Window A/C drainage
Installation manual states "Top rail & side panels are offset to provide proper pitch to the rear of 5/16 inches...necessary for proper water use & drainage."
1) What does 5/16" translate into as an ANGLE , or when using a level ?
(Top & bottom rails are flush, side panels fit easily into window frame.)
2) Manual photos (1915 B.C. quality) show no drain point....Where does
water drain out of the unit, so I don't wake up to find a soggy outlet ?
  • travelcpl13 Aug 07, 2008
    WHERE DO YOU HOOK UP THE DRAIN HOSE?
1/4 " per foot would be a 1 in 48 pitch???
Posted on Aug 05, 2008
  • 1,420 Answers
A little more than 1/4 inch per foot. or a 4/12 pitch.
Posted on Jul 21, 2008
If your window a/c unit is tilted at 5% will it drain properly
Good Morning Friend,
I understand you want to know if your Frigidaire air conditioner, model# FAC126P1, will drain if it is tilted at 5%. I also see that there is no water draining or collecting on the coils. When your air conditioner was installed, you would have wanted to make sure that the top rail and sliding panels at each side were offset to provide the proper pitch to the rear of (5/16"). This is necessary for proper condensed water utilization and drainage. If you are not using the Side Panels for any reason, this pitch to the rear must be maintained! I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire FAC126P1 wall/window Air...
My frigidaire window a/c has a drain hole but it doesn't drain and it is not collecting any water near the coils. Why is it not draining?
I understand your Frigidaire air conditioner, model# FAC126P1, is not draining water or collecting water near the coils. When your air conditioner was installed, you would have wanted to make sure that the top rail and sliding panels at each side were offset to provide the proper pitch to the rear of (5/16"). This is necessary for proper condensed water utilization and drainage. If you are not using the Side Panels for any reason, this pitch to the rear must be maintained! I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Cable system on passenger door power window, 1999 dodge Caravan, has slipped off track. Need exploded diagram to restore to original.
REMOVAL
1. Remove the watershield. (Refer to 23 - BODY/DOOR - FRONT/WATERSHIELD - REMOVAL)
2. Remove door glass retaining clips and secure the window in the up position using masking tape or equivalent(FRONT DOOR GLASS CLIPS).
3. Disconnect wire connector from power window motor, if equipped.
4. Loosen screws attaching front and rear window guide rails to inner door panel (FRONT DOOR MANUAL WINDOW REGULATOR - TYPICAL).
5. Remove screw heads on guide rails from key hole slots in inner door panel.
6. Loosen screws attaching regulator to inner door panel.
7. Remove regulator from inner door panel.
8. Extract rear guide rail through inner door panel rear access hole (FRONT DOOR POWER WINDOW - TYPICAL).
9. Extract front guide rail through front access hole.
INSTALLATION
1. Insert front guide rail through front access hole.
2. Insert rear guide rail through rear access hole.
3. Place window regulator in position on inner door panel.
4. Place screw heads on guide rails in position through key hole slots in inner door panel.
5. Tighten screws to attach front and rear guide rails to inner door panel.
6. Connect wire connector into power window motor, if equipped.
7. Install door glass.
8. Verify door glass alignment and operation.
9. Install sound shield and door trim panel
DIAGRAMS CAN BE FOUND ON JUSTANSWER,COM
Sep 02, 2012 | 1997 Dodge Grand Caravan
How do i change the power window motor on the drivers door?
Aztek, Rendezvous 2001-2005 Window Systems - Power Windows Removal & Installation
  1. Position the window in the full down position.
  2. Remove the trim panel.
  3. Remove the water deflector.
  4. Remove the outer belt sealing strip.
  5. Remove the window weatherstrip.
  6. Loosen the bolts to the clevice clamps.
  7. Remove the window from the outside of the door.
To install:
  1. Position the window between the inner and the outer door panels.
  2. For front window, point the lower front corner of the window down and pass through the belt opening. For rear window, point the lower rear corner of the window down and pass through the belt opening.
  3. Align the edges with the window weatherstrip channel.
    NOTE Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  4. Turn the window to a horizontal position and align the window with the clevice clamps.
  5. Tighten the clevice clamps bolts to 97 inch lbs. (11 Nm).
  6. Install the window weatherstrip.
    WARNING Do NOT allow the sealing lips on the outer belt sealing strip to roll over and point downwards. If this condition is present the window will not raise properly.
  7. Install the outer belt sealing strip.
  8. Install the water deflector.
  9. Install the inner trim panel.
Window Motor & Regulator
  1. Remove the door trim panel.
  2. Remove the water deflector.
  3. For rear window, remove the rear speaker.
  4. Disconnect the window from the regulator carrier plate.
  5. Position the window in the full up position and tape it to the window frame.
  6. Disconnect the electrical connector from the window regulator motor.
  7. Loosen the bolts on the window regulator motor.
  8. Loosen the bolts on the window regulator rail.
  9. Remove the window regulator, lifting up and out from the key slots on the door inner panel and through the access hole.
To install:
  1. Install the window regulator bolts half way into the window regulator motor and the rail.
  2. Position the window regulator rail through the access hole first.
  3. Position the window regulator motor through the access hole.
  4. Install the window regulator into the key slots. Attach the regulator to the motor and the rail. Secure the regulator with bolts and tighten the bolts to 97 inch lbs. (11Nm).
  5. Remove the tape and position the window to the regulator carrier plate.
  6. Connect the window to the regulator carrier plate.
  7. Connect the electrical connector to the window regulator motor.
  8. For rear window, install the rear speaker.
  9. Install the water deflector.
  10. Install the trim panel.
Hope helps (remember rated this).
Jul 16, 2010 | 2002 Buick Rendezvous
Window motor and regulator replacement
Door Glass REMOVAL & INSTALLATION
  1. Remove the door trim panel and the inner panel water deflector.
  2. Raise or lower the window, as applicable, to the half-up position. CAUTION
    Make sure to properly support the window. If the window drops into the door personal injury or window damage may result.
  3. Support the window in the position needed to access the rivets by inserting rubber wedge door stops at the front and rear of the window between the window and inner door panel. Fig. 1: Support the window with rubber wedges in the door channel 88140g46.gif
  4. Use a 1⁄4 in. (6mm) bit to drill out the attaching rivets on the sash channel. Fig. 2: Location of the window retaining rivets 88140g47.gif
  5. Carefully raise the glass to remove from the sash channel, then remove the glass from the door.
  6. Inspect the bushings, retainers, up stop, pins and wedges on the window for damage.
  7. If necessary, remove the bushings and retainers using a prytool covered with cloth body tape.
  8. If necessary, remove the following:
    1. Window front up stop bolt/screw.
    2. Up stop, nut and washer.
    3. Window stabilizer bolts/screws.
    4. Stabilizer pins, nuts and wedges. Fig. 3: Exploded view of the window glass and related components 88140g48.gif
      To install:
  9. If removed, install the window wedges and stabilizer pins.
  10. If removed, install the stabilizer pin bolts/screws and tighten to 62 inch lbs. (7 Nm).
  11. Install the stabilizer pin nut, if removed and tighten to 71 inch lbs. (8 Nm).
  12. If removed, install the up stop and washer.
  13. If removed, install the up stop bolt/screw and nut. Tighten the bolt/screw to 62 inch lbs. (7 Nm) and the nut to 71 inch lbs. (8 Nm).
  14. If removed, install the bushings and retainers.
  15. Carefully position the window into the door so the holes in the bushings lines up with the holes in the channel.
  16. Install the rivets in sequence.
  17. If necessary, adjust the window as outlined later in this section.
  18. Install the water deflector and trim panel.
  19. Remove the drilled out rivets and shavings from the door.
  20. Check the rivet bushings and retainers on the glass for damage. If necessary, remove the bushings using a flat-bladed tool covered with a cloth body tape. Install by snapping the rivet retainer into the bushing.
  21. Lower the glass into the door and position on the sash channel so the holes in the sash line up with the holes in the bushings and retainers.
  22. Using rivet tool J–29022 or equivalent, install 1⁄4 in. (6mm) peel type rivet (part No. 20184399 or equivalent) to retain the glass to sash channel.
  23. Install the rear guide channel.
  24. Install the front up stop to support on the inner panel.
  25. Before installing the trim parts, check the window operation for performance and fit to roof rail weatherstrip.
  26. Install the inner panel water deflector and the door trim panel.
Jul 08, 2010 | 1997 Chevrolet Camaro
1997 mercury villager passenger side mirror replacement guide. how do i do it? is there an easy access panel or does the whole door panel need to be removed
door panel must come off.
go here for villager help
http://groups.yahoo.com/group/villagerquest/
Section 01-05: Trim, Interior 1997 Villager Workshop Manual
REMOVAL AND INSTALLATION Trim Panel(s), Door
Front
Removal
  1. Disconnect the battery ground cable (14301) if equipped with power locks or power windows.
  1. svv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the front door inside handle escutcheon (22620). Failure to do so can result in damage to the component.
    Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942).
  1. If equipped with manual windows, slip a clean shop rag between the window regulator handle (23342) and the front door trim panel.
  1. Pull the shop rag back and forth to release the window regulator handle clip.
  1. Remove the three cover caps and front door trim panel screws.
  1. Remove the one front door trim panel capped screw from the door pull handle.
  1. If equipped with power windows, remove the door pull handle. Disconnect the electrical connectors.
  1. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124).
  1. Remove the front door trim panel.
Installation
To install, reverse the removal procedure. Body Side
Removal
  1. Gently pry loose the body side door latch handle bezel and remove it.
  1. Slide a suitable tool behind each of the retainers and twist the tool to disengage the body side door trim panel from the body side door (24622).
Installation
To install, reverse the removal procedure. Door Electrical Connections
Removal and Installation
Refer to Section 01-11 for Power Window, Section 01-09 for Power Mirror, or Section 01-14B for Power Locks. Watershield
Removal
  1. Remove the Front Door Trim Panel . Refer to the removal procedure in this section.
  1. Remove the front door watershield by carefully detaching it from the adhesive.
Installation
  1. Install the front door watershield in the proper position and press firmly at the adhesive areas. If necessary, use additional adhesive to ensure an adequate seal.
  1. Install the Front Door Trim Panel . Refer to the installation procedure in this section.
May 22, 2010 | 1998 Mercury Villager
How to install a door glass for a Chev C10 . I am have problems install the glass at the Drivers door. I need some help. As soon as possible
GM Full-Size Trucks 1980-1987 Repair Guide
(see Figures 1 and 2)
Non-Stationary Door Glass
  1. Lower the door glass completely.
  2. Remove the trim panel from the door.
  3. Remove the ventilator assembly as previously outlined.
  4. Slide the glass forward until the front roller is in line with the notch in the sash channel.
  5. Push window forward and tilt the front portion of window up until rear roller is disengaged.
  6. Put window assembly in normal position (level) and raise straight up and out.
  7. Installation is the reverse of removal.
Fig. 1: Door window and regulator
Fig. 2: Removing the door glass
Manual Door Window Regulator
(see Figure 3)
  1. Raise the glass to the full up position and tape it to the door frame with fabric tape.
  2. Remove the door trim panel.
  3. Remove the regulator to door panel attaching bolts.
  4. Slide the regulator assembly rearward, disengaging the rollers from the sash panel.
A notch is provided in the sash panel to allow disengagement of the forward roller on the window regulator.
  1. Collapse and remove the regulator assembly through the access hole in the door.
To install:
  1. Prior to installation, lubricate the motor drive gear and regulator sector teeth.
  2. Collapse the regulator and insert it through the access hole in the door.
  3. Unfold the regulator and engage the forward roller to the sash cannel at sash channel notch.
  4. Slide the regulator rearward to engage the rear roller to the sash channel. Also engage the lower roller to the regulator rail.
  5. Slide the regulator into its proper position, and insert the regulator drive through the door panel.
  6. Attach the regulator to the door.
  7. Install the door trim panel.
Fig. 3: Manual window regulator
Power Window Regulator and Motor
(see Figure 4)
Fig. 4: Power window regulator and motor
  2. Disconnect the negative battery cable.
  3. Remove the door trim panel.
  4. Remove the remote control bolts and lay the control aside for access.
  5. Remove the regulator to door panel attaching bolts.
  6. Disconnect the harness from the regulator.
  7. Slide the regulator assembly rearward, disengaging the rollers from the sash panel.
  1. Remove the regulator assembly through the access hole in the door.
CAUTION Step 9 must be performed when the regulator is removed from the door. The regulator lift arms are under tension from the counterbalance spring and can cause serious injury if the motor is removed without locking the sector gear in position.
  1. Drill a hole through the regulator sector gear and back plate. DO NOT drill a hole closer than 1 /2 inch; to the edge of the sector gear or back plate. Install a pan head sheet metal tapping screw (No. 10-12× 3 /4 inch;) in the drilled hole to lock the sector gear in position.
  2. Remove the motor to regulator attaching screws and remove the motor from the regulator.
To install:
  2. Install the motor to the regulator. Make sure the motor and sector gear teeth mesh properly before installing the retaining screws.
  3. Remove the screw locking the sector gear in the fixed position.
  4. Reposition the motor in the door and install the wiring connector.
  5. Attach the regulator to the door.
I really hope help you with this (remember rated this help) Good luck.
Oct 06, 2009 | 1980 Chevrolet Corvette
Back window off track
before you go and buy anything,it may be a good idea to open the rear door panel and see if the window just came of the rail guides on the regulator,there are two white small wheels on the regulator that ride on a guide rail attached to the window this rail is attached to the window by two rivets or bolts,just take the cover panel of and see what is the matter in there. here ara steps to get there.
  1. Remove the assist strap hole cover, bolt and assist strap.
  2. Using a screwdriver, remove the back door trim cover.
    NOTE Tape the screwdriver tip before use to avoid damaging the trim pieces.
  3. Remove the plate and disconnect the electrical connector.
  4. Remove the back door glass.
  5. Remove the window regulator and glass guide rail.
  6. Installation is the reverse order of removal.
Sep 08, 2009 | 1991 Toyota 4Runner
Window regulator replacement
Window Regulator, Rear Door, Explorer Removal
  1. Remove the rear door trim panel and watershield. Refer to Section 01-05B .
Trim Panel, Rear Door, Explorer, Hi-Series Four-Door Removal and Installation
  1. Remove the two screws retaining the rear door trim panel (27406) located above the door handle.
  1. Remove trim cup at the door handle using a screwdriver or sharp object. Retention nibs will flex for easy removal.
  1. To remove window regulator switch plate (14524) , use notch located at lower end of plate using a screwdriver to lift and remove.
  1. Remove window regulator switch plate from rear door trim panel pulling wire harness from rear door trim panel .
  1. From bottom of window regulator switch plate , remove two screws and disconnect connector from window regulator control switch (14529) .
  1. At each plastic clip location, pry the rear door trim panel away from the door inner panel using the door trim panel removing tool from Rotunda Moulding/Trim Kit 107-00401 or equivalent.
  1. Remove panel, lift slightly to remove flange at the top of rear door trim panel from trough in the glass weatherstrip. For installation, follow removal procedures in reverse order. Replace any bent, damaged or missing plastic clips on the rear door trim panel to the door inner panel, firmly loading clips into slots provided on rear door trim panel .
  1. If equipped with power windows, disconnect the wire from the regulator.
  1. Remove the rear door window glass as described in this section.
  1. Remove the window guide, if equipped, (nuts and washers). Remove guide from door belt opening.
  1. Remove three 1/4-inch rivets attaching motor bracket (electric) to inner panel and two 1/4-inch rivets attaching regulator lower bracket to inner panel. Use drift punch to knock out center pins for each rivet. NOTE: Use care not to enlarge sheet metal holes in the door inner panel when drilling.
  1. Using a 1/4-inch diameter drill, drill out the remainder of the rivet.
  1. Remove two upper regulator attaching nuts.
  1. Remove regulator from the front door (20125) .
Installation
  1. Lubricate regulator mechanism with Multi-Purpose Grease D0AZ-19584-AA or equivalent.
  1. Install regulator into access hole in inner panel.
  1. Position regulator using upper regulator studs and tabs on motor mounting bracket (electric) or cup mounting plate (manual).
  1. Install rivets attaching regulator to door inner panel (1/4-20 x 1/2-inch bolt and 1/4-20 nut and washer assemblies or equivalent metric fasteners may be used as alternates).
  1. Install two upper regulator attachment nuts.
  1. Install door glass as outlined under Door Glass Installation.
  1. Adjust glass as outlined under Adjustments .
  1. Reconnect wire to regulator, if equipped.
  1. Check operation of window regulator.
  1. Install door watershield and trim panel. Refer to Section 01-05B .
Apr 11, 2009 | 1994 Ford Explorer Limited
How do i replace the window motor
This is a common problem with driver side window. Its just a wear and tear problem. Don't go to the dealership, the Regulator will cost you over $230. Go to Amazon.com and search for the part number which should cost you only $70-80 or so. If you go to a glass place they will charge you dealership price plus $150 per hour. I say do it yourself which goes a little something like this.
TRIM PANEL
REMOVAL
(1) Remove the plug and remove screw attaching
door pull cup to inner door panel.
(2) Remove switch bezel and disconnect power window/
memory switch.
(3) Remove screws attaching trim panel to door
from below map pocket.
(4) If equipped, remove window crank. (Refer to 23
- BODY/DOOR - FRONT/WINDOW CRANK -
REMOVAL)
(5) Remove screw holding door trim to door panel
from behind inside latch release handle.
(6) Disengage clips attaching door trim to door
frame around perimeter of panel.
(7) Lift trim panel upward to disengage flange
from inner belt molding at top of door.
(8) Tilt top of trim panel away from door to gain
access to latch linkage.
(9) Disengage clip attaching linkage rod to inside
latch release handle (Fig. 13).
(10) Separate linkage rod from latch handle.
(11) Disconnect the power door switch, courtesy
lamp electrical connectors.
INSTALLATION
(1) Hold top of trim panel away from door to gain
(2) Place linkage rod in position on latch handle.
(3) Engage clip to hold linkage rod to inside latch
release handle.
(4) Place front door trim panel in position on door.
(5) Install trim panel into inner belt molding at
top of door.
(6) Install clips to attach door trim to door frame
(7) If equipped, install screw to attach door trim to
door panel behind inside latch release handle.
(8) If equipped, connect power switch into wire
connector.
(9) Place power accessary switch in position on
door trim.
(10) Connect wire connector into memory seat/mirror
switch and install switch into trim panel.
(11) Install screws to attach accessary switch
panel to door trim.
(12) Install screw cover into switch panel.
(13) If equipped, install window crank.
(14) If equipped, install screws to attach trim
panel to door inside map pocket.
(15) If equipped, install screw to attach door pull
(16) If equipped, install screws to attach door
assist handle to inner door panel.
(17) Connect wire connector into courtesy lamp.
(18) Install lamp in door trim.
(19) Install switch bezel.
WINDOW REGULATOR
REMOVAL
(1) Remove the watershield. (Refer to 23 - BODY/
(2) Remove door glass retaining clips and secure
equivalent (Fig. 15).
(3) Disconnect wire connector from power window
motor, if equipped.
(4) Loosen screws attaching front and rear window
guide rails to inner door panel (Fig. 16).
(5) Remove screw heads on guide rails from key
(6) Loosen screws attaching regulator to inner door
panel.
(7) Remove regulator from inner door panel.
(8) Extract rear guide rail through inner door
panel rear access hole (Fig. 17).
(9) Extract front guide rail through front access
hole.
INSTALLATION
(1) Insert front guide rail through front access
hole.
(2) Insert rear guide rail through rear access hole.
(3) Place window regulator in position on inner
door panel.
4) Place screw heads on guide rails in position
(5) Tighten screws to attach front and rear guide
(6) Connect wire connector into power window
motor, if equipped.
(7) Install door glass.
(8) Verify door glass alignment and operation.
(9) Install sound shield and door trim panel. __________________
Avatar: EconoVoyager Concept
2001 Dodge Grand Caravan Sport 3.3L
Apr 05, 2009 | 1998 Dodge Grand Caravan
Heating & Cooling Logo
229 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
