Question about Sony STR-DE345 Receiver
Protect Mode Goes into Protect mode at different intervals. Opened up component and cleaned out. Also noticed that if the receiver is on and not in Protect mode, that with the cover off if you push slightly outward on the back panel it triggers it into Protect mode. Like a ground problem maybe. Any suggestions?
  • mikeyd61978 Mar 11, 2009
    my receiver buzzes then shuts down and goes in protect mode. It'll work a few minutes before it does this but every time BUZZZZ then protect..
  • 4,234 Answers
There are bad connections on the main board that are effected by heat. I would suspect that when the volume level is higher, the system shuts down sooner. This should be a simple repair that will not require parts. If you can solder, you should be able to repair this yourself. If not, the cost will be the local labor rate.
Dan
Posted on Jul 21, 2008
Why does my new AVR X1000 keep going in protect mode
It only goes into protect mode usually when there are to manny speakers hooked up more then its can handle
Aug 01, 2014 | Denon AVR-X1000 5.1-Channel Network AV...
After turning on the tv, the power goes on and off automatically
Hi.
The TV goes into protect mode because a internal fault is detected. Protect mode is a forced standby mode that starts when an internal fault is detected. The TV power board supplies power in different voltages. When in protect mode the PSU higher voltages are shuts down. The only PSU line that remains live is +5VDC.
All you can do at user level is turning off the TV and disconnect the power cord for about ten minutes. This will drain power from the TV circuits and can fix temporary problems caused by the accumulation of electrostatic charge in internal components.
If after the power drain the TV still does not restart, then internal components must be tested and repaired. The job must be done by a trained technician. To book a technician or to order parts call the phone number listed on the owners manual.
Regards.
Ginko
Dec 15, 2011 | Televison & Video
Goes into protect mode..
you probly have speaker wires arching. unplug them and replug thm in making sure no bare wire is showing
May 17, 2009 | Sony STR-DG520 Receiver
Onkyo av amp goes to protect mode
There's a fre service manual here, you need to join tte site (free)
Onkyo TX SV727 Manual AV Control Receiver HiFi Engine
Sep 06, 2017 | Onkyo TX-SV727 Receiver
Sony STR-D611 receiver goes into protect mode when turned on.
I cleaned the contacts on the transistors and it's working great now. Previously, I spilled some drink on the unit and it went into protect mode and it was in the power amp section. It's all up and running again. Thanks for the info. --Steve B.
Dec 06, 2008 | Audio Players & Recorders
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
Goes immediately into protect mode
Yep. The wiring to your speakers or the speakers themselves have shorted out. You have a blown fuse. You'll need to either replace the unit or attempt to replace the fuse yourself.
Sep 10, 2007 | Sony STR-DE425 Receiver
i believe protect mode is because you have the wrong impedence speakers, they are too low (4 ohm? 6 ohm?) it chols work with 8 ohm speakers
Aug 16, 2007 | Onkyo TX-SV454 Receiver
Protect mode
You may have loosened a solder joint on one of the components inside with your air blast. A repair tech would monitor the outputs DC offset voltage and he will probably see one that is not zero volts and while wiggling various things he should see a sudden change in the DC offset voltage on the bad channel when he touches the bad connection. Then it's just a matter of resoldering the connection. Good luck on this one.
May 02, 2007 | Sony STR-DE425 Receiver
Sony STR-DE345 Receiver Logo
312 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
