presenter (Model EV-2000AF) does NOT display COLOR properly onto HDTV monitor. (Appears Bluish or Reddish w/ 2 Composite Cables connected)
Those jacks you are plugging into on the HDTV are not composite inputs. They are component. The reason the color is not right is, you have to have a Red, Green and Blue connection.
The black and white picture from the 1 cable is because you are using a composite signal into a component green.
Big difference between a composite and a component signal. I hope this helps.
Apr 10, 2012 | Televison & Video
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
My E771 monitor colors suddenly shifted with
1. video-card gone bad;
2. video-cable gone bad;
3. video-cable not tightly-connected to CRT;
4. video-cable not tightly-connected to video-card;
5. "red" gun inside CRT gone bad.
Disconnect the video-cable from the computer, and try again to adjust the "red". If red-free, then it's time to responsibly recycle the CRT.
Reconnect & wiggle the video-cable, to see if that induces any "red" onto the CRT.
Connect the CRT to the VGA-output port on a notebook computer, to see if that video-card generates "red" as one of the primary colours.
Give the CRT a strong "whack" on the side, to see if "red" makes an appearance.
May 07, 2010 | ViewSonic E771 17" CRT Monitor
No color Red, Dell XPS 400, NVIDIA GeForce 7300 LE video card
I would recommend for you to try different monitor, so that you can isolate the problem.
If same problem occur, try to plug in your video card into another PCI slot in your computer. Cleaning the gold fingers of the video card with a clean cotton cloth might help.
Use a blower to remove some dust on the PCI slot.
Or try inserting the video card in another computer. If you get the same problem on another computer, you need to replace the card.
Mar 07, 2010 | Nvidia GeForce 7300 LE 256MB PCI Express...
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
My monitor is getting red color is there any solution
Hello !
Well, there is a problem with either your monitor, VGA cable or video card.
If you wiggle the VGA cable (the cable connected from your monitor to computer) and the color changes, the VGA cable is faulty.
Either connect your monitor to a different computer or connect a different monitor to your computer to see the results.
If your monitor works on another computer, your video card is faulty. If a different monitor works on your computer, then your monitor is faulty.
Hope this helps.
Oct 04, 2009 | Dell Dimension 2400 PC Desktop
ATI Radeon HD 4350 will not display red.
It could be a problem with the monitor cable.
Try unplugging and re-plugging the PC to monitor cable (VGA cable)
If possible, Use a different monitor to ensure that your video card is working fine.
Sep 05, 2009 | Power Color Powercolor 1A1-G000004879 ATI...
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Jul 29, 2009 | ViewSonic VP930b 19" LCD Monitor
No green color on display. All updated drivers and monitor is good
If all drivers are updated and you are positive monitor is ok then it must be the connection in between (video cable) or there is a slight chance the video card is gone bad.
I would try a new video cable first
Try reseating the video card in the slot on the board (take it out and put it back in)
Try the monitor on a different PC if possible with the same cable you are using on yours.
If monitor works fine on different pc and cable is good then also try different video card if possible (even if yours is not old) I’ve seen new cards suddenly have problems for various reasons everything from video cable had a little to much tension on it and the solder connections on the video card came loose all the way to the card just decided to quit working from some sort of defect so I wouldn’t rule out the possibility.
But the most common reason for the problem your having is usually loose connection on back of monitor or PC or bad video cable.
Dec 06, 2008 | Computers & Internet
Computers & Internet Logo
89 people viewed this question
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
