Question about Whirlpool GHW9100L Front Load Washer
Control lock light on
How do I unlock controls The Control Locked light is on my GHW9100LW1. I was able to get all other lights on by pressing Stop/Pause and Control On at the same time but the washer still won't start up. The lights turned off after a few minutes.
  • 1 more comment
  • dlww1 Oct 21, 2008
    My control lock light is on. The washer will not work. I have not been able to get the light to go off.
  • Anonymous Mar 17, 2014
    Control Locked light lit up on control panel, how do I fix it?
  • Anonymous Mar 29, 2014
    pressed cancel to stop the washer, now it's locked
Hold the noise control button in for 4-10 seconds.
Posted on Jul 27, 2008
It says CONTROL LOCKED.... how do I get it unlocked??
  • Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
  • Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
  • Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
  • They designed that mostly for kids sorry pain I know just be calm feel saving some ones child thanx
    Dec 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
    Tip
    The front light lit on my Whirlpool dryer is showing control locked
    Hi.
    If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
    Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
    The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
    When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
    If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
    Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
    If the machine is control locked, try unlocking it with the following procedure.
    To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
    If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
    If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
    If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
    In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
    Regards.
    Ginko.
    on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
    Control lock lit, no other buttons work
    Instructions
      • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
      • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
      • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
    Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
    Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
    I have a Maytag MSD2351 side by side and just replace the water filter. When I attempted to reset the filter light, the control locked and I can not get it to unlock. I pressed the lock and water button...
    If the Control Lock feature has been enabled, the Control Lock light will flash 3 times indicating that it is activated. To turn off Control Lock, press and hold the Options key that says "Control Lock Hold 3 Sec" under it for 3 seconds. If the dishwasher has a dedicated Control Lock button in the Options selections, press and hold CONTROL LOCK for 3 seconds.
    NOTE: You may need to disable Sleep Mode by pressing either Start/Resume or Cancel, or by opening and closing the door before you are able to turn Control Lock off.
    NOTE: If your model requires you to press and hold PROSCRUB UPPER, 4 HOUR DELAY or BOTTLE WASH to lock the controls, the Control Lock light will be on when Control Lock is active.
    Nov 03, 2017 | Maytag Refrigerators
    The controls locked is displayed. what causes this and how do i get the controls unlocked.
    1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
    2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
    3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
    Jan 11, 2011 | Whirlpool GEW9250 Electric Dryer
    Control lock on
    To enable the Control Locked feature when dryer is
    running:
    Press and hold the CYCLE END SIGNAL button for 3 seconds.
    The control is locked when a single beep is heard and the Control
    Locked status light is on.
     When the dryer is off, it is not necessary to press the Control
    On button before activating the Control Locked feature.
    To unlock:
    Press and hold the CYCLE END SIGNAL button for 3 seconds to
    turn this feature off.
    NOTE: When the dryer is running and Control Locked is on, the
    dryer can be stopped by pressing the Off button, but can’t be
    Jun 01, 2010 | KitchenAid KGHS01P Gas Dryer
    Control locked light is on
    This feature allows you to lock your settings to prevent
    unintended use of the dryer. You can also use the Control Locked
    feature to prevent unintended cycle or option changes during
    dryer operation.
    running:
    Press and hold the END OF CYCLE SIGNAL button for
    3 seconds. The control is locked when a single beep is heard and
    the Control Locked status light is on.
    To unlock:
    Press and hold the END OF CYCLE SIGNAL button for 3 seconds
    to turn this feature off.
    dryer can be stopped by pressing the Pause/Cancel button, but
    can’t be restarted until the control is unlocked.
    Here is a manual.
    Apr 10, 2010 | Whirlpool GEW9200L Electric Dryer
    Whirlpool duet washing machine ghw9100lw1
    To turn off "Control lock" : press and hold the "End of cycle signal" button for three seconds.
    Nov 17, 2007 | Washing Machines
    Whirlpool GHW9100L Front Load Washer Logo
    88 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
