Question about Hitachi Heating & Cooling
Air conditioner drippin water - Hitachi Heating & Cooling
  • 1,420 Answers
OK, it is supposed to. Just not on anything. Tell me more!
Posted on Jul 21, 2008
Turns on but doesn't put out air
MAke sure you have it leaned back and that water is dripping from it in the back if not do so if water still isnt drippin than screw some holes in the bottom so it can drip if it doesnt work than it might have blown up
Jul 11, 2012 | Fedders Y Chassis AEY12F7E Air Conditioner
Air conditioner leaked a lot of fluid that looked like water after being on all night. Do you think this is an easy fix, or what do you think is wrong with it? Thanks
All air conditioning units have built in drains. When the drain is clogged the water fills the drip pain and spills out. An easy fix is to open you unit and just wipe the drains. If you cannot find the drain find where the water is coming from and trace the water to the source. The other possibility is that the unit has a dehumidifier that is not properly sealed and it is leaking the water it collects if so find the dehumidifier (usually labeled) and pull the cover off clean the seal and put cover back on (may snap into place) and see what happens the next day.
Aug 21, 2011 | DeLonghi PACA110 Portable Air Conditioner
Should my 10,000 btu window air conditioner be leaking water all over my balcony
Air conditioners put out cold air, exhaust hot air, and produce condensation when they are in use. The condensation is the water that is dripping out of your air conditioner.
Your air conditioner is not broken, but it would be wise to determine a way to direct the water off of the balcony.
May 22, 2011 | Whirlpool Heating & Cooling
Help, Brand New A/C unit drippin inside camper
they do that its normal operation, you will get varying amount depending on your location and humidity. If it is not balanced or installed right it drips in the camper.
Aug 16, 2009 | Dometic Rooftop RV Air Conditioner
Water
No you never need to add water to an air condioner. An air conditioner removes water from the air. Get back if you have any other questions, I want to assist you.
May 27, 2009 | Haier 539490003 Air Conditioner
Monte carlo ss 83 350
Did you say you chg. water pump?or just the upper and lower hoses and thermostat? If there is water comming out the weap hole under neck of water pump it needs replaced. The water comming out pipes is just condensation.
Feb 19, 2009 | 1989 Chevrolet Suburban
Water stop dripping less cooling
Your aircon probably needs refrigerant recharge.
Jan 29, 2009 | Heating & Cooling
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
No water
If the air conditioner is putting out cold air, don't worry about it making water. You may not have enough moisture in the air to produce more water than it requires.
In some types of air conditioners, the water taken from the air is used to assist in cooling the condenser unit. The excess is run off.
Jerry G.
Jun 21, 2008 | DeLonghi CF210 Portable Air Conditioner
Heating & Cooling Logo
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
