Question about HP Color LaserJet 2600n Printer
Cannot print landscape with LJ 2600
I am trying to print to a landscape document I have done so in the past now it will not.
  • jmerritt22 Aug 11, 2008
    have the same problem, with multiple applications to an HP laserjet 2600N. It is NOT a tray issue. I have multiple HP 2600Ns and only one exhibits the problem. I am using the same user to test it on each 2600N, I've tried multiple computers, I've made sure the settings are correct. This specific 2600N will not print in landscape. The person that answered the question previously is a total moron!
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
I fail to see what it has to do with the printer???? It is an application problem. As long as it's landscape but letter size the printer should not know the difference.
(I work with HP printers everyday). The only thing that might have happen is the setting for your tray may have changed.
Check the setting in the pc under Printers and go to the properties setting,
Posted on Jul 21, 2008
Printer almost always refuses to print Landscape from Excel. It prints Landscape or Portrait from other software, but balks with Excel in Landscape. It prints a portion (the information at the left) in...
Try printing to a different printer if possible. This may shed some light on whether the problem is with the printer or with Excel. You could also open the file on a completely different PC and printer to see if something is corrupt in the file. Also try creating a completely new document to see if it will print in landscape. Can you print in landscape orientation from MS Word or another program?
Jul 18, 2011 | Office Equipment & Supplies
Canon ir3045n - when printing the paper orientation has switched to landscape. How do we change it back to portrait?
Hello Donna,
To change the orientation of the printer from landscape to portrait follow these simple steps;
- open any document and go to print from the file menu
- when the printers settings window opens click 'properties'
- In the next up coming windows you can see menus like 'main, page setup, effects' profiles
maintenance etc.
- click 'page setup'
- There you can see 'page size' and 'orientation'
- change the 'orientation' from landscape to portrait
- click ok and print
Done : )
please rate if this solution was helpful for you, thanks you!
Jun 23, 2011 | Office Equipment & Supplies
Using ASCII commands form IBM INFOPRINT to Tally T6218
I used escape sequence: <esc>(w
this instructs the printer to use Canadian Englis font page
Nov 13, 2009 | Tally LJ Series T6218 LJ Matrix Printer
Will this printer print on heavy card stock and
Yes the 2600 will print on heavy card stock and vellum paper. I had one and did some landscape proposals on this printer and also printed on card stock as well.
Oct 17, 2009 | HP Color LaserJet 2600n Printer
Tally 6212 - Landscape Documents Printed Vertically
You do indeed have problem-- the printer is doing what you are telling it to do changing the print from Portrait to Landscape on a dot matrix printer has the same effect as that on a Laser printer, it rotates the print by 90 degrees.
The correct solution of to define a custom size of paper which is the same size as the paper you are printing on.
If you are using Windows 2000, XP, 2003 etc you can create a Custom Size paper in the following way;
  • Ensure you are logged in with administrtor rights
  • Open the Printers Folder
  • Ensure the FORMS tab is selected
  • Tick the CREATE FORM button
  • Enter a NAME for the form
  • Enter the dimensions (be careful of the units you are using --- best results use inches)
  • Do NOT set margins printable areas etc
  • Click on the SAVE button
One you have created the custom size form you should be able to select this by name in the printer driver properties and the software package you are using.
Jul 28, 2009 | Tally Line Matrix T6050 Printer
My HP PSC 950 prints anything from the Inernet too
Browser printing option is set to print small you need to check that and make sure you using landscape.. There should be no other reason why so check those landscaping options- thanks and please rate acordenly anything above a thanks for trying would be pleasureable..
May 15, 2009 | HP PSC 950 All-In-One InkJet Printer
Scanned legal doc to email comes out landscape and prints on lett
select scan mode, then select legal on paper select. If you select paper before loading document into the ADF it should go with the size you enter.
Jan 07, 2009 | Sharp AR-M550N Copier
Problem printing multiple pages on one sheet!
This is not the fault of the printer but the fault of word.
The way I did it successfully was as follow:
File > Page Setup > Layout = Landscape (sounds like you have already done this)
In the print dialoge, instead of OK, click Properties. On the layout tab, select landscape and below that select pages per sheet = 4 and then click ok... Then click OK to print.
May 22, 2008 | HP LaserJet 2200 Printer
Printing 2 pages on landscape document
Usually if you see the page in the Publisher window is already landscape, it will go landscape in the Printpreview and also in the print out. I just try to imagine what is your problem.
If I am not mistaken, this is what you did:
You have two "small" pages (maybe A5??) and you want to print it in one page of A4. Of course the A4 should be landscape.
Publisher does not have the facility to set 2 pages A5 in one A4 like in Microsoft Word.
The easiest way is just create a new page with A4, then copy the 2 pages (or you called it flyers) and paste it in that A4 landscape page.
Publisher can do print 2 pages A5 in one sheet A4 but the arrangement is as booklet. You can see the choices in File --> Page Setup --> tab "Layout" --> scroll the Publication type.
I do print 2 pages A5 in one sheet with many variations using addition software named "Clickbook".
Let me know if I m wrong in interpret your problem.
Feb 10, 2008 | Adobe Photoshop 7.0 for PC
HP Color LaserJet 2600n Printer Logo
51 people viewed this question
Ben Johnson
