Black Screen shows memory counting which stops at 256 Mb [is correct] Hit F10 & screen says "Setup" in bottom right hand corner-screen is still black. Floppy Drive Bay green light staying on.
change your cmos battery & and set a boot priority in first boot in hdd
Posted on Jul 21, 2008
There is a round black circle, bottom right corner of the screen when on
could be a burn from constant display of each channels ID
turn off from the wall
wait an hour
see if the screen settles
May 02, 2016 | Televison & Video
Black screen flashing dash top left corner. ....wont reboot after system restore
If its only 3 mnths old should still be under WARRANTY take it back
if its not under warranty
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup usually delete or the F2 key this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Apr 03, 2012 | Computers & Internet
I have a compaq r4000 cto. I just replaced the system board with a used board. When I first started it up I got a black screen and three beeps which after a few tries became a black screen and four...
It's unlikely that you have 2 or more defective memory modules. Remove all cards such as video, modem, etc. Also disconnect all drives (hard drive, CD, DVD). Try booting with one memory module at a time. If still a no go then I would suspect the motherboard.
Feb 20, 2011 | HP Compaq Presario R4000 Notebook
Startup
Black Screen shows memory counting which stops at 256 Mb [is correct] Hit F10 & screen says "Setup" in bottom right hand corner-screen is still black. Floppy Drive Bay green light staying on. Regards John
Jul 10, 2008 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Radeon AGP 9800 ati 256 mb
The memory on your card is beginning to fail. There is no repair for it, and it's time to let it retire.
You should be able to find a new 5700 or similar still in most computer shops. Pricing is the big problem with them costing far more then an equivalent PCI-e model.
Apr 21, 2008 | ATI RADEON 9800 PRO (256 MB) Graphic Card
When i add a memory in damaged DIMM slot showing black screen?
Try moving the working DIMM to other slots, it should work in any slot, if it does, the other ram u have is incompatible or bad
Install a matched pair of DIMMs (equal in speed: DDR266, DDR333, or
DDR400; density: 64 MB, 128 MB, 256 MB, 512 MB, or 1 GB; and
technology: 128 Mb, 256 Mb, or 512 Mb) in DIMM 0 in both Channels A and
B. If additional memory is to be used, install another matched pair of DIMMs
in DIMM 1 in both Channels A and B.
Mar 25, 2008 | Intel D865GBF Motherboard
My Acer Aspire 3000 has a blank screen
When you get in setup check the time and date and see if correct, if not; correct it and save settings and exit, then it should reboot. If the time is correct and date then you will have to reboot the system and keep pressing F8 while its booting, this will take you into safe mode, you need then to choose last known good cofiguration and hit enter, hopefully you should now get into windows.
Sep 05, 2007 | Acer Aspire 3000 Notebook
Open Questions:
Computers & Internet Logo
316 people viewed this question
David Payne
David Payne
