Question about Cell Phones
My w810i isn't working, i dropped it in a small amount of water, and it worked fine afterwards until the battery reached o%, then it turned off. when i turn it on it vibrates and keys light up as usual, but screen doesn't come on. What can i do?
  • Anonymous Jan 05, 2009
    i accidently washed my phone!! i found it at the bottom of the washing machine. i loved that phone to bits and it was a w810i. the keys light up and it vibrates but no screen it stays black but sometimes it goes white for a second. i need a solution!
    Scholar:
  • 154 Answers
Salt water, chlorinated water or just fresh water. If it was fresh water there maybe some water vapour still inside just remove your battery and put it in the oven with door open on about 100c for about 5-10 mins but make sure you keep an eye on it. All you want to do is get rid of the water not cook the chipboard or if you are paitent stick it in the sun battery out and back off for a couple of hours if it was the other 2 waters your phone is propably lost the chlorine and salt eat the chipboards and they tend to short out the fix will only work if you got the battery out after it got wet but it sounds like you never and the lights and whatnot is your phone shorting
Posted on Jul 21, 2008
Tip
What To Do if I Drop My Cell Phone in Water?
The small convenient size of cell phones unfortunately also makes these electronics accident-prone, especially when it comes to water. If you drop your cell phone in water it is often possible to salvage it. If you drop your cell phone in water, you may have only seconds to retrieve it, so you need to act fast even if it means retrieving it from the toilet!
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. It is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open.
If you drop your cell phone in a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
If you drop your cell phone in liquid that isn’t pure water, you may want to try giving it an alcohol bath. The alcohol will displace minerals and microscopic substances as well as aiding in the evaporation of the fluid. If it is available, you should use an alcohol concentration of 95% rather than rubbing alcohol that usually contains only 70%.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If droped your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours.
on Mar 10, 2010 | Cell Phones
SonyEricsson T707 was dropped into water. On recovery (2mins ) later stripped outer covers off and removed battery and sim card. Used hairdryer on unit for about 20mins. Can you suggest anything else I can...
The next thing to do if you drop your cell phone in water is to remove the battery immediately without even hesitating to turn off the power. This reduces the risk of a short circuit which would render your phone useless. Dry the batter with a towel and set aside to dry thoroughly. The battery itself may or may not work again, but fortunately batteries can be replaced fairly inexpensively. Even if the battery does work, it is a good idea to get a new one so as not to risk it leaking battery acid in the future.
After you have removed the battery, dry off the cell phone with an absorbent towel as best as you can. Use cotton swabs to soak up water in crevices and on any fragile, exposed circuits. If you have dropped your cell phone in water, it is also helpful to disassemble it if you can and let all the parts dry separately. Just be sure that you know how to put it back together. If it is a flip or sliding cell phone, leave it open for maximum evaporation.
If you drop your cell phone in water that isn’t pure such as a beverage or in salt water, rinse the phone off with fresh water once you have removed the battery. Once you drop the phone in water, the additional rinsing will not do further damage, however, minerals or other materials will.
Once your phone is clean, leave it in a warm dry area or near an air conditioner for three days before you attempt to replace the battery and turn it on. This is very important, because although you may think that you have thoroughly dried it, the slightest moisture can react with the battery and cause it to short circuit. If drop your cell phone in water, and want to save it, resist the temptation of turning it on to see if it is working until you have waited at least 72 hours. Unless you have insurance for your cell phone which covers water damage, there is no point in sending it to the manufacture with the hope that they will replace it under warranty. If you drop your cell phone in water, the technicians will be able to tell immediately due to moisture sensitive stickers that are contained inside almost all cell phones. The best thing to do is to try the tips mentioned above and repair it yourself.
Jan 03, 2010 | Sony Ericsson T707 Cell Phone
Button to turn op the volume of Samsung Star doesn't work..
If it is in warranty you should reach the dealer and get it repaired free of cost. dont wait
Nov 08, 2009 | Samsung Star GT-S5233 Cell Phone
Will not turn on. looks like it leaked water. power light on with no image in viewer.
i had a small amount of water inside, let ir sit for awhile, a day, with no battery or card and the door open, worked fine, used it again in water same problen, day just started, if it revives, no more pool.
Aug 13, 2009 | Pentax Optio W10 Digital Camera
Water level adjustment
You don't. Front load washers use only a very small amount of water. They fill a small amount, tumble a bit, resulting in water being absorbed into the clothes, which drops the water level in the tub. The washer senses this and adds more water, which repeats until water level stabilizes. The only way to get more water on wash cycles is to use delicate cycles, which use more water, resulting in a more gentle wash action. Remember that due to the low water consumption of front load washers, you should only use one tablespoon of HE detergent per cycle. (even less if you use 2x or 3x concentrate.) This is a FixYa solution. Your washer is working as designed.
Oct 23, 2008 | Whirlpool GHW9100L Front Load Washer
Camera wont turn on or off
Hi
Sounds like the power button switch as been damaged... if I recall correctly it's a very small button and even a small amount of damage to it will cause the parts to no longer align properly which will result in the outer button that you push not reaching the inner button on the board of the camera.
One solution would be to open the camera and see if you can see anything obviously wrong with the button on the inside of the camera. The button is part of the flash assembly, so if there is damage to it replacing the flash will probably solve all your power issues!
If we can help with the part or do the repair for you, please let us know! We pride ourselves in AFFORDABLE digital camera repair... watch out for those ... 'geeks' they will want $150-200 to repair this problem as all they will do is send it to Canon and they will repair it for a flat rate of about $120+.
If all you need is the flash, I can get you one, new or used. New will probably be $40, used $25. If you want us to install it, the cost would only be the cost of the part plus $25 for the installation and return shipping.
Good luck with your repair, and even if you don't need parts from us please let me know if you need any more assistance.
Darntoothysam com
Thomas
Oct 10, 2008 | Canon PowerShot SD850 IS Digital Camera
W810i took a bath!!!!!!
is should have hardware damage since it has been expose to water. you have to send it to service center to get it fix.
Jul 22, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Dropped in water
just go to the place you bought it and ask to get it fixed
-amanda
Aug 26, 2007 | Olympus Stylus 600 Digital Camera
Cell Phones Logo
101 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
