Modem and router both say they are connected but both pc's unable to connect to internet.
  • 64 Answers
Go to your router configuration, usually by opening a browser, then typing http://192.168.x.x, putting the ip address of your router in place of the 192.168.x.x. Once there, make sure that you are connected to your ppoe account. The model of your router would help me to help you better.
Posted on Jul 21, 2008
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
I canot connect to the internet but my laptop detect my router
Make sure your modem is plugged in, first and foremost.
Make sure your modem is connected to your Router with the Ethernet cable.
If you're unable to connect still, do a reset on both the modem and the router at the same time. Unplug both, wait for 30 seconds and plug them back in again.
If you are still unable to get an internet connection, right click your wireless connection in the toolbar on the bottom left (Assuming you're using a PC). Click "diagnose" and it will run through your connection, to identify the problem.
Follow the instructions on screen.
If you are still unable to get a connection after trying these, contact your ISP and have them reset the modem and walk you through wireless setup for their particular system.
Thanks!
Hope this helped!
Jun 03, 2011 | Computers & Internet
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
Unable to connect to the internet using a linksys wireless adapter. Connects to the router but can't find the internet.
Isolate the issue by directly connecting the PC to the router via ethernet cable (if possible).
If you were able to get online while hardwired connected to the router, then check the IP address of the wireless network connection, check the wireless security if the network key matches.
If you cannot get online while hardwired to the router, then directly connect the computer to the modem.
If you were able to get online while directly connected to the modem, then the problem is the internet settings on the router. Check the WAN configuration, such as DHCP or PPPoE.
If you cannot get online when directly connected to the modem, then you will need to contact your Internet Service Provider.
Nov 07, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Problem getting to internet through 2wire 2701hg-b router
how can I connect a 2wire 2701HG-B router to a motorola SB5101modem?
Apr 22, 2009 | 2wire Computers & Internet
Can't connect to internet after resetting router.
Try to connect your PC straight to the cable modem and see if the problem persists. If so, the modem is the problem.
You might have to reset your modem.
Unplug your router (power and ethernet to modem), unplug the power of the modem and wait 20 seconds. Plug the power back into the modem and wait until all lights are on. (This sometimes takes a minute or so.) Then plug in a cable into the modem FIRST and THEN into the router.
Now connect the PC to the router and see if you can get internet access.
If not, check your PC settings. It should obtain the IP address and DNS automatically.
If this doesn't help, please supply more information on what modem you are using.
Jan 08, 2009 | Linksys Wireless-G WRT54G Router
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Unable to connect internet
hi,
theres a possiblity that the modem is set to bridge mode,in that way,you will not be able to connect to the internet direclty to the modem,192.168.1.1 is usually the deault gatewayy address for almost all verizon modem and username is admin and password is admin as well,if admin didnt take for the password,try using password as the password
thanks and God Bless
Dec 10, 2008 | Toshiba WRC 1000 Wireless...
I have connected my Wireless G Router #F5D7230-4 to the modem as instructed in the instructors manual and I am unable to obtain a internet connection. I have tried to disconnect from modem and router and...
what kind of brand is it? and make sure your ethernet cable pluged in back of router where its supposed to be and reset your modem first when lights start lighting up reset your router...by reseting i mean unpluging power from equipment...hope that helps
Aug 23, 2008 | Belkin Computers & Internet
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
